GWhen I was cooking some noodles the container full of water spilt and leaked all over my mricowave. After I was cleaning it up I noticed it would't turn on. When I turned it to it's side I noticed some water dripping out so I think it has water in it. How can I fix this?
You will need to leave it open to air dry for a couple of days. Be sure to leave the door opened!
Posted on Oct 29, 2012
SOURCE: Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Posted on Apr 04, 2007
SOURCE: Water leaking from water dispenser
lot of water coming from under the refrijerator
Posted on May 21, 2008
SOURCE: Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Posted on Aug 13, 2008
SOURCE: We have a TFX25JR side-by-side with ice maker and
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Posted on Oct 07, 2009
SOURCE: Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an
adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water
inlet valve on the back where the house water supply comes in.
Posted on Nov 16, 2009
Apr 07, 2016 | Cooking
Oct 08, 2014 | Cooking
Feb 20, 2013 | Cooking
I love
cooking pasta in my microwave as I don't have to wait for the water to come to
the boil.
Put your pasta in a large bowl with lots of water and season. I cook my pasta for around 10 minutes and stir it half way through. Test one piece and if you want to cook it for longer just bung it back in.
In terms of
water to pasta ratio, you should use around 4-6 quarts of water for every pound
of dry pasta. Once the water has come to the boil add the pasta and then bring
it back to the boil. Add some salt, stir occasionally and follow the
instructions on the packet to find out how many minutes to cook it for.
Jun 23, 2011 | Refrigerators
Mar 05, 2010 | Culligan Sediment Water Filter Heavy Duty
Jan 19, 2009 | Pool & Spa
Feb 25, 2008 | Solis Master 5000 Espresso Machine
Apr 22, 2018 | Refrigerators
37 people viewed this question
