Question about Mercedes-Benz Mercedes Benz 3176948 Mc3520 Mc3010 Mc3330 Mc3110 Mc3198
Mc3110 cd changer doesn't read disk
Keeps saying magazine empyty
SOURCE: 1999 clk 320 Cd changer says Magazine empty and
Same problem in my 2000 C280. Through dumb luck I was able to correct it in the way that I later found described in the Nov 13, 2005 post here: http://www.benzforum.com/forum/showthread.php?t=7716. No guarantee that will help you, but it did solve it for me. Good luck.
Posted on Mar 23, 2009
jasperoni
  • 203 Answers
SOURCE: cd changer wont play
All radio accesories are on what is called a d2b ring. This ring consists of your c.d. player,telephone t.r.u. and voice activation module. On some vehicles the factory amplifier and tele aide modules are on this loop. If you have aphone see if it works. I do not think your amp is part of this ring although benz started incorporating the amp. in 2000 model years. The way this system works is that the head unit sends a wake up signal and verifies that these components work. Each components is in series and the last one in the loop sends the signal back to the head unit. It is easy to determine if you have a problem in your d2b ring if none of these components work. Although the head unit reads no changer I would make sure all of the c.d.s are installed correctly. You can also try and remove the unit and there should be areset button you can push in with a ball point pen at the base of the unit.
Posted on Jun 28, 2009
SOURCE: cd magazine stuck in the cd changer in mercedeze e320
CD magazine stuck inside the changer in a 1999 E-320 Mercedes Benz.
Posted on Aug 23, 2010
  • 3 Answers
SOURCE: hi i have a mercades
you dont say if its standard fitted model hifi unit, i take it you have pulled the din plug out of changer unit and checked all the pins are there? push plug fully in, check head unit end too, if thats done i had one that needed resetting on head unit, another the disc unit had dodgy earth lead, they dont norm give up. saying that my dads gave up when he hit a spped hump to fast. tricky...
Posted on Jul 15, 2011
  • 10 Answers
SOURCE: CD Player will not eject the CD magazine
Disconnect Battery
  • As with any tasks on a Mercedes or other vehicle, when you are dealing with disconnecting and connecting electrical systems, you should always disconnect the negative battery terminal. This will ensure your safety and prevent you from getting an electric shock.
Dash Panel
  • Pry the dash panel from the dashboard. There are two levers on the sides of the Mercedes factory-installed CD changer. Pulling down on the levers will release the radio from the bracket in the dash. You will have to remove the wiring and the antenna cable from the back of the system.
Installation
  • You can replace it with a newer version of a CD changer or insert the same one, once it has been repaired. Slide the player into the installation sleeve of the stereo dock. Pay attention to where the wires were removed and connect the unit's wiring to the leads in the wiring harness adapter. Connect the antenna cable lead into the antenna detector. Snap on the dash panel to complete the removal and installation.
    Buy Custom Car Parts.
Posted on Jun 02, 2012
I got a vw golf 1.6 s yesterday n cd player keeps saying CHK MAGAZINE or no disc I've looked online n said something bout a changer but there is no changer any ideas what it could b what to do?
some cars use a cd magazine situated under a seat or in the boot. if the read out states check the magazine then there probably is one
talk with a service dealer to find the location if it has one.
May 05, 2015 | Car Audio & Video
Vw beetle cd player wont read
The player may need replacement, especially if you have used it for more than a few years
May 08, 2013 | Car Audio & Video
Magazine won't eject?
A CD may be stuck between the player unit and the magazine. You can try loading and unloading several times but in extreme cases it is necessary to do some disassembly to get at the disk
Oct 20, 2012 | Clarion Caa-355 6-Disc CD Magazine...
Cd changer cannot read cd
Its laser pickup assembly might be faulty. Click here to know more about how to clean it. Do it once, and if it do not help you, replace it with same type and number.
Sep 03, 2012 | Audio Players & Recorders
Jaguar 6 disc player not working
If you are getting power to the unit and you hear it clicking and making a sound when you hit the eject button, the this means that a CD is jammed in the track and while it was changing it got stuck and now causes you to see an ERROR message.
What you do is while hitting the eject button, wiggle the CD MAGAZINE up and down and side ways. This will cause the CD to fall into place and your magazine will pop out.
KennyV
Jun 22, 2012 | 2005 Jaguar X-Type
Cd won't go in the changer.
you might want to try replacing the cd magazine. and if that doesnt work it's going to come down to you replacing the cd changer itself
Feb 16, 2010 | Car Audio & Video
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CDC-3 magazine will not eject nor play, error on receiver indicates magazine error
1998 porchea boxter cdc-3 cd changer, The cd changer keeps on changing tracks as if their are no cd's in the changer. keeps going from 1 to 6 and then changes to radio.
May 19, 2009 | Becker Car Audio & Video
Error message appears when magazine is put into changer
why doesn't my cd changer reads. it keeps saying no magazine, when i insert it in. when i hit the eject button it ejects it out but wont read it or the cds why???
Jul 26, 2008 | Car Audio & Video
Mercedes-Benz Mercedes Benz 3176948 Mc3520 Mc3010 Mc3330 Mc3110 Mc3198 Logo
53 people viewed this question
Top Mercedes-Benz Car Audio & Video Experts
Tom Chichester
vince
rugby prop
Are you a Mercedes-Benz Car Audio and Video Expert? Answer questions, earn points and help others
