Question about Canon PIXMA iP90 Mobile Printer
Rows of print missing
Printer was working fine this morning, then suddenly it started missing sections of print, the bottom half of a row missing in the same places each time i print
  • richard mann May 14, 2007
    it worked for the first print after then the black stopped printing altogether and won't restart
    Genius:
  • 2,985 Answers
Clogged heads. Does this model have the heads the cartrige? If so take the cartridge out damp some tissue with mild detergant water place it in a dish and stand the cartrdge on it a while. Make sure the side contact are clean and undamaged.- re insert- give it a go to go further try www.fixyourprinter.com
Posted on May 14, 2007
  • john ash
    john ash May 14, 2007
    that web address should be
    www.fixyourownprinter.com
  • john ash
    john ash May 17, 2007
    New cartridge or heads- depending on model
I think the printhead needs replacement
It sounds as if the print head needs cleaning. Follow the instructions in section 10.1 of your manuaI If you don't have a manual you can get it here - http://www.toshibaprinters.com/technical_information/technical%20info.htm. If the cleaning doesn't work you will need to replace the head.
Oct 29, 2009 | Toshiba TEC B-572 Printer
I am working with 2 Toshiba SX8 thermal printers. The text recently started shifting downwards for no aparent reason on both printers. Jobs that I have printed fine the last couple weeks have sudenly...
several reasons may cause this problem.
-On Tec printers, the height of the labels must be the most precise possible. You must include the gap height in the command
{D0350,1000,0320|} for la label size 100 mm and 32 mm high and 3 mm interval. If this information is missing, the printer may work correctly for some time and suddenly you'll have your phenomenon.
- You may have a label stuck under the sensor.
- You may need to recallibate your sensors.
- the correct sensor is not selected
Sep 21, 2009 | Toshiba TEC B-472 Thermal Label Printer
Works 8 Word Process set Repeating Page Column Headers
Choosing the single cell below rows you want to repeat on each page and to the right of the column you want to repeat and then freezing that cell will cause those rows and that column to repeat on each page as you print. works fine on preview. However I still can't get the machine to print.
Ralph R. McKibben.
Mar 21, 2009 | Microsoft Works 8.0 for PC
Gap in printing
the color ink cartridge has dried. replace it.
Nov 29, 2008 | Dell 924 All-in-One InkJet Printer
Officejet 7310 misses lines while printing, copying, etc
Turn off the unit.
Disconnect the Power Cable.
Open the rear access door.
Clean the rubber rollers with soft dampened clean clothes.
Let it dry for sometime.
Turn on the unit and see if it works.
If it doesn't work, your printer might have to be service.
Apr 10, 2008 | HP OfficeJet 7310 All-In-One InkJet...
I have a HP Photosmart 8450 printer. I would like to know how to set it to print 8.5 x 8.5 photos
Hello SLeolioness
Please, go HERE for HP's support page for your printer.
HERE you will find the manuals that are available for your printer.
You can change the photo sizes on the front control panel. Please, go HERE and scroll down to the HELP section. [ Photo sizes ] is on the 3rd row.
I think that may be it because if you go further down to the PREFERENCES section, you'll see an option there for printing Passport Photos.
While still in preferences, look at the 5th row from the bottom. There you'll see how the printer can automatically detect the paper size.
In the 4th row from the bottom, it explains how a print preview option can be set. In this way, it will allow you to preview the photo(s) your about to print in the selected layout. (Not an option on all printers, however.)
So, it would appear that by using the proper combination of tray size, paper, and menu selection (for the photo size) you will be able to print to 8.5 x 8.5 photos.
* If the information I provided you w/
* resolved your problem or lead you
* to a resolution for your problem or
* an answer to your question, then, a
* "FixYa" rating would be most
* appreciated. @:)
* (You can assign the same rating to
* more than one expert who participated
* in solving your problem.)
* It is best to wait until the problem
* has been resolved b4 rating the experts'
* solution(s). Once you enter a rating,
* the problem will be closed and we will
* not be able to continue to assist you.
* Very often it will take more than one
* exchange of information between you
* and an expert in order to resolve your
* problem. If a proposed solution doesn't
* work for you, don't rate it yet. Instead,
* post back here letting us know and we'll
* continue to work w/ you until we find a
* solution that does work for you.
* Thank you
* BJ @:)
Apr 09, 2008 | Office Equipment & Supplies
Bottom Margin Cut Off! :(
Your printer prints Letter format. Set the printer to A4 standard printing. As I remeber this tab is in the printer in the country/region section. Select your language and as a country select the Cech Rep. Is one of the countryes that uses A4 standard
Nov 15, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Canon PIXMA iP90 Mobile Printer Logo
old marine
old marine
