Question about Tools & Hardware - Others
Why is the hy-mag domestic timer for geysers contactor is switching constantly
3 Suggested Answers
  • 5089 Answers
SOURCE: how to set Hy-Mag pool timer switch
Be real.
Describe the timer in detail, and include the model number and take a photo and post on flickr.
Add a comment with missing information.
Is this a timer, or circuit breaker?
Posted on Oct 09, 2012
Where do i connect the geyser load wire to a dhc15a-20a timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#PB1
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#FM1
The other terminals are NO NC and Com
Neutral does not connect to these... only Hot
Hot connects to Com... and then connect wire to geyser to the NO contact... general illustration on link above
Sep 19, 2014 | Hardware & Accessories
How to set a Kes load control timer model ISG1201
The Geyser Load Control Timer, ISG1201, is designed to prevent geyser from operating during the Eskom's designated weekly morning and evening peak times. The ISG1201 features 4 easily selectable, pre-programmed, geysers "ON" operating profiles to ensure maximum comfort whilst not burdening the user with the complicated process of having to program the unit.
The profiles are as follows;
  • Program (1) is always "ON"
  • Program (2) "ON" after sunset to accommodate solar geysers
  • Program (3) "OFF" all the time
  • Program (4) savings program - "ON" 6 hours weekdays and 12 hours weekend days
Source: http://www.kgwanyape.com/solutions/isg1201-geyser-load-control-timer/
Oct 31, 2013 | Hardware & Accessories
Geyser timer stopped working
Check circuit breaker.
Click fully off and then back on.
Check for burned smell at breaker or loose crackling sound that says breaker is bad.
Reset timer. Then Reprogram.
Possible geyser timer manual
http://waterheatertimer.org/pdf/Digital-Geyser-Timer 24H-7-Day-Timer-230V Brochure.pdf
This timer has a non-replaceable internal rechargeable battery.
If battery has gone bad, then timer is defunct.
Use manual override button to turn timer ON-OFF.
Then test across terminals 3 and 4 for 240Volts.
Turn timer OFF, and test across terminals 4 and 5 for 240Volts
If no voltage shows then timer does not have output.
If test shows 80% undervoltage, that can cause load not to activate, depending on type of load.
Have electrician check for voltage issues at power company transformer.
Unknown what load timer is connected to.
Max load for this timer at 240 volts is 3680 watts, 16 amps.
Motor load is 230 volt 8 amps.
Check label on load for watt or amp rating.
Volts x amps = watts
Watts divided by volts = amps
Oct 31, 2012 | Hardware & Accessories
I need a diagram of magnetic contactors with timers
10-19-12
Each timer has a contactor.
Timers can also control a contactor.
Which timer do you have?
Here are contactors, with some illustrations showing tiimers controlling contactor:
http://waterheatertimer.org/H230A.html
Here are example timers controlling a 3-pole contactor for 3-phase application:
http://waterheatertimer.org/How-to-install-3-phase-timer.html
Oct 19, 2012 | Paragon 8145-20 Defrost Timer
How to set Hy-Mag pool timer switch
Be real.
Oct 09, 2012 | Hardware & Accessories
I am a Home Inspector. How do I override the timer controls to produce heat at the ETS units so my clients can see that they work. I put the timer lever in the manual position however after 30 minutes no...
You posted under ET70415CR. This is a complicated timer with many wiring and programming capabilities.
Open following links for ET70000 series image and ET70414CR instructions:
http://waterheatertimer.org/images/ET70115C-copy.jpg
http://waterheatertimer.org/pdf/Intermatic-et70415cr.pdf
Among the features, this timer can be programmed for pulse or momentary action to control external latching contactors:
Page 36 of instruction says:
Note: Using the manual On/Off keys to switch this type of contactor On or Off may not provide the expected result and may cause damage to the contactor coil. For this application external Momentary Pushbutton may be added for both circuits or the circuits may be programmed for override pulses.
So instruction is saying that additional wiring is needed to override specific types of circuits.
The timer has 8 internal contactors, and each can be controlled separately by the timer to control 8 different electric circuits. This is called 8-channel timer since all eight timing contactors can be programmed separately.
Each contactor is wired separately to control any type of electrical appliance including 440V lights, and 24V alarm system, and 240V heat, etc.
For example contactor1 might be for lights, and contactor2 for controlling a latching contactor, and contactor3 for controlling a boiler, contactor4 etc...
To override the system, you have to identify which contactor controls the system in question.
Then there are 2 options:
1) Reprogram the timer on that channel
2) change the wiring temporarily: Each of the 8 contactors has 3 screw terminals: COM, NO, NC. If there are wires on all 3 NO NC COM terminals, you have to reprogram timer. If there is a wire on NC terminal -or- NO terminal, typically you would move that wire to the COM terminal to by-pass timing operations.
Jun 23, 2011 | Intermatic ET70415CR Energy Controls - ETS...
Pool pump cannot be turned off with timer switch. Pump runs constantly. I can turn off with breaker switch but not with switch on timer.
You posted under Intermatic EI200 series countdown timer.
Intermatic EI200 series is rated for 1/4 HP.
Check nameplate on motor for HP. Pool pump is probably 1 HP.
Open following link for countdown timer ratings:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%20auto-off%20timers.aspx
Add a comment and say what kind of timer you are using and say specifically what you want timer to do, and I will locate correct timer for that specific need.
You can also add a contactor to the circuit.
Timer controls contactor, and contactor turns pump on-off.
http://waterheatertimer.org/Water-heater-contactors.html
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 04, 2011 | Intermatic EI220 Electronic Auto Shutoff...
I am installing the timer for a whole house fan. I hooked red up to load, black to hot and white to neutral per instructions...confirmed with meter....the timer does not seem to work..I can turn on and...
A) GE 15069 image at Amazon
http://www.amazon.com/60-minute-Automatic-Shut-Off-Timer-Switch/dp/B002DNAE7Q
15069 manual
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/In-Wall-15069-Manual-eng.pdf
Manual shows GE 15069 countdown timer is rated up to 1/2 horsepower
Whole house fan is likely 3/4 horsepower >> check nameplate on fan motor.
B) work around:
Hook timer up to a contactor/relay.
Timer turns on 120 volt, 7 watt contactor coil.
Contactor turns on fan motor
Square D contactor at Grainger
http://www.grainger.com/Grainger/SQUARE-D-Compact-Contactor-5B132?Pid=search
http://www.pexsupply.com/Furnas-Controls-45EG20AF-2-Pole-30-Amp-120V-Contactor
I buy these contactors at local HVAC supply for $15
add a comment if you need help wiring this device.
C) List below shows countdown timers with horsepower rating:
GE15088 countdown timer is rated 3/4 hp
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay
Intermatic spring wound countdown timers are rated for 2 horsepower
http://www.intermatic.com/products/timers/in-wall%20timers/decorator%20spring%20wound%20timers.aspx
Woods spring-wound countdown timer says bath/ ceiling fans, but doesn't give horsepower
http://waterheatertimer.org/pdf/Wood-59700-series--spring-wound.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#countdown
Woods push-button countdown is 1/4 horsepower
http://www.amazon.com/Woods-59014-Decora-12-8-4-2-12-Hour/dp/B002C54GH4
Lutron MA-T51 countdown timer specifically says it cannot be used for motors, which says the electronics inside each device is Load specific
http://www.amazon.com/Lutron-MA-T51-WH-Maestro-Countdown-Timer/dp/B001EFV1DA
http://www.lutron.com/TechnicalDocumentLibrary/0301041A.pdf
Pass and Seymour RT1 countdown does not show rating for horsepower, so this timer will probably not work for fan motor
http://www.homedepot.com/Electrical/h_d1/N-5yc1vZ1xg8Zarcd/
Wattstopper RT50 at Grainger shows 1/6 horsepower rating
http://www.grainger.com/Grainger/WATT-STOPPER-Time-Switch-2HTE1?Pid=search
Dec 12, 2010 | GE 60minute Automatic ShutOff Timer Switch...
How to install 25amp 3 pole relay
There should be 8 screws on the relay L1, L2, L3, T1, T2, T3 and two additional screws either at the top or bottom, or one on each side. The incomming, constant power in from the circuit breaker, should connect to L1, L2 & L3. The power out to the load should connect to T1, T2 & T3. The control wire from the switch or timer you will be using to close the contactor will connect to the remaining two screws. THE MOST IMPORTANT PART IS THAT THE CONTROL VOLTAGE MATCHES THE COIL VOLTAGE OF THE CONTACTOR. They will make 12vac, 12vdc, 24vac, 24vdc, 120v, 240v, 277v, etc. coils for the contactor.
Also keep in mind that when the contactor closes L1 & T1 make contact, L2 & T2, Etc.
Oct 08, 2009 | Eaton ARC FAULT CIRC BREAKER
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
