Question about Dryers
Dryer stop working during cycle, won't restart
After dryer stopped, there was a electrical burning smell. tryed to restart but dryer did not turn on.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Check the belt.
Posted on Oct 28, 2012
SOURCE: smells like somethings burning, more
did the drum stop turning,when motors overheat they smell realy bad.
Posted on Nov 01, 2008
barkencoa
  • 3463 Answers
SOURCE: Whirlpool Electric Dryer wont turn on
Try this;
In your browser bar type in youtube.com
In the search box type in repairing whirlpool dryers
Then click on the apprpiate video.
This should help you.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
  • 105 Answers
SOURCE: Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Posted on Feb 06, 2009
jonniewalker
  • 1031 Answers
SOURCE: Dryer will not dry clothes properly
Problem: The drum spins, but there is no heat.
Solution: This could be the effect of a number of problems. Here's a list of things to check and details on how to do it.
  • Fuse could be bad -- Check the fuse for a break inside. If it’s bad, replace it with an identical fuse.
  • Temperature switch could be bad -- Use VOM to check the switch. Set VOM to RX1, remove leads and touch the probes to the switch's terminals. The reading should be zero or infinity. Turn the switch, and the reading should change from zero to infinity or infinity to zero. If not, the switch is bad.
  • Thermostat could be bad -- Set the VOM to RX1, take a lead off one of the two outside terminals and press the probes to the two outside terminals. There should be a reading of zero. If not, it's bad.
  • Heating coils may be bad -- Set the VOM to RX1 and remove the leads from the coil. Press the probes to the terminals. If the reading is zero, the coil is bad.
  • Timer could be bad -- Disconnect the leads from the motor. Set the VOM to RX100. Clip the probes onto the leads. If the reading is infinity, the timer motor is bad.
Posted on Feb 10, 2009
  • 63 Answers
SOURCE: Kenmore 70 series electric dryer. Clothes are
most common reason for this would be clogged vent...check all the way in and out!
Posted on Mar 16, 2009
DRYER WON'T START
you need a new heating element just had mine fixed did the same thing
Sep 28, 2012 | Frigidaire Electric Dryer
The coils in back turn red hot and smells like it is burning
Here is a tip that I wrote about why an electricdryer will not stop heating sometimes.
ElectricDryer won't stop heating
heatman101
Aug 15, 2011 | Frigidaire FER311FS Electric Dryer
My dryer stopped running in mid cycle and there was a burning smell. I thought it may be the belt, but it is not the belt. Also, the light inside the dryer hasn't worked for years, so I don't think...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 15, 2011 | Maytag HYE3658AY Electric Dryer
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Washer stopped during wash cycle, burning smell
http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/index.aspx Take a look at what a new motor costs for your machine and go from there. Is may not be a motor is could be a belt or a bearing. I rebiult a washer for less then 50 dollars that one did not need a motor just bearings and a belt. I would take the washer apart so you can get an idea of what went wrong and then look at parts to repair it and decide what to do good luck
May 23, 2009 | Maytag PAV3240A Top Load Washer
The dryer timer runs but the dryer does not
burned out element probably to much lint on the element and motor unplug dryer and take back off and use a vacume to vacume up all the lint and look at the element to see if they are broken they are fairly cheap .cheaperthan a new dryer also check the belt it mighjt be broken
Mar 23, 2009 | Kenmore 62622 Electric Dryer
Feb 06, 2009 | Malber TD700 Electric Dryer
Washer just stopped
I would check the drainpump ans see if there is something jammed inside like a coin or screw,nail etc before doing anything else .Unplug the machine first though . A burning smell will occur with a load of water trying to spin .
Nov 06, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
76 people viewed this question
Top Dryers Experts
