Question about Cisco Aironet 1131AG 802.11a, 802.11g/b (746320933474) Wireless Access Point
How do I setup a Cisco Aironet 1131AG using console port
SOURCE: cicso 1131ag Drops off
Meru
Posted on Mar 06, 2008
  • 5 Answers
SOURCE: configure cisco aironet wifi
if ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Posted on Jun 19, 2008
SOURCE: how to reset Cisco Aironet 340 Wireless bridge?
Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
    For more information, refer to the Cabling Guide for Console and AUX Ports.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal. Other programs are similar.
  3. Enter a name in the Connection Description window.
  4. Select an icon for the connection.
  5. Click OK.
  6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
  7. Click OK.
  8. In the Port Settings window, make these selections:
    • Bits per second (baud): 9600
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
    • Flow Control: None
  9. Click OK.
  10. In the Connection Description window, enter a name and select an icon for the connection.
  11. Click OK.
  12. Press Enter.
  13. When the Main Menu screen appears, reboot the bridge.
    Turn the unit off and then back on.
  14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
  15. Press Enter.
  16. Enter Yes.
  17. Press Enter in order to confirm the command.
  18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
see this link 340 Wireless Bridge
Posted on Jul 25, 2008
  • 30 Answers
SOURCE: How can I change the default management vlan (vlan
create a new vlan (eg vlan 10)
then ensure that the ethernet port is the same bridge group number as the new vlan (bridge-group 10)
do the same for the wireless port
then shut down vlan 1
Posted on Dec 05, 2009
  • 30 Answers
SOURCE: radio0 and radio1 "not installed" problem on Cisco 1131AG
check that you have enough power on the PoE to power up both radios. Switch one off for clarity and see if 1 powers up. Also check the log of the AP and the PoE switch as it will report the power related issue if it is a pre- PoE approved switch
How to configure cisco aironet 1131 and how to find the getaway for this router ?
Have you read the quick start and installation guides?
http://www.cisco.com/en/US/products/ps6087/prod_installation_guides_list.html
Yes, the AP should be able to obtain an IP address via DHCP from your
Netopia router.
If this device is used, it may not be setup to aquire things via DHCP,
and you'll probably have to hookup over a console port and do password
recovery.
Cisco's aren't the easiest things to setup, they are more akin to a
box of tools, rather than a single purpose built item, and thus can
do quitealot, but you have to learn how to use the tool first. It will
then let you setup things quite advanced that the single-purpose built
item never imagined, but you have to know how to get there first, not
coast and do the advanced stuff later.
Dec 29, 2013 | Cisco Air-Ap1131G-A-K9 - Aironet 1131G...
My Cisco aironet 1141N-ke9 showing red blinking continuously and stuck in that .Now only access via console.Can any one solve it
Sounds like the network connection to the AP is shot. Try a different cable, different port on the switch, or repower the device.
Aug 05, 2012 | Aironet Air-ap1141n-a-k9 Cisco 1140 Series...
Default username & password after hard reset
Username:[none]
Password:Cisco or
:root
:Cisco or
:Cisco
:Cisco
Try from above 3 then you can access cisco router.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 01, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Can I hook a 1131ag LWAP directly to a 7941g?
If the 7941g is the cisco cp-7941g ip phone then no you can not since the ip phone only has ethernet connections and the airap1131agak has only wireless connections on it as it is a wireless access point, so you will need a wireless router or something similar to get the wireless to ethernet cable.
Oct 29, 2009 | Cisco Aironet 1131AG (AIRAP1131AGAK)...
Radio0 and radio1 "not installed" problem on Cisco 1131AG
Mar 12, 2009 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Wireless power problem
After researching Cisco site. And testing. I suggested the coutomer log on to the device and adjust settings. It turns out the unit when using a power injector goes into a Power Managment mode. The unit goes to half power and can cause problems.
Thanks for the help.
Jun 10, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Configure cisco aironet wifi
Jan 17, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Erasing the flash....
Toast...looks like you killed your entire IOS installation...it will have to be reloaded to the flash...
Aug 21, 2007 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Cicso 1131ag Drops off
How are attached / verified by the LAN? Do you have a RADIUS server for the certificates?
Oct 27, 2006 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Cisco Aironet 1131AG 802.11a, 802.11g/b (746320933474) Wireless Access Point Logo
162 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
