Question about Kodak EasyShare Z885 Digital Camera
Reset the easyshare cx7330 with new software
Memory card not read in camera, can I update my camera with any software ?
  • kakima Oct 28, 2012
    What type and size memory card?
    Genius:
  • Kodak Master
  • 1,019 Answers
The firmware is at the Kodak website listed under support, make very sure to download the CX7330 firmware.
Posted on Jan 24, 2013
Agent Allan
  • 480 Answers
SOURCE: Memory Card Requires Formatting
Hey B418,
Formatting will delete all your pictures on your camera or memory card. The camera might be prompting you to format because the the camera's memory is full. To avoid losing your pictures I would connect your camera to a computer, download your images to your computer first, and then format the memory.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 01, 2008
SOURCE: new memory card says memory card full
The following memory cards are compatible with your Kodak EasyShare C330 Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your Kodak EasyShare C330 accepts SD Card cards.The largest SD Card card you can use in your Kodak EasyShare C330 is 1GB
Posted on Aug 30, 2008
SOURCE: why is the camera stating memory card is full?
Hello, I have the same camera, I went to buy a Kodak memory card and the Representative was kind enough to ask me what digital camera, he said that the c330 will only take a 1GB SD Memory Card. Hope that helps.
Posted on Dec 05, 2008
SOURCE: kodak easyshare cw330 new memory card reads full....
Camera doesn't support more than 1GB memory card, so better use less than 1gb SD card
..........Prashant
Posted on Mar 13, 2009
  • 1566 Answers
SOURCE: Kodak Easyshare C533
This means that the internal memory of the camera is full. Apart from the external memory slot, camera's have this what you call internal memory. It is built-in to the unit itself.
What you want to do is to set the default storage to the external memory instead of the internal once.
On the Menu, navigate to image store and then choose AUTO.
Auto (default)—the camera uses the card if one is in the
camera. If not, the camera uses internal memory.
Internal Memory—the camera uses internal memory,
even if a card is installed.
Also, you would want to set the camera resolution to a lower value to. The higher the pixel rate, the bigger space it eats up in your memory storage.
Posted on Aug 15, 2009
We bought a 4GB SD Card, but the camera fail to format the card. We've tried formatting the card on computer but it still didn't work after inserting back in the Camera.
To correct a Memory Card Lock:
one the side of the memory card is a plastic toggle switch, slide it down and up again to reset the switch and then stick it back into your camera.. see if that fixed the problem.
SD SDHC Card Problems and Fixes Card Locked Card Error No Memory Card...
Jul 19, 2015 | Kodak Easyshare CX7530, CX7430, CX7330,...
My pictures say unrrecognized file format. why? it is also not on every picture
Is the camera or memory card new? you may have to format your memory card. unfortunately all the pictures on it will be erased, but its the only thing that will let you take pics and save all of them. I found this out when i got my new camera. I used an old memory card and had to format it.
Apr 18, 2011 | Kodak EasyShare CX7330 Digital Camera
Memory card is protected, how do I remove it, if i can, I have a Kodak Easyshare cx7330
Look at the card. SD (and SDHC) cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 05, 2011 | Kodak EasyShare CX7330 Digital Camera
Camera tells me "memory card requires formatting."
Your memory card is larger than 2GB, isn't it? The CX7330 works with MMC and SD cards. If your card is larger than 2GB then it's actually an SDHC card. While SDHC cards will fit into the camera, they are electronically incompatible and won't work in the CX7330.
Dec 20, 2010 | Kodak EasyShare CX7330 Digital Camera
Trying to format a new SDHC card but it won't format
The CX7330 is designed to work with SD cards, not SDHC cards. While SDHC cards will fit into an SD slot, they are electronically incompatible and will not work.
Dec 02, 2010 | Kodak EasyShare CX7330 Digital Camera
4 g memory card will not format, tried moving switch, etc
Remove the memory card from your camera, put it into a card reader, connect it to your pc and format the card from your computer.
I hope this is helpful
May 23, 2010 | Kodak EasyShare CX7330 Digital Camera
We can turn on the camera, but the OK button does not wok.
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 27, 2009 | Kodak EasyShare CX7330 Digital Camera
Memory card is protected how do i switch on memory card when i turn camera on, message reads that the memory card is protected and to reset switch on memory card. what happened?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 11, 2008 | Kodak EasyShare CX7330 Digital Camera
Cx7330 connection problems
try a different USB port (if running vista) - or try not plugging into a USB hub if doing so.
Mar 19, 2008 | Kodak EasyShare CX7330 Digital Camera
Can't download my pix to my computer
monkey1,
As this is an old post, do you still require help?
Have you contacted Kodak tech support?
Apart from the Kodak software to connect the camera, you could use a USB card reader.
Take the memory card from your camera and put in the card reader.... it transfers MUCH faster than directly from the camera too.
May 27, 2007 | Kodak EasyShare CX7330 Digital Camera
Kodak EasyShare Z885 Digital Camera Logo
43 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
