Sherwood ax-2000c no power - Audio Players & Recorders
2 Suggested Answers
  • 6771 Answers
SOURCE: SHERWOOD CDC-2000C ?D6376 starts skipping
Unfortunately the laser pickup assembly needs to be replaced, overtime the laser becomes weaker until it can not track properly and will end up skipping or won't read the disc. It is far cheaper to replace the CD player than have the assembly replaced.
Posted on Mar 19, 2011
Testimonial: "Thanks for the quick response, will now look for as capatable unit"
Sherwood ax 3030r
What is the question? More information is needed before somebody can help you. What type of watts are you asking, power input, output, music, RMS, etc.
May 14, 2014 | Audio Players & Recorders
Sherwood AX-4103 amp keeps clicking
Hello there.... Check your speaker wires and then if that doesn't do it? try replacing the fuses on the back of the amp.. make sure power is turned off and unplugged. If that doesn't work? Try one speaker at a time ... something is causing the system to short out. Hopefully it is not internally
Apr 21, 2014 | Sherwood Audio Players & Recorders
SHERWOOD CDC-2000C ?D6376 starts skipping it was sent to be repair played about 2 discs when I got it back and started skipping again
Mar 19, 2011 | Sherwood Audio Players & Recorders
The main transformer in my Sherwood amplifier is down the primary winding is open circuit. I cannot find the transformer outputs as to replace it. does any one know the voltages and current ratings for...
I would contact Sherwood as Transformers are deemed to be safety components and should be replaced with excat parts or those recommended by the maker.
Jan 25, 2010 | Audio Players & Recorders
Sherwood AX-4050R Amp - faulty RCA inputs
It is rare for the actual input connectors to fail. More likely, either the solder connections need to be re-flowed, or the switching IC is defective. If you can solder, try resoldering the pins of the RCA connectors. Look closely at them and see if the PC board trace is broken. If the resoldering fails to resolve the problem, look for a switching IC with about 28 pins. It may be marked TC9163 or something similar. That will be the audio switching IC. I would change that next.
Dan
Nov 25, 2009 | Sherwood Audio Players & Recorders
Sherwood AX-7030R don't work
Try Googling (Sherwood)(AX-7030R)(manual) without parens.
Dec 20, 2017 | Sherwood Audio Players & Recorders
Sherwood AX7030-R
I have a number of suppliers that can deliver internationally or are located in Europe. If you can list the part, I may be able to locate a few alternatives that might be more readily available as well.
Dan
Dec 17, 2008 | Sherwood RV-7050R Receiver
Sherwood AX-7030R amp - doesn't switch on.
Something doesn't sound right. The standby circuit is usually very simple. The "regulator" is just a transistor. Can you request and post the parts that he/she can't find. I should be able to get you a source or substitutes.
Dan
Dec 16, 2008 | Sherwood A-965 Amplifier
48 people viewed this question
 Grubhead
Grubhead
