Question about HP Photosmart C7180 All-In-One InkJet Printer
I can send faxes but cannot receive them fax test tells me there is no dial tone detection
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 43 Answers
1. Press the power button to turn off the HP fax product.
2. Wait for 20 seconds, and then press the power button to turn on the HP fax product, and then connect one end of a two-wire telephone cord to the telephone jack and the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
3. Make sure that there is plain white paper in the input tray.
4. Press the Setup button on the product Control Panel.
5. Press the down arrow to select Tools, and then press OK.
6. On the Tools menu, press the down arrow to select "Run Fax Test", and then press OK. The Fax diagnostic test prints.
7. Review the report.
If the test lists faxing issues and solutions, the fax test failed.
Try the steps on the printout to troubleshoot the issue as the report is specific to your product and faxing environment.
Repeat the fax test after fixing the listed faxing issues to make sure the test passes. Try to receive a fax.
Okay, next, we need to make sure that the Auto Answer feature is turned on by following the steps below:
When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls.
1. Press the Setup button on the product Control Panel.
2. Press the down arrow to select Basic Fax Setup, and then press OK.
3. On the Basic Fax Setup menu, press the down arrow to select Auto Answer, and then press OK.
4. Press the down arrow to select On, and then press OK.
5. Try to receive a fax.
Since the issue persists, the problem could be due to some conflicting telephone services.
The following telephone company services might block or interfere with incoming faxes:
Distinctive Ring Service: A distinctive ring service, if it is available from the telephone service provider, often resolves this issue.
* Voice mail: It is possible to use the fax in manual receive mode while using a voice mail service. For manual receive mode, turn off auto answer and press "Start Fax Black" or "Start Fax Color" on the control panel before the voice mail picks up the line to start receiving the fax.
* Call waiting: Do not use a call waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
* Privacy block
* Security screen
* Anonymous call rejection
* Privacy manager
* Any other service that screens or intercepts incoming calls
If any of these services are on the telephone line connected to the HP fax product, contact the telephone service provider for its recommended solution.
After addressing any existing conflicting telephone services, try to receive a fax.
Try contacting telephone people
try changing the settings below
2. Press the down arrow to select Advanced Fax Setup, and then press OK.
3. Use the down arrow to select Fax Speed, and then press OK.
4. Use the down arrow to select Medium, and then press OK.
5. Try to receive a fax again. If the HP fax still cannot receive a fax, try lowering the fax speed even further
Next, change the "Rings to Answer" setting on the HP fax by following the steps below:
2. Press the right arrow key to select Basic Fax Setup, and then press the OK button.
3. Press the down arrow to select Rings to Answer, and then press OK.
4. Use down arrow to select the desired number of rings, and then press OK. you cn change the rings to answer to 6 if your telephone answering machine picks up the call after 4 rings.
If the HP fax still cannot receive a fax, change the following steps
2. Use the down arrow to select Advanced Fax Setup, and then press OK.
3. Use the down arrow to select Error Correction Mode, and then press OK.
4. Use the down arrow key to select Off, and then press OK.
1. Plug the telephone cord directly into the telephone jack and not through any other device.
2. If present, remove any splitters or other devices attached to the line, except for a DSL filter.
3. If the telephone cord is over 3 m (10 ft) long, move the fax closer to the telephone jack, and then use a cord 3 m (10 ft) long or shorter.
4. Connect the other end of the telephone cord directly to the back of the HP fax product into the port labeled 1-Line.
5. If other devices such as, telephone answering machines or computer modems, are attached to the telephone line, remove them. If devices attached to other extensions of the same telephone line are present, remove them for this test.
6. Try to receive a fax.
If removing telephone devices and connections allows the HP fax product to receive faxes, this indicates interference from one or more of the removed devices. Interference can be caused by incompatibility or by using too many other telephone devices at once. Telephone devices can be added back but test after adding each to make sure that they do not start to interfere again.
If the HP fax product still cannot receive a fax after removing other devices, continue with the following steps:
7. If a DSL filter is needed on the telephone line, change the DSL filter and then try to receive a fax. If the HP fax product still cannot receive a fax, proceed to step 8.
8. If a new telephone cord has not been tried, change the telephone cord to a new two-wire telephone cord, and then try to receive a fax again.
if it does not resolve then perform the following steps
1. Disconnect the power cord from the back of the product.
2. Wait for 20 seconds, and then press and hold # and 6 on the product Control Panel.
3. Connect the power cord to the back of the product and then release the buttons when the product turns on.
4. The product resets to factory defaults.
As a last step, test in another location by following the steps below:
If possible, move the HP fax product to another location with a separate telephone line (another house for instance).
Try to receive a fax at that location, and if you are able to receive faxes from the changed location, then your telephone line should be tested.
If it resolves well and good if it does not then service the printer
Posted on Nov 08, 2013
hashir4u
  • 79 Answers
SOURCE: Fax Problem
turn the printer on ...
unplug the power cable without turning the printer off....
press and hold # & 3, keep them on hold ....
while holding these two buttons put the power cable back in ... and wait for a few the screen to come up ... the screen may go blank ... use the power button to turn the printer on ... try to receive the fax ...
if it will not work then try # & 6 .... remember take the backup of phone numbers if stored on the printer as it ll erase the memory of the printer ,,,
Posted on May 23, 2008
  • 1894 Answers
SOURCE: fails to receive fax
i think this can be a problem in your FAX unit alone.
may be due to some disturbances in line
Posted on Jun 10, 2008
  • 81 Answers
SOURCE: No dial tone detected
It may be a bad modem on the copier. Plug your phone into the auxillary phone port on the copier and see if you get a dial tone. Also make sure that your cord from the wall is plugged into the line port and not the phone port.
Posted on Jul 24, 2008
  • 105 Answers
SOURCE: Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
Posted on Oct 05, 2008
  • 40 Answers
SOURCE: C6180 FAX UNABLE TO SEND OR RECEIVE
check the the phone line, The fax sinal need good clear. Surely,plug the phone-line is rigth line socket. If you do that all, the broblem is still happenning,need to change "relay" on moderm fax board.
Posted on Jul 27, 2009
Why is there no dial tone?
Connect a telephone in place of your fax machine. Listen for a dial tone. If you hear it, something is wrong with your fax machine connection.
Aug 15, 2015 | Brother IntelliFax-4100e Fax
How do i set my fax machine to recieve and send faxes
Dear
Connect the telephone line to the LINE socket of the fax machine and a telephone receiver unit to the EXT socket of the fax machine.
To send a fax, put the document on the platen glass (face downward) or face upward in case of ADF.
press on hook dial, (here the dial tone on machines speaker)
dial the fax no. ( wait for call connection and here the fax Rx. tone)
press START.
To receive a fax two procedure can made, manual- lift a hand set of telephone receiver on incoming ring, here the TX tone(periodical beep tone) press * 9 * of the telephone receiver. In auto mode go to fax setup select ans. to ring or auto fax etc. to activate atuo reveive of fax.
Hope this may helpful.
Thanks.
Aug 11, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Can not send or receive faxes. Have successfully performed and passed the 6 components of the HP Fax test. Can hear dial tone when attempting to fax.
Dial from printer to your mobile phone sense the ring then send the fax sense the fax tone if fax tone not hearing you replace formatter ...
Sep 08, 2011 | HP Officejet 5610 All-In-One InkJet...
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
I can receive faxes but cannot send them
Check your fax speed settings, also, make sure you get a good clear dial tone on the line. Sometimes it wont send if it detects line noise.
May 01, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Printer can't send or receive faxes
Same problem here - I got it work:
- Error Correction: off
- V34: off
(both Menu -> Fax-Setup - All Faxes)
- detect-dial-tone: off
(Menu -> Fax Setup - Fax Send setup - detect dial tone)
:-) Stefan
Aug 30, 2008 | HP LaserJet 3055 All-In-One Printer
Jul 24, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Trouble with the fax function
There is no setting to make this work, sorry.
This is just the nature of digital phone service. Some fax machines will work, and some won't, but generally the extremely high priced units are the one that will work (of course, right?)
It all has to do with the way the fax machine "hears" the ring, or detects the dial tone.
The only other option is to use the HP as a scanner, and send the faxes through the internet using a 3rd party fax program.
I know this is a pain, but unless you want to shell out big bucks for a new fax machine, it may be the only answer.
Apr 07, 2008 | HP OfficeJet k60xi InkJet Printer
Lexmark 7350 all in one
Before you begin
To pinpoint the cause of the issue, please record answers to the following questions:
Can a fax be sent or received?
Can a fax be sent, but not received?
Has the fax function ever worked in the past?
Any error messages may also help to narrow down the cause of the issues.
Print out the following:
- a settings list to view the current fax settings
- a receive log if there are issues receiving faxes
- a send log if there are issues sending faxes
- an activity log if faxes cannot be sent or received.
Initial checks
If the fax option has worked in the past and does not do so now, check that the same connection is being used and that it still works.
Check to see if any configuration settings have been changed that could have affected the fax settings.
Faxes cannot be sent/received:
If you are using a digital line, you need an analog card, an ISDN adapter, or an ADSL filter in order to send faxes.
If a PBX is being used, an ISDN Adapter/ADSL filter will not be used as these are supplied within the system. (A PBX is normally used within a company to share a small number of public lines among a large number of private ones to save on cost.) For instructions on configuring the X6100 Series machine with a PBX, see How and When to Use the PBX Option.
Check the phone line (without the printer):
Test the line by connecting a phone directly into the phone port.
Check for a dialing tone.
If you cannot hear a dialing tone, try another phone cable. Once you can hear a dialing tone, you know that the phone port is live and working.
Make sure the RJ11 cable is not damaged.
Check that the printer is accessing the dialing tone correctly:
Press the Options button on the operator panel five times until ON HOOK DIAL is displayed.
Press Select. You should hear a dialing tone.
If you can't hear a dial tone, make sure that the speaker volume is set to High. (Go to Fax, press Options eight times until SPEAKER VOLUME is displayed, then use the plus or minus buttons to change the setting to HIGH. Press Select.)
If there is still no dial tone, unplug the power cable and the phone lead, then plug them back in and try again.
Faxes can be sent but not received:
Connect the Lexmark All-in-One directly to the phone port. IMPORTANT: Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
Faxes can be received but not sent:
Make sure that Country Code is set correctly:
Press the Fax button on the operator panel and then press Options 15 times until Advanced is displayed.
Press Select.
Press Options 13 times and then press the + or - button until the right country is displayed.
Press Select.
IMPORTANT! These tests must be carried out with NO EXTENSIONS, i.e. phones or answering machines, connected to the EXT port on the All-In-One.
Feb 15, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
HP Photosmart C7180 All-In-One InkJet Printer Logo
78 people viewed this question
Seeker5211
Seeker5211
