Question about Canon Office Equipment & Supplies
Paper gets jammed into my printer whenever i feed paper (canon LBP 2900
    Top Expert:
  • Canon Master
  • 35,531 Answers
Use a flashlight to examine all accessible parts of the paper feed path. Chances are you will find a bit of paper or some other debris
Posted on Oct 29, 2012
  • 6 Answers
SOURCE: Canon PIXMA MP600 printer - paper feed
Issue: Paper feeds skewed
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
  3. Press the <HOME> (A) button.
  4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
  5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
  6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
  9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
The above illustration shows a PIXMA MP500
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click here to return to step 2
Posted on Jun 12, 2008
pineworks
  • 4041 Answers
SOURCE: paper won't feed through canon printer. no paper jam apparent -
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
  • 4 Answers
SOURCE: Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
Posted on Jun 25, 2010
canontech
  • 1219 Answers
SOURCE: how can i clean my canon LBP 2900 laser printer?
First check the toner crg., if you have marks on drum, replace crg.
Posted on Jul 02, 2010
SOURCE: Paper wont feed into printer no paper jam
In the comments section Blumm suggests pushing a piece of cardboard (like the back of a legal pad) through the feeder as far as you can. Turn the printer off and then on again with it in there. Pull the cardboard out and check for any foreign objects that have been pushed through.
It worked for many people including myself - I got a piece of plastic and it works wonderfully again!
Posted on Jul 31, 2010
Canon lbp 2900 paper jam
if paper jam at the half of of fuser unit then problem is with fuser or spong roller tell us location of jaming
Mar 31, 2014 | Office Equipment & Supplies
I am using canon 2900 printer and i having every time paper jam issue please help me
Paper jam I suppose is the commonest of all printer problems as it can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation. I have observed that most people fan the paper pile to keep them dry or non-sticky. It's a wrong method because fanning the pile of papers make them go haywire and often lead to paper jam.
Aug 27, 2012 | Canon LASER SHOT LBP-2900 Printer
Paper jamming trouble when i getting printouts from my cannon printer, the paper jams in the printer
It is not major dont worry you just need the service of printer contact with any service provider
Sep 10, 2011 | Canon LASER SHOT LBP-2900 Printer
I have a printer canon lbp 2900b. problem of the printer is alignment.paper feeding is correct,but alignmet is correct.
To clean your Canon laser shot > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc...
This will solve the paper jamming problem. Hope this helps, please rate if the solution was helpful, thanks!
Sep 02, 2011 | Canon LASER SHOT LBP-2900 Printer
Paper jam always
clean the paper feed roller sitauted in the lower centre of paper tray
Jan 29, 2011 | Canon LASER SHOT LBP-2900 Printer
I have a cannon LBP 2900 printer and it keeps saying there is a paper jam but there is no paper in it. How can I fix this?
I also haave the same problem with the canon laser shot lbp 2900 even it is a new piece. so it is better never to use this product.
Jan 14, 2011 | Canon LASER SHOT LBP-2900 Printer
Iam havin the canon lpb2900. it has beb workin pretty well. now we are havin problem with paper bein jammed inside. how do u get the paper out?
1. Open the top cover.
2. Pull out the toner cartridge.
3. Pull out the paper slowly in output direction.
4. Having paper jam continuously, check the fixing film.
Jan 15, 2010 | Canon LASER SHOT LBP-2900 Printer
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
242 people viewed this question
old marine
old marine
