Computers & Internet Logo
Anonymous Posted on Oct 28, 2012
How to fix Blue SCreen of Death - HP Computers & Internet
Brian Sullivan
Level 3:
  • HP Master 27,725 Answers
  • Posted on Oct 29, 2012
Brian Sullivan
HP Master
Level 3:
Answers
27725
Questions
Helped
5664428
Points
79191
BSOD Bluescreen of death can be caused by a number of things
A bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to fail
make sure all leads have a dust free secure connections
A bad driver loose or faulty lead or not having enough ram
you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to
compatible ram also you will have an option to scan your system
you should always ask the seller if they guarantee the compatability of the ram before making any purchase
if you dont want to install more ram uninstall some unnecessary programs
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
if you can get a screen
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
hope it helps
1 Related Answer
Anonymous
  • 36 Answers
  • Posted on Jan 08, 2009
SOURCE: blue screen of death
Try booting in safe mode (F8 when windows begins loading) and see if everything is ok. If it is, then try safe mode with networking, if that works, but then the problem persists, back up your data and reinstall windows. You likely have a corrupt DLL file somewhere.
My screen keeps switching from blue to desktop and back to blue
BSOD = BLUE SCREEN OF DEATH
This is mainly due to a driver issue, application error or worst hardware issue. Click below for more info.
How To Fix Blue Screen of Death BSOD
16helpful
3answers
Why screen is black out.
On my Windows 7 laptop, I got problem of Black Screen of Death, Windows Boot Genius fix the problem without data loss! I vote it!
Hey do you guys know any tech does work voluntary to fix blue screen problem
3 Easy Tactics on How to Fix Blue Screen of Death The famous windows Blue Screen of Death(BSOD Error) can be fixed with 3 types of Blue Screen Death Repair. Try to apply the following tactics when the blue screen death occur before you call a computer expert for help.
1. Uninstall any programs which you had installed recently.
Sometimes, there exists a conflict in drivers installed on your pc that causes the blue screen error to pop up. In most cases, this does not occur, but if it does, Windows offers you a roll back feature where you possibly can bring your PC’s operating system back to its original functioning state.
2. Random Access Memory is faulty.
When the Random Access Memory is faulty, the Computer stops functioning everytime when the RAM is accessed by the CPU. This brings about your PC to halt almost at Random. A simple solution is just to remove 1 stick of RAM and see if the problem goes away. If it does, your PC is fixed!
3. Repair Registry Errors to fix the blue screen of death
Over time, the registry of your windows will get messy with tons of data because you always install and uninstall programs or applications. When you experience slow performance in your PC during boot up times, opening up of new files, surfing internet and blue screen of death, its likely that your registry has a ton of information which needs to wade through. Therefore, it is highly recommended to get a good registry cleaner and improve the performance speed of your PC. Errors fixed in your registry can also fix Blue screen of death error instantly.
2answers
How-To Repair Blue Screen and Safe Mode
if u wanna rid of the blue screen follow this link
http://ezinearticles.com/?Blue-Screen-of-Death---How-to-Remove-the-Windows-Blue-Screen-of-Death-For-Good!&id=1752190
Update the Operating system.
Update the Iphone too
Should cure the problem.
Richard.
2answers
Try to reinstall windows by repairing it.
2answers
r u sure the monitor is causing the blue screen of death?
I would try another monitor to verify.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
