Question about Karcher Garden
Hi have a Karcher 6.91 and I cant get any high water pressure. It has power, I have checked the o-rings, filter and lances but it does not build up high pressure. The water also appears to flow back
What can I do to fix this problem.
  • 92 Answers
SOURCE: Karcher pressure washer won't start
Dear ralph_birtwi,
Most pressure washers when their gun is released, the machine stops automaticaly. This is done ny means of a control valve. When the gun is closed...pressure is built and the control valve moves and switches a micro switch off. In your case the micro switch is still closed in off position. Now this happens if a machine is left and stored with pressure in it., This control valve could get jammed and leaving the micro switch in off position. It could also stay in off position by sticking, due to incorrect chemical.
So the control valve or even called spill valve, must be renewed.
Sometimes a little lubrication with the right type of silicon grease will get the control valve working again. This job is sometimes delicate and better done by a qualified technician.
Regards,
fulltech.
Posted on Apr 12, 2009
  • 32 Answers
SOURCE: Karcher Motor Pulese On and Off
hi mark, you do have a problem with the lance.
you need to disconnect the lance and straighten a paper clip and insert down the nozzle end.
use the machine to wash the dirt in the nozzle backward down the lance.
Dirt only in nozzle end.
if still no good, purchase some nozzle cleaners and file out nozzle very slightly.
Posted on Jul 04, 2009
  • 6 Answers
SOURCE: Australian Karcher 2.91 intermitant start
Under the top cover there is a micro switch that sometimes dislodges
This switch is for auto cut off when you release the trigger
Posted on Jul 27, 2009
  • 250 Answers
SOURCE: The motor keeps surging
If there's a lot of sediment in your water supply, there's a chance that sediment has gummed up the pressure switches. I'm assuming it has a full power switch and high power switch. It runs on full power until a pressure switch is satisfied, and runs on low power to slowly build the pressure back up, at which a second switch is satisfied from the pressure and turns the motor off. These things are not easy to work on, and are made of metal probably too fragile to try any chemicals. You should probably contact the manufacturer.
Posted on Sep 19, 2009
Testimonial: "Thankyou, great help!"
  • 10865 Answers
SOURCE: does not give a continous high pressure flow cuts in and out
Hi. Water flow may be restricted to the pressure washer.
Check that all hoses are free of kinks, leaks, or blockage. Make certain all hoses and fittings are connected properly. Make sure to open the faucet/spigot to full force. Set the spray wand to high pressure.
Clear any debris from the nozzle. If the nozzle has even a little bit of dirt in the tip, it may cause enough obstruction for the pressure washer to pulsate. If your pressure washer came with a nozzle cleaner, use it to clean the tip. If not, you can use a pin or paper clip to clear the nozzle tip of debris that may have become lodged in it.
If these have been checked and the washer is still fluctuating from high to low pressure there may be air trapped in the pump. To bleed the pump of any air, turn the machine off and disconnect the high pressure hose and trigger gun from your power washer. With only the garden hose connected to the machine, turn on your water source and allow water to run through the pump of the machine for 20 or 30 seconds. Turn off the water and connect the high pressure hose and trigger gun and try using the machine again.
Posted on Jul 31, 2010
Karcher K2.94 intermittent pumping and buzzing
try the machine with the lance removed from the gun.
buzzing is usually the noise made by the motor when it cant turn. if the pump start to pruduce pressure but the pressure builds up too high then the motor will stop turning... faulty lance or faulty spill valve (dump valve)
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 05, 2013 | Garden
Why doesn't the unit stop running when pausing while pressure washing, it use to
Hi If you have any leaks on the high pressure side then the unit will keep starting. Please check all external hoses etc and o rings to make sure that they are water tight. The most common one is where you screw your high pressure hose on,there is a o ring inside the coupling that usually wears. Also check all o rings at the trigger and lance. If there are no leaks then it sound like you have a problem with your pressure switch.
Jun 14, 2010 | Karcher K238CCK 1600 PSI 13 GPM Electric...
When the patio cleaner is attached,the Karcher 5.68 pressure washer now keeps stopping and starting.It works fine on high pressure lance.It worked fine when bought from new a few days ago. We tried...
None of these fixes works for me and the original poster, like me what he's saying is when he swaps the high pressure lance for the patio attachment it pulses on and off, but when that happens, you can swap back to high pressure lance and it's fine. This means it's the patio attachment not any valves or power source, I have the same problem
Mar 09, 2010 | Karcher Garden
When pressure washer engine is running and hooked to water supply, there is no water spray with trigger is depressed
Hi Have you checked that your nozzle in the lance end is not blocked. Please try this and then try without the high pressure hose attached.
Oct 27, 2009 | Karcher 2500 PSI Pressure Washer
Sep 19, 2009 | Karcher 1750 psi Electric Pressure Washer
My karcher G2000QT WORKS AT HIGH PRESURE FOR A COUPLE OF SECONDS AND THEN STOPS THEN A COUPLE OF SECONDS LATER WILL START AGAIN WHATS GOING ON?
are you making the machine **** for water, if so you have got a air leak on the suction hose.
try force feeding with water by connecting your hose to the mains water hose and see if you can see a water leak.
could be starved of water also,chack the filter
Jun 28, 2009 | Karcher 2500 PSI Pressure Washer
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
Garden Logo
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
