Question about Kenmore Kitchen Ranges
Oven has power but none of the burners on top or the bake or broil elements work
Model # 665.4579350. Power was surging on and off in the house for about an hour during a storm. Now, none of the top burners or oven elements will turn on. Just hear a clicking sound when I try to turn on the bake or broil elements. The oven has power though. (clock works, digital display works.)
  • mike gedroc Oct 28, 2012
    Thanks for the suggestion Thomas. //turned the breaker off for about three minutes and when I turned it back on I got the PF code, but still, nothing worked.
  • mike gedroc Oct 30, 2012
    Thanks again for the help. The problem was with the power lines coming into the house due to hurricane Sandy. Powe Co. came out tonight and removed the trees and fixed the power lines. Thanks to FPL as well.
  • 14,338 Answers
Go to breaker panel,turn off and wait a minute and turn on,may reset it.
Posted on Oct 28, 2012
docjohn174
  • 943 Answers
SOURCE: Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Posted on Sep 28, 2008
  • 26 Answers
SOURCE: Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
docjohn174
  • 943 Answers
SOURCE: Whirlpool range
hi the part # is AP 3008287 at Appliance parts pros.com infinite switch controls the top burners thanks the appliance doc
Posted on Sep 29, 2008
  • 109 Answers
SOURCE: Kenmore Oven - neither the bake or broil work, dial doesn't light
these elements burn out over time so chk. that out
Posted on Aug 23, 2009
SOURCE: Loud pop when I was baking with the oven on Convection bake
Did you resolve the problem with your stove.
Mine just did the same thing.
Posted on May 05, 2010
Why isn't my oven working? After changing bake element and thermostat
Either the bottom element is defective or the wiring to it is not hooked up properly so it gets power and does its job ala the top element.
OR the control that is responsible for having power delivered to both elements is only sending power to the top element. Make sure you are not using the broil setting since that only activates the top burner.
Feb 03, 2016 | Ovens
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Nov 22, 2014 | GE Profile JT952 Electric Double Oven
Tappan oven won't come on
follow this steps and fix it.God bless you
Power Cord
If the power cord fails you still may have the control portion working but no bake or some other functions. The reason this happens is the oven takes in 220 volts then splits that to 2 110 lines. Some for the controls, lights, bake and broils elements, and stove top. If your cord has failed on one half of the 220 line or the terminal block were the wires are connected may have melted or failed. You may need to replace the power cord and terminal block.
Heating Element
This is usually the problem. To Check this first turn oven on to a bake setting,say @350, check to see if element glows, if not shut oven off. If it is warm but does not glow it is getting power and the elements need to replaces. If it does not get warm remove the element and check to see if it is getting power if it does get power replace the element. No power it is the main control that has failed. Check element for continuity, if none replace.
Temperature Sensor
This is a long thin tube like part located usually in the top rear of the oven. It is held in by 2 screws. This can easily be removed by removing the 2 screws and carefully pulling it out. Usually there will be wires connected and insulation so you will need to work it out. Then unplug the connector and check with an ohmeter. It Should have around 1000-1100 ohms if not replace sensor. Some will have a thin capillary tube attached in this case the problem will be in the control attached to this tube.
Main Control
This can cause your oven not to heat. Sometimes the oven relay gets burned out, when this happens the control is unable to send power to the bake element. There will usually be separate relays for bake and broil if you have 2 different elements. If your heating element gets no power replace the control. If your control does not respond at all check to if youhave power entering the control. If you do and it does not respond replace control board No power to the control Check or replace the power cord .
Jul 29, 2013 | Tappan Kitchen Ranges
Baking & broiling elements won't heat after baking element burned out and was replaced.
the surge from the original element burning out has destroyed the control board if you can't hear the relays on the board clicking when you power up the elements bake or broil then its either the low voltage side of the board,if you hear clicking then the relays are working but the contacts are burned out and can't pass the current to heat the oven or briol elements
Jan 04, 2013 | Jenn-Air Ovens
Oven and elements not working,
the oven and burner relay that supplies power to the bake/broil/top surface units is bad or the signal to latch this relay is missing from the control panel
Jun 03, 2012 | Moffat Ovens
Frigidaire DGES388DS2 electric single oven
Did you reset the house circuit breaker that supplies power to the oven?
Apr 24, 2012 | Frigidaire Ovens
My oven wouldn't bake or bbroil but all burners
First suspect is the thermal fuse that feeds the bake and broil elements. It is located on the back oven wall or sometimes the top.
Jun 27, 2010 | Frigidaire FEF312 Electric Kitchen Range
TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Sep 28, 2008 | Whirlpool GY396 Electric Kitchen Range
Kitchen Ranges Logo
155 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
