Question about Welding Tools
Xmt 304 it shows PPP PPP when in the mig selector
Where the volt and amp led aret shows PPP PPP when in the mig selector . any mig from V sencing to pulse mig and just mig.
    Genius:
  • 1,212 Answers
There were a couple options with that model, each with it's own manual.
Generally speaking though, the issue should localized to the switch- a wire may be broken, or if the unit has not been cleaned out/blown out with dry compressed air, it may simply be dirt, especially if the machine acts as if in pulsed mode for all of those settings. If no "HE.L" codes appear, I would look for a short in the switch, meltted wires, shorted wires, or the switch contacts themselves may be dirty and need some contact cleaner. If you have the model with an inductance control, make sure to spray that as well. Look for a small opening into the control to direct the spray.
If you do not have the manual, you can get it here for free:
http://www.millerwelds.com/service/ownersmanuals.php?model
While it is possible to service the circuit boards at the component level in the event of a component failure, parts are sometimes just not available, but that does not mean they cannot be serivced, just that you may need to canibalize another machine for certain pieces and parts. However with that said, most of the potential board failures would trip one of the "HE.L" codes..
Posted on Oct 28, 2012
3 Suggested Answers
  • 2976 Answers
SOURCE: connect ln 9 gma to miller xmt 304 inverter with 14pin recep.
One of your pins isn't wired correctly for your combination.
Posted on Feb 12, 2009
luis_david
  • 407 Answers
SOURCE: when im welding the xmt 304 machine will arc out
Help 5 Display Indicates the right side of the unit has overheated.
The unit has shut down to allow the fan to cool it. Operation will continue when the unit has cooled.
If unit overheats, output stops, a Help 5 message is displayed, and cooling fan runs.
Wait fifteen minutes for unit to cool.
To avoid this problem Reduce amperage or voltage, or duty cycle before welding.
Posted on Jan 22, 2011
I have a HEL p-6 code on a xmt 304 how do I fix it
Sounds like a input power problem . Make sure voltage is correct coming to the unit and wired correctly. I checked a Miller welder recently ,auto link that would come on and weld but not good . Took cover off and it was wired wrong .
Dec 08, 2014 | Welding Tools
I need a heat selector switch for a silver beauty 90100 mig welder or something that will work
Clarke Mig Welder 6 Position Heat Selector Switch Parts
I found a heat selector switch, but I don't know if that's what you need. You can do web search for ' heat selector switches' or' mig welder switches'.....
May 23, 2014 | Garden
Mig welder model# 205680 make a rare noise when turn on
Take the wire out of the hose to the gun and see if noise stops. You may have a short in the Trigger
Nov 16, 2013 | Craftsman 304 FI 95 Amp 120V Flux Core...
I have a miller xmt 304 i bought it used. i have a 12vs wire feeder on it and im not getting power to it. any suggestions on what the problem could be
Hi:
Ok, let troubleshoot this one.
There is only two connectors on your 12VS wire feeder; the lead cable that goes to the + side of the XMT welding machine and the VS cable (Volt Sensing) that goes to you work piece joining the ground cable (don't forget the ground clamp).
a) The mode switch on your XMT must be on V-sense feeder.
b) Your 12VS feeder depending on what kind of wire you are using (innershield) negative side or gas wire + side.
That's it. If there i no spark, there is something wrong with your XMT.
If this was useful to you please vote. Thanks.
Apr 01, 2011 | Welding Tools
When im welding the xmt 304 machine will arc out and the volts will say HE.L and the amps will say P.5 its like it loses ground what does the volts and amps mean when it says that.
Jan 22, 2011 | Miller Welding Tools
My problem is that I went to my local Canadian Tier to get help with ordering a part from you people and they have yet to here from some one at your customer service department it has been two weeks sence...
hello there sorry to hear about the problem you are having :
please try this link ok Black & Decker 13760901 TOAST SHADE SELECTOR KNOB
TOAST SHADE SELECTOR KNOB TRO700T/701T/700S AND 700B. Works with the following models: Black & Decker TRO700B, Black & Decker TRO700S. Black & Decker TRO700T, Black & Decker TRO700W, Black & Decker TRO701T.
[93 in stock] Price: $5.95 More details single_arrow.gif
Sep 14, 2009 | Black & Decker Kitchen Appliances - Others
Welding Tools Logo
246 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
