Question about Garden
What type oil does black & decker pressure washer pw1300 take and how to tell oil level
What type of oil does it take, how much and how do you check level
dontbother10
  • 2220 Answers
SOURCE: OIL CAP REQUIRED FOR BLACK & DECKER GK1630T
Black & Decker GK1630T Type 1 Chainsaw Spare Parts
http://www.mtmc.co.uk/prodtype.asp?PT_ID=12708111
Item 147, only someone that can see the item in question can determine whether just the cap or the repair kit is needed. If in doubt order the kit, if not needed it will be on hand when it is.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 20, 2010
#1 Taper
  • 1040 Answers
SOURCE: I need to download a
This link may provide the help you need, There is a phone # that you can call on this site:
www.ereplacementparts.com/black-and-decker-pw1600-1600-psi-pressure-washer-parts-c-4167_9499_9560.htm
I wasn't able to find it.They may know where to link you to to get a download of your manual. I wasn't able to find it.
Jim
Posted on Sep 23, 2010
  • 127 Answers
SOURCE: what type of oil does my black and decker chainsaw
You can use SAE 30 weight motor oil or bar and chain oil. Press the bulb on the resevoir cap 2x before each cut making sure the saw is pointed down and to the right to let the gravity feed oiling system work properly.
Posted on Jan 05, 2011
kel1guy2002
  • 3740 Answers
SOURCE: Black and Decker PW1300 Type
Hi and welcome to FixYa, I am Kelly.
Not sure if anyone has responded to you but.... This is a symptom of the unloader / bypass valve sticking. The unloader bypass valve is located on the output side of the pump either under a brass cap or an extended stem with a knob on it for pressure adjustment.
Try this...
- Lay the unit down so that the water supply connection fitting is facing up. Leave the high pressure hose connected with wand. (Power to the unit)
  • First inspect the inlet screen for debris.
  • Next pour about 3 oz of regular automotive engine oil in the water supply fitting. Take your time... do momentary on / off cycles of the switch (bump the pump.... on / off) You are trying to get oil to the outlet fitting (No more than 1 second on off cycles)
  • Check for evidence of oil at outlet fitting
  • Leave it set overnight with oil in the unit. (Water supply and outlet fittings up.)
NEXT DAY.... add 2 oz more oil and connect water supply. (PURGE HOSE of ALL air before connecting)
  • Do not pull wand trigger yet
  • Cycle unit on and off about 10 times slowly... don't ruin the switch then let sit 10 mins.
  • Turn unit on without triggering and let run for about 2 minutes.
  • NEXT STEP be advised your going to shoot out OIL
  • Begin triggering the wand on 1 sec off 3 seconds for at least 2 minutes (your trying to get the unloader bypass spring / plunger and seals to start moving inside the pump high pressure area.)
  • If your wand has a soap application function make sure the wand is in the HIGH PRESSURE position. (Closed CCW)
This procedure does not always work but, I have revived about 70 % of the pressure washers I worked on by just doing these steps. If the procedure does not work... you will have to disassemble the unloader / bypass valve by pulling it out of the housing and then cleaning up the inside of the pump housing and wiping the seals clean. IMPORTANT STEP here: Before inserting the valve back into the pump housing you MUST lubricate it with #105 white grease. Housing and unloader / bypass valve parts. (white grease in small tubes at any automotive parts source.
Thanks for choosing FixYa,
Kelly
Posted on Feb 26, 2011
  • 2239 Answers
The chain lubrication should be a non fling chain oil, the non fling addative helps to keep the oil on the bottom of the bar where most cutting is done, rathere than spraying off the end of the bar.
Posted on Sep 18, 2011
I have a black and decker rotary hammer drill i can only read 3 numbers of the model it is 045 but its the last three sn number 0481121 under pat 3309541 need parts manuel for
Your one sounds like this one
http://www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-c-4167_7879_17406.html
However there are three variants on this page.
http://www.ereplacementparts.com/black-and-decker-hammer-drill-parts-c-4167_7879.html
Black and Decker Hammer Drill Parts ' Great Selection ' Great Prices ...
  1. Cached
  2. Similar
Black and Decker 22738 Type 1 1/2-Inch Hammer Drill Parts. 22738 Type 1 Black ... Black and Decker 27106 Type 1 3/4 Rotary Hammer Parts. 27106 Type 1 ...
Black and Decker 5045 Type 100 Rotary Hammer Parts
www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-...
  1. Cached
  2. Similar
Black and Decker 5045 Type 100 Rotary Hammer Parts .... Drill Parts Hammer Drill Parts Rotary Hammer Parts. Search within model. SEARCH. Discuss ' Repair ...
Black and Decker Hammer Drill Parts & Repair Help ' Fix.com
https://www.fix.com/parts/power-tool/drill/hammer-drill/black-and-decker/
  1. Cached
Shop for Black and Decker Hammer Drill parts today. Find genuine replacement ... (Type 100). Variable Speed Reversible Rotary Hammer · 5014. (Type 100).
Black and Decker Parts - Tool Replacement Parts ' Tool Parts Direct
www.toolpartsdirect.com/brands/blackdecker.html
  1. Cached
  2. Similar
Black and Decker Drill & Driver-Drill Parts · Black and Decker Hammer Drill Parts ... Black and Decker Rotary Hammer Parts Model Schematics and Tool Parts ...
Black and Decker 5043K_TYPE_3 ROTARY HAMMER KIT Parts ' Tool ...
www.toolpartsdirect.com/blackdecker-5043k-type-3-rotary-hammer-kit.html
  1. Cached
Find the Black and Decker blackdecker_5043K_TYPE_3 ROTARY HAMMER KIT parts you need at Tool Parts Direct. Shop thousands of Black and Decker ...
Black and Decker Rotary Hammer Parts ' Tool Parts Direct
www.toolpartsdirect.com/hammer/rotary-hammer/blackdecker.html
  1. Cached
Replacement Black and Decker Rotary Hammer Parts online. Tool Parts Direct has thousands of Rotary Hammer Parts to fix Black and Decker tools. Shop by ...
www.toolpartsdirect.com/hammer/rotary-hammer.html
  1. Cached
  2. Similar
Tool Parts Direct carries the largest inventory of replacement Rotary Hammer Parts for thousands of make and models. Buy Rotary Hammer Parts online for all of ...
Black & Decker Replacement Parts - 1800ToolRepair.com
https://www.1800toolrepair.com/tool-repair-parts/black-decker
  1. Cached
Black & Decker replacement parts for all Black & Decker tools. ... Black & Decker Cordless Circular Saw Parts ... Black & Decker Electric Hammer Drill Parts.
Beyond Parts - Black & Decker ServiceNet
servicenet.blackanddecker.com/Parts/Detail/29096
  1. Cached
  2. Similar
Available, Add Parts to Cart ... Model #, Model Description, Parts Diagram. 5041K Type 1 · MACHO I ROT HAM KIT · 5042-09 Type 1 · HD ROTARY HAMMER.
black and decker rotary hammer drill Google Search
Dec 25, 2016 | Rotary Drills
Need manual B & D power washer for concrete siding etc moidel PW1300 type 1 about 10 years old or older
The Black & Decker power tools are supported at http://servicenet.blackanddecker.com/Home . If you search for the PW1300, you'll see the oldest model (PW1300) listed first. The PW1300 compact pressure washer support page is http://servicenet.blackanddecker.com/Products/Detail/PW1300 . Look on the right hand side for the link to the instruction manual. The direct link to the manual is http://documents.dewalt.com/documents/English/Instruction%20Manual/598111-01,PW1300.pdf
I hope this helps.
Jun 21, 2016 | Washing Machines
I have a black and Decker pressure cleaner pw1500. Oil needs replacing in the motor pump. How much oil needs to be replaced and what type of oil?
What makes you think the oil needs replacing. These pumps typically are sealed and have no servicing requirements. You one uses a 3 piston wobble pump which I suspect will have a grease packed bearing in it. (I haven't checked your one, but this is common in these pumps)
May 20, 2016 | Garden
My motor brushes at end of life for a Black and Decker electric leaf blower. Where can I get them? Black and Decker leaf hog, model BV400 type 4, Cinderson 90510850 motor. Black and Decker site no help...
Try Platt Electrical supply - 800-257-5288 (Platt.com) BLACK & DECKER #89754-01 REPLACEMENT BRUSH. It seems the entire motor head was manufactured by DeWalt and is now obsolete. I don't know if these brushes will fit, but someone there may help.
Good Luck!
Aug 31, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
The motor wont start
This could be a few different things. 1. Check oil level, if your machine is equipped with a low oil sensor the engine will not start if oil is low. 2. Check the spark plug, remove it and place it against something metal and crank the engine over while looking at the spark plug to see if you have spark. Don't hold the plug because you will get a shock. 3. Check the carburetor, remove and clean. Check the air filter, make sure its clean. If these steps don't work let me know.
Jul 23, 2011 | Black & Decker Garden
Dont get correct pressure. What type of oil do i
A loss of pressure on this type of washer is normally caused by failing water seals and check valves in the pump. You will need to replace both of these using a pump rebuild kit that will be available by contacting the manufacturer of your machine. The pump oil used will be 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Feb 28, 2011 | Black & Decker 1700 PSI Electric Pressure...
I need to download a Black & Decker manual for a power washer- PW 1600
Jim
Sep 23, 2010 | Garden
I have a Black & decker-pressure washer and the problem is the hose was broken. How can i fix or where i can buy a new one?
duck tape if it's completely dry and extremely tight. Mabey epoxy but that might not be strong enough. I would just get a new hose at blackanddecker . com or ebay
Black & Decker - Dewalt DP352 Pressure Washer 4000 Psi Hose
$71.99 new - TheHardwareCity.com
Jun 27, 2010 | Garden
I have a black & decker pressure washer model PW1600 and its not getting the high pressure anymore. any ideas
check the unloader valve (pressure relief valve) probably need to replace the o-ring. it should be on the side of the pump and have a large spring. just unscrew and replace.
hope this helps.
Sep 12, 2009 | Black & Decker BDP2600 Gas Powered...
Honda GX340 11 Hp ..Runs fine until it gets hot , Cuts off and
FIRST...check the engine oil level. Some Honda engines have an oil sensor that shuts off the spark if the oil is low. This would also explain it shutting down when it get hot. Check the manual to see how to tell if the oil level is correct. Also, the oil should be brown and transparent, not black. It may need changing. Post again if this doesn't help :-)
Jun 01, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
