Question about Orion STV2763 27" TV
Orion 27" HD TV Green Screen
My Orion has nothing but a green screen. I do have sound, but I can barely even see the menu and channel numbers.
  • 883 Answers
SOURCE: Wrong or 3-Digit Channel Numbers
that request is not available...firm-wared chip proprietary from orion
Posted on Jun 01, 2007
  • 934 Answers
SOURCE: orion tv1929 19" tv
If you're looking to just release the v-chip try this:
Turn set on and set the volume to minimum.
Hold the volume (-) on the set and press 0 (zero) on the remote.
V-Chip password should release.
Posted on Nov 15, 2007
  • 1689 Answers
SOURCE: Orion TV, Model STV2763A
This is usually caused by some of the electrolytic capacitors in the vertical deflection amplifier and in the blanking circuit areas. Sometimes it can be some of the other types of components going slightly off specs.
To test the capacitors, an ESR meter or the equivelent is required.
I would suggest sending the TV out to have an experienced TV service tech do this type of work for you. These types of problems can get very involved. There are also some serious safety issues when working on a TV set.
Jerry G.
Posted on Jun 10, 2008
  • 520 Answers
SOURCE: am i able to get into the menu of small orion tv without a remote
It may be possible to access the menu by holding down both volume buttons for 10 seconds. If not you probobly need the remote.
Posted on Dec 19, 2008
SOURCE: Orion stv 2750 27" TV
if you dont already have the remote set up then find the codes and t it up. the remote should have a button that says either tv/video or input. depending on the tv it should take you to a few channels through this button. look for either input 1 or 2, or even GAME. these should be the channels it will play on.
Posted on Dec 30, 2008
Green and Red (thin lines) across entire screen [JVC 70 G886 HD TV]. Screen went to all green (wide and thin) within 1/2 hour and picture hasn't come back. "Input selection" box is visible and clear...
Try a "hard reset" first by unplugging the set for 30 seconds. and if no help, you may have a problem with the SMPS power supply, it might have a bad capacitor or two by now. Worth repair if engine is good compared to a flat panel.
Apr 22, 2014 | JVC HD-70G886 70" Rear Projection HDTV
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Problems tunning channels in my old orion tv
On the remote, is there a setup, install or menu button? sometimes its the red, green, yellow, and blue buttons on old tv's that are the tv's system settings, if that does not work can you tell me what the make of the tv is, there should be a number or make on the front of it.
Jul 19, 2009 | Orion STV2763 27" TV
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Samsung HLR5067 flashing green
Thank you!!!! Our power was off due to new transformers being installed in the area and we had no clue how to fix this. I called around and no one seemed to know the answer (not even Samsung, who only wanted to tell me my TWO year old tv was out of warranty),so I tried this and it worked perfectly!!! You saved me a bundle! Thanks!
Jun 13, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Orion 27" tv
Ok,Who has been Playing with the Remote,Go into menu,And what you are looking for is Captions in the Captions mode look for Text,Turn it off,Just turn off cc Completly and that will fix it Let me Know ttech
Aug 01, 2007 | Orion STV2763 27" TV
Orion STV2763 27" TV Logo
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
