Sony Klv-32t550a Bravia Multi-system Lcd 32" Logo
Anonymous Posted on Oct 28, 2012
My LCD TV display continuously blinking and no sound appear.
When switched on, the TV work for few min...the display blinking continuously without sound appear.please help
I have Samsung ln46c600 turn on and stays on for about 2 min but after i unplug it for awhile and as soon as i do the standby light blinks 6 times can anyone help me the capacitors have been replaced
blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Why tv sharp lc-80le632u when its starts it appear this blinking error "Power supply error 2 D+3.3V error"
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
My lg 52ld 550ub, has a problem . No picture, on lg logo comes on and red blinking light
I replace the lamp and now the tv powers on and after a few min turns it self off and power button blinks red
Why no picture, no sound?
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
2answers
I have a Sharp 70" (LC-70LE632U) LED TV. When you turn it on, the front led is on, but no screen. After a few seconds, the front led starts 5 short and 2 longer blink and continue this way constantly.
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location
Please let me know , why my IKON LCD TV not on, when I try switch on tv , so red light blink for few second but tv not on . what do .. I need to repair lcd tv or remote ?
Your TV has the fault. The blinks you see with it are called blinking codes, and are fault indications. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV, which will make repair easy. If you're sound in electronics, and have all the tools to work, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
My 47LG70 tv went out. I heard a pop and the screen went blank. The lower right hand sensor light turned blue. I tried unplugging but that didn't work. When I tried to turn it on again the sensor light...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
