Question about Sewing Machines
Feed dog on Rimoldi 327 1CD wont feed after I pushed in the button in lower front of the machine and turned the flywheel _ I thought this was how to change the width of the stitches but now it won'
Feed dog wont feed fabric
  • sylviaivie Nov 12, 2012
    Did you accidentally lower the feed dogs?
RickE1
  • 202 Answers
SOURCE: Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
Posted on Feb 07, 2009
sewinsnap
  • 135 Answers
SOURCE: I can't drop feed dog on my Husqvarna viking 230
It sounds like maybe you have it set up to make button holes.
Posted on Aug 14, 2010
drifterK
  • 4924 Answers
SOURCE: Husq.2000 Model 6010, Machine does
take a look that it has another button in the right down area that controls the feeding dog ..and for some machines is used for embroidery ....this button has to be in the middle to be working right ...it is usually posted under the one that controls the stitch length ...and it has some symbols with a stitch too..but it is in fact the step of the feeding dog ...Im not sure for your model ..but change the position of that button and see which one is the right one for to work ok ..In some position the feeding dog will not get high enough to touch the fabric and this is the reason that the feeding ahead will not work ..
Posted on Aug 25, 2010
  • 1456 Answers
SOURCE: My fabric wasn't moving so
Hello
Turn off the power. Remove the accessory compartment located in front of the machine, if applicable.
Open the hook cover that shields the bobbin area. Please note that you do not need to remove the bobbin case.
Locate the drop feed lever near the bobbin case. Some machines have the lever towards the back of the free arm. Press down on the lever and then move it to the next notch or position. The raised metal feed dogs should be visible through the openings on the needle plate. You may need to rotate the big balance wheel one rotation to engage the mechanism on some machine models. The metal teeth will then spring up.
Close the hook cover. Insert the accessory compartment, if applicable.
Turn on the power. Try test stitching a piece of fabric. The raised feed dogs should help guide the fabric under the presser foot.
Posted on Jul 12, 2011
SOURCE: Feed dog not pushing fabric
then the feeddogs need to be checked at a sewing machine shop to see
what wrong with the feeddogs
Posted on Apr 27, 2012
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
Feed dogs won't move
No info on the sewing machine make or model. It sounds like something is binding up, is bent, or is tangled in the machine. Look around the front and back of the sewing area for a switch to lower the feed dogs.
Good luck
Oct 05, 2012 | Sewing Machines
Feeding device (with "teeth") does not come up
Reengage the feed dogs by pushing the feed dog button AND manually turning the flywheel towards you through one stitch sequence, you should see them moving back above the needle plate after a stitch has been made.
Oct 10, 2011 | Husqvarna Viking 1
Machine will not move material under pressure foot. Thread get all bound up like tension my be too tight!
is stitch length setting correct, should be 2.5 for straight stitch. are feed dogs lowered for some reason? raise pressure foot and manually turn flywheel towards you while watching feed dogs. do they move up backwards and down? sounds like they are not feeding fabric through. check manual for how to raise and lower feeddogs if they appear to be down. sometimes its a button on base front or back of freearm. hope this helps out a little
Jun 06, 2011 | Sewing Machines
Elna Envision 8007 feed dogs dropped and can't get get them to go back up ...the switch doesn't make a difference. Had this problem before and thought it was fixed. This is the first time I needed to...
Have you actually starting stitching a seam after sliding the feed dog control back to normal position?
In most cases, the feed dogs don't magically pop up until the machine has moved through a stitch sequence.
Put a piece of fabric under the pressure foot, lower the pressure foot, then turn the flywheel towards you two or three turns or use the needle up, needle down control button to make a couple of stitches - this should get them back.
Apr 15, 2011 | Elna 8007
How do I raise the feed dog in my Elna 5000, a machine I recently inherited.
I have a 7000 manual and from memory the 7000 was released a year after the 5000 and very similar. Look at top middle image below, for feed dog release at back of the sewing free arm.
tally_girl_19.jpg At the back of the sewing free arm (remove the accessories tray) is a slide to lower the feed dogs, there is a little stub that you need to push to release it. Manual says "Drop the feed by pushing the slide (a), which is at the rear of the elevated sewing surface, to the left. To raise the feed dog again, press down the stud (b) and the feed dog will rise when you start sewing." You might need to wind the flywheel towards you half a turn to visually check they have come up.
Apr 12, 2011 | Elna Sewing Machines
How do I lower the feed dogs on my Husqvarna 2000 sewing machine please?
It's been a while since I have owned a series 2000 Husqvarna, but from memory there is a little white (?) button on the lower right-hand side - near the knob for stitch width - it has a notch on the underside. Push the button in, push it in a downward motion and the notch should catch on the edge of the hole and stay there (in other words the notch "disappears" inside the hole). The feed dogs will be lowered. To raise them, push in the button again and let it lift up and then outwards (you see the notch again). Turn the handwheel once and the feed dogs pop up.
Nov 09, 2010 | Husqvarna Designer I
Raise feed dog
I have a different model Viking with a feed dog button to the left of the power button. When it's pressed down, the feed dog stays in the "down" position. Press it again to bring the feed dog up.
May 19, 2010 | Husqvarna Viking 1
Feed dog
There is a black lever behind, above and to the right of the needle.
Aug 24, 2008 | Kenmore Sewing Machines
Feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Mar 18, 2008 | Sewing Machines
Sewing Machines Logo
44 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
