Question about Onda vi10 7" TFT Capacitive Screen Android 4.0 Tablet Computer Black
Onda V971 startup problem - Onda vi10 7" TFT Capacitive Screen Android 4.0 Tablet Computer Black
Dispaly problem
Check power settings and scrennsaver time.
Apr 07, 2014 | Santai Onda VX530LE 4.3 Inch Screen TV-Out...
Problem with V. 811 Onda Tablet
hi Akram.
this is all i could find out.
When the tablet is turned off, keep home button pressed.
Now turn on tablet while still holding the home button.
When white android figure appears, release both buttons.
You will get into recovery mode, you can select "restore factory settings" there.
Download the right firmware here: ONDA
Extract the content to the root of your sd card (since you cannot use your tablet, i suggest using a cardreader + pc or another tablet? or try to hook your tablet to the pc and hope it recognizes it)
There should be 5-6 files now on your SD card.
Turn on tablet while holding home button, untill white android figure appears then release.
It should update your firmware now...
or you could try this link on how to do a hard reset.
but do so at your own risk.
Onda V811 hard reset format factory mod recovery rom install ..
or try this link for more info.
hard reset tablet onda v811 Google Search
or this one.
811 Onda Tablet logo screen white Google Search
Nov 27, 2017 | Tablets & eReaders
My tablet onda V971 stuck at android logo at startup
HI. My name is Hammad. I was facing same problem. I cnnect usb cable to my laptop and other end to my onda v971 tablet. Then I power it up. It starts in first try without any problem. Try it
Nov 05, 2012 | Onda vi10 7" TFT Capacitive Screen Android...
I need an english onda VX570 User Manual
The Polaroid pmp500-4 HD Touch is the pretty close to the same as the ONDA and the manual located here could meet your needs
http://www.southerntelecom.com/polariodsupport/downloads/PMP500.pdf
Nov 07, 2011 | Audio Players & Recorders
Onda & ACER Connectivity issues
Problem is considered as "solved" as both ONDA & Vodafone.gr supports CONFIRMED in written that specific brand new and capable for even 10 mbps maximum speed usb 3g mobile modem CANNOT SURVIVE IN A ACER IN GENERAL and no existing microsoft or ACER patch solves that !
So vodafone is thinking now with what (and compatible to new ACER's) will CHANGE my ONDA !
So consider that solved !
THO BE AWARE THAT NO FIX SOLUTION EXIST ON SUCH A CASE
Oct 14, 2009 | Acer Aspire 3000 Notebook
How to use my onda vx858 mp4
If it's an Onda, then it's a custom build. I would see if you can get Windows Media Player to recognize it, and then sync files to your device that way. If not, just connect it to PC, double-click my computer, and double-click the Onda device. If it has a msuic folder, just drage your files to there. I would only drag mp3-formatted files to this player - since it is a custom build, there are no specs. Here is a link to the company website:
http://www.ondacorp.com/products_custom.html
Custom builds are not for rookies. You are THE expert in this product simply because you own it.
Sep 07, 2008 | Audio Players & Recorders
Onda vx767 mp4
OK, so you plugged the car charger for the FM transmitter into your Onda player headphone jack perhaps? Yeah, that could cause problems. On the one hand, this player needs to be replaced. You can e-mail Onda by going to the crappy US version of the website - they seem small and they seem like custom-builders. On the other hand, they may have an inferior web page because there are no US contacts at all - they may all be Chinese. Most products have a warranty, but even better, most stores have a return policy. A US-based repair service would cost a minimum of $279.00, and that is assuming that they would be able to fix it (which they probably can't).
If you have already tried a reset suggested by the manual, and there is no "recovery" method listed in the manual (which would just be a version of what I gave you before, except they may suggest a button other than volume +), then I would go ahead and return it - sorry.
Jun 12, 2008 | Audio Players & Recorders
Onda vi10 7" TFT Capacitive Screen Android 4.0 Tablet Computer Black Logo
171 people viewed this question
Top Onda Computers & Internet Experts
David Payne
David Payne
Are you an Onda Computer and Internet Expert? Answer questions, earn points and help others
