Question about Garmin eTrex GPS Receiver
Accident - Create Bad connection on starting
Hi. Last night, maybe the last night to me to geocaching :( The bag where the GPS and the material fo geocaching, had an accident. It fault down to the ground. And the GPS now does not started. I click the button, it appears in a one or two seconds the windows start and then it shut down. The GPS already have more then 3 years, so guaranty is off. Question: to make sure everything is good inside, how to do it? And also how to open it?
SOURCE: the gps does not boot
Use with caution: This will delete your user data on the unit.
Try a reset:
  • Hold QUIT pressed when turning unit ON (will delete waypoints, routes and tracklogs)
(This worked for me when I had a similar problem.)
You could try a master reset;
  • Hold Zoom-OUT + QUIT + NAV and power ON. Hold keys for 10-12 seconds.
  • You lose all almanac and temperature compensation tables (it
  • reconstructs itself but takes time - several hours)
  • Be patient - it will take HOURS for the unit to recover
Fair warning: I have not personally tried the master reset.
Posted on Dec 16, 2007
SOURCE: lost satellite reception
I have the same problem, and so far the only solution is patience. If you are in a cutting, or between tall buildings, and the satellites are low down on the horizon, then it seems reasonable that reception will be between poor and zero. But in wide open spaces mine too sometimes loses the signal. Hang in there, and contact is restored.
LocoTorque
Posted on Aug 15, 2008
SOURCE: connection problem maybe ? im not sure
make sure that you have the garmin driver downloaded onto your pc
Posted on Dec 07, 2008
SOURCE: GARMIN PROBLEMS
Had the same problem. Called Support. They answered immediately - a HUMAN, no recording, speaking American English - walked me through some tests, diagnosed a defective battery, gave me info on returning unit, I had it back in a flash. This is a classy outfit, and the Garmin C330 is a superb piece of equipment, has been flawless since.
Call 1-800-800-1020
Posted on Mar 10, 2009
SOURCE: My Garmin NUVI 200W cannot switch on/power up.
i had same problem so i did reset
this how u do this
http://www.garmin.com/garmin/cms/site/us/lang/en/searchsupport
Posted on Apr 15, 2009
Geocache list doesn't show on gps
Basecamp is displaying the contents of the gpx file. This means you've correctly imported the gpx file into Basecamp.
A copy of the gpx file needs to be separately saved into the "GARMIN/GPX" folder on your GPS via USB and your computer. (Note: I believe your Oregon has the same file structure as my Garmin Montana).
On startup, your GPS will read the new data and display the caches.
Mar 27, 2013 | Garmin Oregon 450 Handheld GPS Receiver
What is Geocaching?
Geocaching is a real-world, outdoor sporting activity using GPS-enabled devices. Participants navigate to a specific set of GPS coordinates and then attempt to hide and seek the geocache (container) hidden at that location (anywhere in the world).
Jan 14, 2013 | Sport & Outdoor - Others
Poi software on win7 doesn't find the gps 60
If you're using a serial connection, make sure you have the proper port selected. Otherwise use a USB connection.
If your unit has a removeable memory card, save your POIs to that before inserting the card.
If you're trying to load geocaches, there is a free program that really helkp with that. Download GSAK (Geocache Swiss Army Knife) http://www.gsak.net/.. It works great.
Feb 20, 2011 | Garmin GPSMAP 60 GPS Receiver
My location is stuck at last place visited. It got mailed then wont leave the last place.
Are you talking about the Last Position or Location..... The Last Position is where the GPS came off the cradle or holder... once you connect it to a cigarette lighter adapter and remove it, it retains the Last Position... to create the Last Position when plug into lighter, remove it from Holder /Cradle then turn off unit... this will create last position... to find it go to your Favorites it will guide you to your car
This feature is awesome if you park your car somewhere, you can always find it by going to your favorites ... last position
Nov 04, 2010 | Garmin Nuvi 350 Car GPS Receiver
Has worked fine, went to turn it on and now alls I have is white blank screen. Please is there a solution to this or ?????
Somehow in your last activity you created a trail, waypoint, geocache or route that corrupted the software in the internal system.
Sep 01, 2010 | Magellan Triton 400 Handheld GPS Receiver
When pulling up geocache map
This is a common problem when you enter geocaches or Waypoints in which you DID NOT SCRUB the html code. Start Deleting Geocaches until you find the bad one and all will return to normal.
Also investigate a program called GSAK and use its stripper before you load the geocaches.
Jun 06, 2010 | Magellan Triton 400 Handheld GPS Receiver
I want to go Geocaching and I want to know how to enter Lat/Long or update my equipment to this?
well i'm a great geocacher and i love to help people with the GPS'rs
so you found the guy :))))
It may not be the easiest approach, but you could create a custom POI file for your Geocache locations and then load them into your c330 using POI Loader.
If you're a premium member on Geocaching.com, it's my understanding that you can download locations in GPX format. POI Loader is supposed to read GPX files, but I haven't tried it with geocache locations yet.
Do you have a geocaching account that can download GPX files?
Someone told me that you can use Long/Lat with Google Earth, and you can save Google Earth POI's in GARMIN .cvs format, to use in the PIO Loader.
May 03, 2009 | Garmin StreetPilot C330 GPS Receiver
this how u do this
Apr 07, 2009 | Garmin nuvi 200W GPS Receiver
My gps was working last night and now it jsut wont turn on.
Hi, Has it got wet or frozen overnight? How old is the battery? Can you plug it in and try after an hour or so of charging?
Most likley your battery is dead.
Jan 09, 2009 | Garmin nuvi 200W GPS Receiver
Garmin eTrex GPS Receiver Logo
37 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
