Port forwarding in D_LINK DI 1705B
For remote access of server
Benimur
  • 6966 Answers
SOURCE: Have D-link 704 router, can I connect the DI-524 to it also to add wireless?
Hi, I have not tried it myself with DLink but with LinkSys, yes it will work. It may take a little configuration tinkering but should work. However a few notes: 1. You should only have 1 DHCP server (both have this feature); 2. You can not have 2 identical IP address; 3. I suggest you make the 524 as the gateway and the 704 as a slave; 4. In effect you will connect 1 of the LAN port of the 524 to the WAN input of the 704; 5. You have to copy the WAN settings of the 704 to the WAN settings of the 524; 6. Or if you want to retain the 704 as the gateway, disable the identical features in the 524. I suggest you treat the 524 as a client of the 704. Hope this gives you some idea and work out for you as it did with my LinkSys. Goodluck and kind regards.
Posted on Aug 17, 2007
marked
  • 6487 Answers
SOURCE: Remote Access
If you want to access your router remotely, you just need to enable remote management on your router so you can access it using your internet IP colon the port number usually its port 8080.
Posted on May 09, 2008
SOURCE: port forwading
http://portforward.com/
this site may be of some assistance
Posted on Jun 19, 2008
amusedgeek
  • 787 Answers
SOURCE: D-Link DI 524 behind VNC access remotely - Need help....
Open a browser and type in htp://192.168.0.1 to access your router's web management interface. Enter the username and password (default is username admin and no password)
Go to the Advanced Tab and Virtual Server
Name=VNC
Private IP=IP Address of your Home notebook
Protocol Type=TCP
Private Port=5800
Public Port=5800
Set Schedule as you like
Enable the rule and click Apply.
To access you Home notebook from anywhere other than your house, go to http://10.0.57.46:5800
Next - remote management of the router.
The IP address that you enter on the remote management page is the IP address that is allowed to connect to the remote management. If the 194.145.183.83 is the IP address of your office, this should work. Be sure you apply a password or anyone going to http://10.0.57.46 will have access to you router, I also recommend changing the port from 80 to 8080 so that http://10.0.57.46:8080 has to be typed to access the remote management interface.
Posted on Jan 06, 2009
dante777
  • 623 Answers
SOURCE: I have a zyxel p600 series modem connected to a
Your setup looks correct to me. It might very well be that your ISP is blocking port 80. Go here and check from your server if port 80 is accessible.
If you are the only one that wants to connect to you server, you can simply choose another port to use, i.e. www.myserver.com:801. Set port forwarding form port 80 to 801 in your router.
TCP&UDP - from 801 - to 80 - [serverIP] - [Webserver]
The better way is to use a service like DynDNS.com or No-IP.com. You can register a DNS name (like myserver.dyn.com), which redirects to your public IP. The trick is to update your IP address, so even if you have a dynamic IP assigned from your ISP, the redirect will point always to your server. Most routers have the ability to set up with DynDNS, so the process runs in the background and you don't have to update manually - check your router manual.
The second part of this beauty is the redirect to a different port. So even if your port 80 (and 25 for that matter) are blocked, you don't have to have an arbitrary number in your URL (http;//myserver.com:801). You can find more detailed information here.
For a quick check, change your webserver to run on port 801, enter the redirect in your router and see if you can get to your server from the outside (internet). If you still can't access the webserver, the problem is not a blocked port.
Hope this helps, but if you have any more questions, just come back here and leave a comment - I'm happy to help you figuring this out.
Posted on Oct 23, 2009
Port forwarding
As i remember all port forwarding was under Virtual Server configuration. But you need to check maybe web cam is using more then 1 port. Try to play with netstat to see, to which ports Connection establishing when you are connecting to cam.
Apr 19, 2010 | D-Link AirPlus DI-524 Wireless Router
Windows home server remote access - cant get it to work
It's probably not about RDP. I think we are talking about the homeserver remote access that allows you to up/download stuff to/from yourshares, run the server console or remote control a workstation in your homenetwork from outside (from the internet).
The whole procedure is a little complex. In short, you have to:
- start remote access in the WHS console (settings - remote access)
- create and configure a dyndns domain name (or something similar) to find your server from outside
- configure the user profiles to allow remote access. They need to have "strong" passwords.
- forward the port numbers 80, 443 and 4125 to the servers IP address on your internet router.
- forward the port 3389 too, in case you want to use the RDP protocol to access the servers remote desktop.
That should be it.
If you have several routers in your net, you have to forward the ports from the first one to the second and from there to the home server.
Since we don't know where exactly you are stuck, you should post a little more information.
Hope this helps.
Nov 06, 2009 | Computers & Internet
How to Site to Site VPN between DI 804HV and DI 804HV.
you can try to do port forwarding by logging in to router GUI setup page and manage this port
Service Name Start Port End Port Server IP address
VPN1 47 47 192.168.1.x
VPN2 50 51 192.168.1.x
VPN3 500 500 192.168.1.x
VPN4 1723 1723 192.168.1.x
Jul 13, 2009 | D-Link Express EtherNetwork DI-804HV...
Ssh remote computer access
It is possible to limit outgoing connections, but generally a firewall is used to limit connections being initiated from the outside (incoming connection attempts). Check the settings in your router to ensure that it isn't limiting outgoing connection attempts, but it sounds more like a permissions issue on the server your are trying to connect to.
Apr 15, 2009 | D-Link DI 514 Wireless Router (DI-514)
Letting Ultra VNC go through a Dlink router to connect to a serve
You may have to define the VNC service under services then port forward that service on port 5900 to internal 5900.
Of if it has a Virtual Server option just forward port 5900 to 5900 and send it to the LAN IP Address of the computer you want to use.
If you need instuctions let me know and i'll post,
ta, HPC
Feb 24, 2009 | D-Link AirPlus DI-524 Wireless Router
How to enable WAN IP in a DI-604 Router for 3 computers
"I wanna make the 2nd pc a server but it isn't accessible through the WAN ip. "
Well that explains everything. If you want to get to 192.168.0.102 from the internet, you need to tell the router where to send packets. You do this by going to the ADVANCED section and configuring Virtual Servers. For example: If you are setting up the computer at 102 as a ftp server, ftp uses port 21. The name would be FTP, private IP would be 192.168.0.102, Protocol is TCP, and the Private and Public ports would normally both be 21. Don't forget to Enable the rule.
What this does is tell the router that when ever a request comes in on port 21, it should forward it to 192.168.0.102. To access the external side of the router you need to go to 70.55.84.233 (according to the image you posted)
Jan 03, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Name=VNC
Protocol Type=TCP
Private Port=5800
Public Port=5800
Jan 02, 2009 | D-Link AirPlus DI-524 Wireless Router
Port forward
What you have done is fine. "Integer" means that you have to input a number between 1 and 65535 as the public and private port.
D-Link have specified that it must be an integer because some other firewall products from other manufacturers also accept service names such as "ping", "pop3", "ntp", etc.
Mar 12, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Opening ports
To forward a specific application port please follow the steps below: Step 1: Open your web browser and enter the IP address of your D-Link router (192.168.0.1). Step 2: Click on the Advanced Settings tab and then select Virtual Server from the left side. Step 3: Enter the last three digits of your IP address on the field provided and then enter the range of ports that would like to allow in. If you would only like one port to be opened, then enter the same number in each box. Step 4: Click Submit and then Save and Restart when prompted.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
Configure the firewall
You can use the Virtual Server to forward an individual port to one of your computers. You cannot forward the same port to multiple computers. In order to configure the Virtual Server you need to know the IP address of the computer that needs the port opened and the service port number. The links below will help you find the IP address of your machine. If you don?t know which port needs to be opened, try checking the software manufacture?s support website for information on use behind firewall. Configuring the Virtual Server: Step 1 Access the device configuration by entering 192.168.0.1 in your web browser. Login with your username and password. The default username is admin and the password is blank. Step 2a If the port you need to forward is a common port, it will be under the predefined virtual server list at the bottom of the page. Click the pad and paper icon next to the virtual server entry you want to use. The Protocol Type and Service Port fields are preconfigured. Click the Enable radio button to use the virtual server. Enter the private IP address of the computer that will use the service port. Configure the Schedule as needed, then Apply your settings. Step 2b If the port you need to forward is not listed under the predefined virtual server list at the bottom of the page, you can create a new entry for your application. Click the Enable radio button to use the virtual server. Give your virtual server a name. Next, enter the private IP address of the computer that will use the service port. Then, select the Protocol Type and enter the Service Port. If you don?t know how to use Private and Public port assignment, then just enter the same port number in both fields. Configure the Schedule as needed and Apply your settings.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
