Question about Lifetime Toshiba Satellite L305DS5974 Replacement Laptop Power AC Adapter Charger (91812013470)
My laptop gets way to hot and turns off.
It only takes about 3 mins from the time I turn it on before it over heats. Why could this be and how would I fix it?
  • Lifetime Master
  • 27,725 Answers
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
Posted on Oct 29, 2012
Model 39A gets too hot too fast
That model has a thermostat (also called a high limit) that is set at 450F. it should produce a popping cycle of 3 mins, and yes will burn popcorn if you don't dump it fairly quickly.
The speed it heats cannot be too fast, there is only so many watts in the heat element. it may go to hot, but never to fast.
The best way to test temp is time the 2nd popping cycle with a stop watch. the second batch should be 3 mins +/- 30 seconds. if it is 4 mins it is too cold. a 2 min popping cycle is to hot.
A popper that is too cold is also popping poor quality popcorn, higher amount of unpopped kernels, and small chewy popcorn.
Measure carfully when doing time test popping. That model is 2oz oil, 6oz popcorn, and 1 tsp salt. Start timing when you put ingredients in, and stop when you dump it. The kettle must be hot, that is why you time the 2nd batch.
May 20, 2013 | Star 39 JetStar Popcorn Maker
I have dell inspiron mini 1012 , when i turned it on booting it works then after 10 min it freeze, so i turned it off and tried to power on it worked but it didn't find the operating system, i tri
It sounds like your system might be running hot. Do you hear the fan running? If so it will turn on after it has cooled off, but once it gets hot it will turn off. If you immediately try to turn it back on, it won't work until the system has cooled off.
Laptops overheat because of the following problems:
1. Dust has clogged the Fans, Vents, CPU & Heat Sink Area
2. The FAN has stopped working
3. The Thermal Paste around the CPU and HeatSink has either dried up or is too thin to keep the system cool.
Try a can of compressed air and blow out the areas you can get to around the vents. You'll have to take the laptop apart to get to the Fan, CPU and Heatsink
Mar 30, 2012 | Dell Inspiron Mini 1012 Netbook...
I have a 99 ford expedition with heating problems. It will heat in the middle section for about 15 seconds then you can feel it go to cold air. We have changed the blend door actuator, thermostat, and...
Check if there is a vacumn powered valve in the heater hoses, if there is the vacumn hose may be faulty [ broken or crimped.] or the valve is faulty. good luck.
Jan 03, 2011 | 1999 Ford Expedition
Takes three cycles to dry towels, displays 45 min. turns off within 30 min. still not dry
2 possible reasons, either the towels have not been spun at a high enough speed and are too wet, or the dryer is not getting hot enough because it is not switched to a high enough heat setting or there is a partial element or thermostat or humidity sensor failure. You should spin your towels as fast as you can, 1000 MINIMUM but 1400 or more is better. Did it ever work? Is it a new drier? Is it getting hot? 45 mins is a short time anyway to dry a full load of towels.
Jan 03, 2011 | Whirlpool Dryers
My Kenmore gas oven sporadically takes forever (30+ min. to heat up to 350 degrees). Sometimes it works fine, & other times it takes at least 1/2 an hour. Also, I periodically smell natural gas when I...
Sounds like a weak ignitor. If it doesn't get hot enough to allow the proper amperage through to the gas valve, you will have this symptom.
Jul 25, 2009 | Kitchen Ranges
Hot water is cutting out after 2 - 3 minutes whilst showering
check the screen on the cold water intake on the cold side,, you might have to flush the system out, and do you have the shower head water restricter in, if not you may be using to much hot water,,, how many other hot water fixtures are running at the same time? try running just the shower,,,if this is a tank water heater the dip tube could be bad that is on the cold side it takes the cold water to the bottom of the tank and forces the hot water out,, if you ar only getting a couple of min of hot water and the dip tube is bad it is not going to the bottom but just at the top and not getting all the hot water you will need a plumber
Mar 21, 2009 | Water Heaters
Laptop (Toshiba Satelite A60) keeps turning off
Is it turning off by itself after being on for 20min... each time? I.e. is it consistently turning itself off after the same amount of run time? Check the bottom of the laptop... how hot is it? Might be an over-heating problem. Some freeware (MobileMeter) might help you monitor temperatures and see if it is a problem
MobileMeter
http://www.softpedia.com/get/System/System-Info/MobileMeter.shtml
Some excellent heat management information here:
http://www.technowledgebase.com/2007/07/03/monitoring-your-laptops-temperature/
Jul 05, 2008 | Toshiba Satellite A60 Notebook
No hot water help
have a ariston euro combi boiler ,the problem to get hot water i have to turn the heating on to get hot water. but now it only run for a few min then run cold please help
Feb 18, 2008 | Washing Machines
Lifetime Toshiba Satellite L305DS5974 Replacement Laptop Power AC Adapter Charger (91812013470) Logo
Top Lifetime Computers & Internet Experts
Corey Bartlett
Level 1 Expert
Paul Bade
GG TECHNOLOGIES
Are you a Lifetime Computer and Internet Expert? Answer questions, earn points and help others
