Question about HP Computers & Internet
My laptop just started showing insert boot disk and press enter, what do i do? i need help as my dissertation is saved in my laptop. i hope i wont loose my work. help pls
I dont know just help pls
  • 105 Answers
I think that for your work it's too late but you can try use a linux live CD to boot and explore your HDD
SystemRescueCD is good for this job
Posted on Oct 28, 2012
  • 5 Answers
SOURCE: hdd master password
PLEASE REPLACE UR MOTHER BOARD BATTERY. I GUESS UR BATTERY MODEL WILL BE CR3212... PLEASE CHAGE IT AND TRY IT AGAIN. NOT YOUR LAPTOPS BATTERY... THIS IS A BATTERY ON THE MOTHER BOARD. PLEASE TAKE IT TO UR NEAREST DEALER AND GET IT DONE.. PLEASE DO NOT OPEN IT WITH ANY KNOWLEDGE.
CHEERS
AVI
Posted on Nov 05, 2007
freetek
  • 5568 Answers
SOURCE: Aspire 5315, no bootable device, PXE-E61 media test failure,
With any standard laptop (your Aspire included) the default boot disk should be set to drive C:
If the system is not finding drive C:, the boot sector may be damage or the drive may have failed completely.
Depending on your operating system (probably Win XP for this one) you can make a boot disk on a friend's optical drive and change the boot sequence in the BIOS setup to your optical drive. Just make sure the disk you've made is compatible with the drive in your Aspire; such as CD - DVD+-, etc.
Once you can get some kind of prompt, either from a basic Desktop or just E:\ from your boot CD, try typing in "C:" (without the quotes) to see if it is accessible. If not, the drive may be bad.
If the drive is still readable, you have more work to do to restore the damaged boot sector.
Posted on Mar 21, 2009
sidlas
  • 95 Answers
SOURCE: my laptop says BOOTMGR is missing what does that means?
tap f8 when boot,in menu go to last good known configuration>enter,post reply if not helps will give further instructions if needed.
Posted on Jun 15, 2009
SOURCE: Acer Aspire One Insert boot disk
well u really cant put in a disc, you said you have the aspire one that means it doesn,t have a disc drive . Thats the way it was made
Posted on Jul 10, 2009
SmartFix
  • 89 Answers
SOURCE: When I Turn On My Aspire One mini Laptop, Windows
  • You have to boot with the operationg system cd.
  • If not Click here and follow to Create boot disk.
Please rate my response!!! Thanks, SF
Posted on Jan 28, 2010
FORMAT NEW HD
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Jul 03, 2012 | Computers & Internet
Emachine350 has no bootable devce
Try pushing f2, and going into boot options, and make sure the hdd appears in the list, if not, it's possible the hdd has coincidentally failed. If it does appear what order are the boot options in?
Mar 15, 2012 | Computers & Internet
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
I have been using HTS545032B9A300 320GB drive in my Samsung R428 laptop. One day, suddenly, its shuts down and never boots up. It never gets beyond setup. It hangs and showing "Entering into...
When start your laptop,is their any spinning sound in your hard disk(Hitachi)?
If so, try to go setup the bios ,just watch the laptop either detect or not,
If your laptop detect the hard disk ,again install to the laptop, and remove the new seagate just for recover the data through following step.
Please download hiren boot bootable ISO file ,
Download the iso file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
Mazor problem is most of the user, burn ISO file in data mode and the result, it could not run in boot time.
Burn the iso file, under image burning option from any nero .
Boot from cd, no need to setup bios.
DONT PANIC follow all the steep It is very simple. (Use the down arrow key.)
1.INSERT CD TO CD TRAY
2.Boot from cd
3.Select start boot cd
FOR REPAIR THE HDD DONT PANICI
Choice hard disk tools
1.select HDD regenerator>enter
wait create it auto mode
2.Enter(If you have one HDD)
3.Press "1"ENTER for scan and repair (With out lose any data)
4. press 3 for REGENERATE ALL SECTORS
I will sugest press for "1" and enter
press( 1-9 )any one number and type mb and ENTER
Repair will Start soon.
Insert a pen drive
Restart your laptop and boot from cd
1.Boot from cd
2.Select mini windows
3.you can explore every drive (hitachi) and can copy paste to pen drive.
ALL IT WILL BE POSSIBLE IF YOUR HDD CAN SPIN AND AND READ .
Hope this helps.
Shibuda,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 18, 2011 | Hitachi Travelstar 5K500.B...
When turning on my acer aspire desktop a black screen comes up with the following and wont start up: Verifying DMI Pool Data...... Update Success Boot From CD: DISK BOOT FAILURE INSERT SYSTEM DISK AND...
Ensure that you havent got a cd in the cd rom then reboot, press F2 or Delete to enter the bios and look for boot options, set the primary boot to your harddrive press F10 and press y to save and exit the bios, Press F11 and set that to boot from harddrive and let the computer boot, if it still dosent boot to windows then the hdd has become faulty, or has been wiped of the operating system and windows will need to be reinstalled.
Aug 21, 2010 | Acer Aspire™ T180 PC Desktop
Laptop will not start up the toshiba oening page shows on screen then the screen goes blue with only the cursor showing
For that when you power up the computer press F8 key then enter into safe mode and if you able to enter in safe mode.
Then first remove temp files from computer.
Go to start->run or press windows key + R key then you can see run type in run "%tmp%" then press ok then delete all temp files then type in run "prefetch" press enter delete all prefetch files.
Type in run "chkdsk /r" then press ok then press "y" then restart computrer then it fix error on harddrive.
Also scan computer with updated antivirus then it works fine.
But if you are not able to enter in safe mode.
Then you need windows disk for that insert that disk into rom then enter in bios and set first boot device as cd/dvd rom then save settings and exit from bios .
Then it boot with that windows disk.
Then follow the procedure on screen and choose options are when it ask for "Repair previous windows" .
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 17, 2010 | Toshiba Satellite Pro L300 Notebook
Gateway mx6453 wont boot up- oper system not found
Restart the computer while tapping the deleate key this should bring you to bios go to advanced and check if the harddrive is listed with it highlighted press enter to enter the sub menu make shure its not disabled if it is enable it hit escape key to exit sub menu go to Boot on main menu set hard drive as 1st boot device set cd/dvd drive as 2nd boot device press f10 to save changes and exit. Try restarting
if you get msg opperating system not found use the system restore disk
Hope This Helps good luck
Please leave feedback
Nov 26, 2009 | Gateway MX6453 Notebook
I have an Acer Aspire One notebook. I cant seem to start it. I turn it on and this displays : Check cable connection..! PXE-E63 : Error while initializing the NIC PXE-M0F : Exiting Intel PXE ROM. No...
It happens when no boot device is selected, the default is network boot first, you must select CDROM/DVDROM or HD as your first startup device. boot up machine and enter bios setup think its F2 key to enter bios generally it del or f1 or f2 it may say onscreen at start if f2 doesnt work
in the bios set boot order to HD as firstboot option then save and exit
hope this helps
dont know if all acers do this but also if you press f12 on boot up it gives you current boot options select HD that way is current boot and would have to be done everytime
Nov 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
I need to restore my laptop to the factory settings. I have the recovery disks that came with it. What are the steps I need to take when using the operating system restore disc? I'm not familiar with...
Hello
First
what disk do you have?
one should be OS disk and a other should be drivers and software or a recovery disk.
if you have a label recovery disk start with that.
if you have an OS + driver disk start with the os disk.
put it in cd and press a key when it says so.
here is a very good guide to follow
after you installed the os then run the driver recovery disk just click next, its not that hard.
Sep 04, 2009 | HP Pavilion dv1000 Notebook
Boot problem
use the orginal windows cd and inset the disk and
show the press any key that time press ENTER ok ...........after booting is start .................send me feedback.......ok
Apr 01, 2009 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
