Question about Polaroid TLA-01511C 15 in. LCD Television
Ariel socket broke
The small bit on the inside of the ariel socket has broke off can i fix it
  • mdoyle91 Jan 03, 2009
    thanx
    lol
    im getting the tv replaced now .
  • 122 Answers
Ya got to pul the panel apart to remove the old connection then you have to solder a new one in place mabey Radio shack might have a generic part to fix it . just trying
Posted on Jan 03, 2009
Where can i buy a replacement veon tv aerial port ?. to replace bent one
It will be difficult to get the body part of a tuner. You're asking about it. The Ariel socket is the part of its tuner. It will look like a small box [inside]; and should be replaced as whole unit. Contact any service technician. http://electronicshelponline.blogspot.com/
The part to replace will look like this.
Mar 24, 2015 | Televison & Video
Toshiba tv no place to insert my ariel
Your problem is the tuner socket has broken off. You can either install anew tuner unit or replaced the tuner socket which is a bit more fiddle.
Jan 09, 2014 | Toshiba 14AF42 14" TV
I have a jeep liberty05 and my oil pan drain plug was put in by last owner so tightly i had to use an irwin east out in doin so with my impact the inside threade piece that the plug screws into broke off...
YOU NEED TO BUY CORRECT SIZE NEW OIL DRAIN PLUG. YOU TO KNOW YOUR THREAD SIZE ON NEW OIL DRAIN BECAUSE YOU NEED THE RIGHT TAP AND DRILL BIT TO CENTER DRILL THE BROKE BOLT IN SIDE OIL PAN YOU NEED A CENTER PUNCH TO PUNCH A SMALL ENOUGH TO START THE DRILL BIT DEAD CENTER OF BROKE BOLT.OIL PAN NEED TO BE REMOVED TO DRILL HOLE STRAIGHT.THIS IN NOT A EASY JOB.EITHER YOU REPAIR OR DAMAGED OIL PAN DRAIN PLUG HOLE. YOU DRILL BIT HAS TO STRAIGHT WHILE DRILLING HOLE DEAD CENTER OF BROKEN BOLT YOU NEED TO MEASURE LENGHT OF OIL DRAIN PLUG BOLT. THEN USE A PIECE TAPE ON DRILL BIT WRAP A PIECE TAPE AROUND DRILL BIT THE DEPT YOU NEED TO DRILL THROUGH BOLT. LIKE I SAY THIS JOB TAKE SKILL AND A STRAIGHT HAND. BECAREFUL WITH DRILL AND WEAR SAFETY GOGGLES. DONT DO THIS FIX IF YOU NOT SURE OF MECHANIC SKILLS YOU WILL EITHER DAMAGE THE OIL PAN OR FIX THE PROBLEM.
Sep 19, 2011 | 2005 Jeep Liberty
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Broken ariel socket
Try Radio Shack.....hope this helps............
Feb 18, 2010 | Radio Communications
My headphone jack broke inside of laptop how to
Unfortunately this can only be repaired by a shop.
Oct 30, 2009 | Acer Aspire 3050-1733 Notebook
Broke ariel knob
yes it can be repaired.youll need to call a tv repair shop and have them come out and fix it but it shouldnt cost alot to repair
Jan 08, 2009 | Samsung HCN436W 43" Rear Projection...
Ariel socket in tv has broken
The best thing is to replace the signal board, that costs $24.
Check here for the part : Polaroid Replacement TV Parts
You find the part on Ebay here.
Part number is 200-013-JK371-1AH FLM-323B
Oct 24, 2008 | Polaroid LCD-2050 20 in. Television
Polaroid TLA-01511C 15 in. LCD Television Logo
42 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
