Question about Brother Sewing Machines
Brother se350 has error code F07 speed vr break
Se 350
4 Suggested Answers
SOURCE: Brother SE-350 "The safety device has been activated"
Return the bobbin winding shaft on the top right of the machine to the Left Position. It may be stuck in the middle.
I had this same problem. After an hour or two of fiddling, this fixed my problem.
Posted on Nov 03, 2010
  • 11 Answers
SOURCE: I need to find a repair or technicians manual for brother se-350
Hey if you need a new manual go to this link www.ifixmachines.com and dont forget to put this code (150t) so you can get $1.50 discount. Hope this help.. By the way the manual cost only $10. BYE
Posted on Jul 22, 2009
SOURCE: brother SE-350
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&type2=-1&prod=hf_se350eus&c=us&lang=en&flang=all
Posted on Oct 06, 2009
Good afternoon, My Brother sewing mach. has a error of f7 what does this mean. The model is Cs80
According to http://www.sewingmachinesplus.com/brother-sewing-machine-error-code-f7.php
the meaning and answers are as follows...
Q: What does F7 error message mean?
A: Speed VR disconnected
Q: How to fix F7 error message?
A: Unplug the sewing machine and reconnect any loose wires on the SSVR PCB assembly and the main PCB assembly. If the wiring connections are okay, replace the SSVR PCB assembly. If the problem persists, replace the main PCB assembly.
Jan 10, 2017 | Brother Sewing Machines
How to replace spool pin on brother se 350 sewing machine
Is this a chromed metal shaft that stick straight up?
IF SO, the broken piece can be PROBABLY be unscrewed using pliers. Then you have the thread size, the piece, that you can take to a hardware store and get a long blot this the same threads.
The part can probably be found on the internet using google.com or on eBay.
92results for Brother sew spool pin
Mar 18, 2015 | Brother SE350 Mechanical Sewing Machine
How do I adjust the tension on brother SE-350?
Before you go adjusting tensions, make sure your upper thread is threaded properly. Always thread with the presser foot in the UP position so the thread can slip easily between the tension discs. Also make sure there are no wraps around the thread spool spindle.
Be certain that you have the bobbin properly inserted as well.
Once you are absolutely certain that there is no issues is threading. The tension is adjusted by a wheel on the top of the machine. Left to loosen, right to tighten the tension.
Jul 04, 2014 | Brother SE350 Mechanical Sewing Machine
Can you change the port where the embroidery card attaches on a Brother SE-350?
Hi Marla,
If your machine supports a USB connection to your computer, you may be in luck getting designs to and from your machine. In the meantime, the bent pins may cause issues, but if there a standard
USB cable A to B (printer cable) available you may try that. If I recall there will be some settings to check but that is another way to get designs in and out of the machine.
Cheers,
Kelly
San Diego, CA
EmbroideryServices
May 21, 2014 | Brother SE350 Mechanical Sewing Machine
While sewing the thread will break
Take a small piece of material and take several practice runs of a straight stitch. If the cotton breaks try adjusting the small tension wheel (numbered 1234 etc) . To decrease tension turn to a lower number. Adust as necessary until you get a satisfactory stitch.
Jan 30, 2011 | Brother SE350 Mechanical Sewing Machine
Dec 22, 2009 | Brother Sewing Machines
Jul 21, 2009 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
375 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
