Question about Zanussi ZKC5540X Stainless Steel Electric Range
I want to reset the timer on the clock on my zanussi cooker
3 Suggested Answers
SOURCE: zanussi cooker
thanks but solved the problem.The white wire was loose in the socket on wall.
Posted on Oct 15, 2008
  • 5 Answers
SOURCE: I have a zanussi gas cooker. we had a power cut
There should a symbol of a hand on one of the switches or buttons, press or turn and then it should set to manual.
Posted on Oct 11, 2009
My zanussi cooker isn't working after a power cut...even the timer/clock isn't flashing to reset wht can I do
Claire. Have you checked the cooker supply switch? (Usually on the wall near the cooker) If it has a neon light is this on? If not or no neon check the circuit fuse/mcb in the fuseboard. Allan Pointer.
Apr 06, 2016 | Zanussi Ovens
Oven will not heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jul 04, 2011 | Zanussi ZBF260 Electric Single Oven
Cooker oven not working - replaced bulb. Hot plates still work.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Jan 07, 2011 | Zanussi ZCE611X Electric Kitchen Range
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
Cooker clock requires resetting
You need to press 2 or more of the timer/clock buttons in seqeunce to cancel the auto setting.
The sequence of buttons varies according to the make of cooker, so just keep pressing the buttons until you hit the correct sequence.
Hope this helps.
Jan 06, 2010 | Ovens
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
CLOCK & OVEN PROBLEM
How Ironic, we have a Moffat Discovery and exactly the same thing has happend, so we are waiting for a new Zanussi to be delivered.
As the clock timer is linked to the oven it will not light when the clock has broken.
Temporary solutions: So I turned all the electricity to the cooker off and left it a while, when I turned it on still the same problem, but after about 2 hours it comes back on, works for a couple of days then goes off again, (always seems to go out when my missus is planning to cook, so wondering if she' got something to do with it, don't tell her I said that though)
Now trying to switch the clock setting to stop or manual, and when it goes off i'll try and see if the oven lights,
HPC
Mar 03, 2007 | Zanussi ZCG7680 Gas Kitchen Range
Zanussi ZKC5540X Stainless Steel Electric Range Logo
Top Zanussi Kitchen Ranges Experts
Paul Bade
ray gallant
Ellie Davis
Ellie Davis
Level 1 Expert
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
