Question about Caroma 270W-RF Reflection Round Front Dual Flush Toilet - White
The bowl doesn't flush from the front part
The front half circle of the bowl wouldn't have water flowing when flushing
  • salman Oct 30, 2012
    the water is flowing only from the back not the front
    Genius:
  • 1,212 Answers
If a new toilet, the front holes may not have been cast correctly. If an older toilet it is likely mineral buildup has blocked those holes. A mittor and a coat hanger shoudl suffice to open the holes up, use the mirror to see under the rim lip and use the coat hanger to open the holes- you may need to use a larger clip instead depending on the size of the holes.
Posted on Oct 30, 2012
3 Suggested Answers
  • 21 Answers
SOURCE: after flushing, the water slowly leaks into the
It's suppose to do that. The internal P-trap has to be reprimed everytime it is flushed.
Posted on Nov 27, 2009
  • 6 Answers
SOURCE: how do I adjust the
By moving the float
Posted on Oct 25, 2010
What is a flush cylinder
It is really the valve that opens up to let water flow through the bowl when activated by the flush lever, to flush the toilet. it should prohibit water from flowing after the toilet flushes.
Aug 03, 2014 | Kohler - Toilet - One-piece - Santa Rosa -...
Flush's to the front only
Just make sure the back is not clogged.
Jun 24, 2013 | Eljer Home
The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Jun 09, 2012 | Toto CST744SLR Elongated Drake Two Piece...
Flushing problems
Tank needs more water and the flapper has to stay open longer by adjusting chain so the flapper goes up higher when you flush the unit. Practice and you will get it right.
Apr 09, 2017 | Kohler Toilet - One Piece with Ingenium...
My toilet doesn't flush every time I flush it! It only flush If I pour a little more water into toilet bowl while water coming down toilet bowl! I've checked water level in tank and it was full...
I think the problem with your toilet bowl is in the tank fitting of it..you better check if the fittings are proprerly working..You also check the flapper and also the fillvalve.
If it is not good already you can replace it by buying the tank fittings at the hardware store..And you better also be check it to your plumber for the second thought..
Jun 17, 2011 | American Standard Home
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Jul 19, 2010 | American Standard Cadet 3 FloWise...
The water in the bowl does not evacuate properly. Seems only half of dirty toilet water leaves the bowl leaving other half of dirty toilet water to mix with clean water coming in from bowl. Secon, third...
what you need first is to check to see if your bowl is out of level then use a snake rotor to clean any mess in the bowl then flush this should solve your flushing problem
Oct 25, 2009 | American Standard 735083-400.178 Tank...
When flushed, not enough water flow to empty sides and waste
make sure water level is sat at factory settings. there should be a black line that reads WATER LEVEL. If this is not the problem. then you have calci buildup. get a gal. of muratic acid,plunge all water out of toilet bowl. then dump in at least 1/2 gal. let set over nite. with water turned off. get up turn on water then flush. You mite have to do it twrice. hope this helps you.... duane.
Sep 28, 2009 | Kohler Barrington Pressure Lite Elongated...
No back flush pressure
increase the tank water level half inch at a time till you have the back flush pressure.
seems like the water in the bowl is too low to create any wirlpool.
Oct 30, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Caroma 270W-RF  Reflection Round Front Dual Flush Toilet - White Logo
94 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Ngoro
Ngoro
Are you a Caroma Home Expert? Answer questions, earn points and help others
