Question about Kenmore Dryers
Kenmore gas dryer model no 417.93142300 stopped working during cycle; will not start again, also dryer has an electrical burnt smell
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Check to see if the belt has broken.
Posted on Oct 28, 2012
SOURCE: my kenmore electric dryer quit working mid cycle and just stopped
could be the motor start relay
Posted on Oct 31, 2008
SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Posted on Jan 26, 2009
jtbjtb
  • 135 Answers
SOURCE: I have a Kenmore Dryer
You have at least 3 problems, with your dryer; door switch, start switch and drum support. To to retire it for a replacement. Hope this helps!
Posted on Jan 28, 2009
ned_san_jose
  • 234 Answers
SOURCE: Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Posted on Jul 07, 2009
  • 121 Answers
SOURCE: Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Posted on Oct 20, 2009
Inglis dryer is squealing like a belt loose. it subsides during cycle but a burnt rubber smell is very prominent when finished
Replace the belt - it is old and worn out. The belt is made of rubber and is slipping, causing the smell and squeak. The belt heats up and becomes more flexible after the dryer runs a while; this is why the squealing stops.
Mar 26, 2013 | Inglis 6.5 Cu. Ft. 5-Cycle Electric Dryer...
My model 400 series Kenmore gas dryer has a heating issue. At first start I can hear the gas heater ignite and heat the dryer. After the dryer has ran for a few minutes the burner shuts off and fails to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 05, 2011 | Kenmore Dryers
Kenmore electric dryer 70 series - it starts, motor sounds horrible, turns, gets hot, almost a burnt smell. what do i do?
Greetings,
it sounds like its bad...they usually will drag slightly when you push start. in other words, you can hear a delay in it starting...almost a hum, but not always...if its smelling like burnt wiring..it usually cuts off and will not come back on until it cools down..
Are you sure its the motor thats making noise?? if a roller goes bad..it will go thump,thump, thump and they make alot of noise too...does it stop during the cycle? if you have more question, let me know and hope this helps
Feb 03, 2011 | Dryers
Kenmore dryer stopped working, still has power.
When the timer stops during the duration of the time set the timers cogged tooth gearing has stripped out. A new timer will be needed to get your dryer working again
Apr 07, 2010 | Dryers
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Jul 06, 2009 | Kenmore 73952 Gas Dryer
The dryer timer runs but the dryer does not
burned out element probably to much lint on the element and motor unplug dryer and take back off and use a vacume to vacume up all the lint and look at the element to see if they are broken they are fairly cheap .cheaperthan a new dryer also check the belt it mighjt be broken
Mar 23, 2009 | Kenmore 62622 Electric Dryer
KENMORE DRYER WILL NOT START
It sounds like the motor has burned up or is burning up is why you are getting that smell. There could at the same time be a wire that has come loose or burned off that is causing it not to come on.
Jan 26, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
43 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
