Question about Engel MT-35F-U1 34 Qt Portable Refrigerator & Freezer
Engel keeps turning on and off when it reaches temp
When our engel is turned on it will cool to required temp and then it turns off and on every few minutes. it will keep on doing this for the time it is on. Draws lots of power from battery.
4 Suggested Answers
sodeep
  • 3267 Answers
SOURCE: My engel MT60F motor turns on for 1-2 seconds and
Looks either your thermostat is malfunctioning. If thermostat is OK then the problem might lie in loss of refrigerant gas, freon or CF4. Get these 2 items checked in the above sequence..sodeep
Posted on Jun 27, 2009
SOURCE: Sr70f g4 refrig. 12v 240v.
check to make sure the fan in the back is runing sometimes things fall off the back and stop the fan from running ie plastic bags
Posted on Apr 12, 2010
baraquielnar
  • 247 Answers
SOURCE: My engel cools when set to max,but when it
this noise is normal due to starting period the compressor felt hard pumping operation but after a minutes it run smothly or maybe your unit has a year in using there is a possible wear and tear of mechanical parts a try to set it your thermostat on your desired setting then observe operation. the function of to sense the temp. inside and stop the comp. after reaching your desired temp.
Posted on Feb 06, 2011
Thermocouple
Does it ever actually reach the temp set? It may just need cleaning and a service so it cuts out at the right temp.
Apr 01, 2014 | Engel Freezers
Engine only reaches temperature after I turn it off
please check if cooling fans are running all the time- only should come on when engine temp reaches fan temp setting- google it for exact temp
Feb 21, 2014 | 1994 Chevrolet Suburban
Fans are not cutting on
your fan comes on when your car reaches required temp but if you turn the ac on it will turn the fan on also but if your fan don't work at normal temp check cooling fan relay or fan motor
Sep 24, 2012 | 1997 Chevrolet Malibu
93 honda accord shuts off after reaching temp
I had the same problem with my accord years ago and it turned out to be that the ignition module would die whenever it got hot and then start working again when it cooled off. It is located inside the distributor and costs a bit less than a whole new distributor. I changed the entire distributor, to be sure all the ignition components were new and would not fail again for a while.
Aug 06, 2012 | 1993 Honda Accord
My engel cools when set to max,but when it switches off it makes a noise as if it is trying to start again, only by turning the temperature control down and then turning it back again will she start.Where...
Feb 06, 2011 | Engel 43 Qt.Portable Freezer.
When I turn the engine off the main radiator fan keeps running and is draining the battery. Why?
well the electric fan will turn on and off at any time. when you stop your vehicle and the fan continues to run what is happening is the temp sensor says the motor is still too hot and it needs more cooling. now as it reaches the cooling temp it is also suppose to shut it down. have the sensors checked.
Jan 11, 2011 | 2000 Jeep Grand Cherokee
With my thermostat on auto and on heat, and the furnace turns on, the fan will not turn on with it. If I switch the fan to on it will run after I repeat back and forth from auto to fan on several times...
Well, here is the deal: unless you rewired from two wire to multiple (usually 4 to 10 wires) wires, the fan cannot be controlled from the thermostat, even though the thermostat indicates that it can > it is a physical wiring and fan administration issue.
Unless you have a newer furnace, the fan is controlled by plenum temp. Works like this: burner turns on, no fan until the plenum temp reaches set temp,....then burner off, and fan keeps running until pelnum temp drops, and often the fan may kick on a few more times as this temp depletes.
Oct 03, 2010 | Honeywell Electronic Programmable...
Heat will not turn off.Removed thermostat wile
Hello
Could be a stuck control relay,Tsat completes a circut for this relay to engage,once relay contacts are closed heater will start.and stay on until you reach temp.
once temp is reached relay will open and heat will shut down.
By disconnecting all power to heater your forceing relay to open.or simulating a satisfied temp.
I would have a service tech look at your control relay and t stat.
Jan 28, 2010 | Goodman Heating & Cooling
Servis frost free fridge freezer makin crackin noise afew tyms a day
this is not unusual on any make. the cracking noise is the cabinet creaking with change in temperatue. don't worry about it
Oct 18, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Engel MT-35F-U1 34 Qt Portable Refrigerator & Freezer Logo
35 people viewed this question
Top Engel Refrigerators Experts
Jaime Hernandez
christian nielsen
cwradio73
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
