Question about DeLonghi Cooktops
Connecting a Delonghi hob to kelvinator oven
I need to connect a delonghi 4 plate hob model:''604HX'' to a kelvinator oven.
The delonghi hob has 4 plastic clip in plugs but the kelvinator stove only has a chocolate box to connect the 4 wires per plate to the stove. I need to find the wiring diagram to determine wich wire color needs to go in which specific chocolate box hole.
SOURCE: Wiring installation
You do need a 208/240 volt supply from your service panel. The green is ground, white is nuetral, and the red and black should measure 120 volts each to ground or 240/208 between each other. It is normal for most breaker panels to supply 208/240 between adjacent insulators. If you are only getting 1/2 of that then the circuit breaker may not be straddling the insulator bar but be 1/2 notch out and both breaker pins contacting the same 110 supply.
Posted on Apr 16, 2007
  • 4 Answers
SOURCE: GE JP350 wiring problems
a to black one
b to red one
d to orange
e to grey
a-e to red two
a-d to black two
a-c to orange two
a-b to grey two
a-a to white
Posted on Jan 20, 2008
SOURCE: wiring a cooker top
Thios induction hob (Electrolux) has 4 wires - Y/G, brown. blue and black.
The Y/G is obviously the Earth conductor, and I would assume normality says that
Brown is the live conductor and Blue the neutral conductor.
The quandry is whether or not to disconnect the black wire completely, as this appears to have no function in a domestic wiring circuit.
Regards, Albert.
Posted on Jan 12, 2009
SOURCE: Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Posted on Jun 13, 2009
  • 1865 Answers
SOURCE: how to connect 4 wire into 3 wire existing box.
L1 and L2 connect to the black and red. White connects to White. Green connects to the electrical box if it is made of steel and is grounded. Otherwise the green connects to the whites
Posted on Jun 14, 2009
How to turn oven on on a Kelvinator Cookarama Oven (Older model)?
You need to hold /push the oven control knob in quite firmly while you press the igniter. When it lights up keep holding for about ten seconds then gently release it.
Jun 02, 2014 | Kelvinator Refrigerators
Smalvic gas hob troubleshooting
Where can i buy smalvic ignitions?
Apr 12, 2014 | DeLonghi Cooktops
Hob problems
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
May 19, 2010 | Smeg 28 in. P752 Electric Cooktop
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
just a thought - check the connection block where incoming mains connects to the hob. these quite commonly burn out
Sep 07, 2008 | Cooktops
Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Jun 06, 2007 | Zanussi 23 in. ZKT641H Electric Cooktop
Cooktops Logo
104 people viewed this question
Top DeLonghi Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a DeLonghi Cooktop Expert? Answer questions, earn points and help others
