Question about Denon AVR588 Receiver
Onkyo 506 zone 2 no sound
Speakers through main cinema system carry all sound however when i just want sound in zone 2 no sound is heard but the sound source is still on in main cinema room .Speakers are connected as per instruction manual with zone 2 powered spkers switched to on via speaker config
I believe that you can only get analog signals thru zone 2 (i.e radio, cassette player), kind of a ripoff since they bury this info in the manual
Posted on Feb 10, 2009
I have and onkyo tx sr-506 receiver and it has no sound on zone 1 , but zone 2 works normally . what can it be ? where do i look for ?
Hi Leonardo, I am sorry about your issue. I suggested taking it to a service center. Thank you. Onkyo USA
Sep 14, 2016 | Onkyo Audio Players & Recorders
I have 2 qustions?
my guess is that the yamaha has pre-amp outs, most yamaha stuff does, and that is the one you should be using for the main, and hooking up to the onkyo, and letting the yamaha be your zone controler, and the onkyo be your remote amp for your second zone (if your onkyo had pre-amp outs it would work how your trying to do it, but it dont) so exchange there places, and run a pre amp out to any input of your onkyo, and you'll have total volume control of your outside speakers
Jul 28, 2013 | Onkyo Audio Players & Recorders
I have an Onkyo TXNR609 home theater receiver hooked up to a 6 speaker surround sound setup in the living room. I also have 2 speaker pairs outside - one on the downstairs patio and one upstairs. I was...
If you haven't done already, then verify that zone 2 works without the selector. If the speakers definitely work and the zone output definitely works then the speaker selector must be the culprit! It's pretty difficult to mess up the wiring with speakers, as even if polarity is reversed, you will still hear something.
Sep 23, 2011 | Niles SSVC2 Two Pair Speaker Selector...
I have a Onkyo TX-SR604 Receiver. I get no sound
Hello Fixya customer,
Thank you for your question.
A point to keep in mind here is that Zone II will only feed through an analog source. Since the Video 1 input is using the digital (coax, optical) input that that is your most likely issue.
Thank you for using Fixya, and please let me know if I can firther assist.
May 01, 2010 | Onkyo Audio Players & Recorders
Onkyo tx-sr601 bi wire with zone 2
SMCCARTY,
The idea behind bi-wiring speakers is to get the highest quality of sound by getting the sound from two separate sources doing separate jobs. Lower frequencies are harder for an amplifier to produce than higher frequencies. So it is common to give these frequencies to two different amplifiers so each can produce the highest quality of sound. By removing the low end from the top end amplifier, it provides the top end amp more headroom thus reducing the chances of clipping. Clipping can easily be heard from the tweeters destoying not only the sound but your speakers as well. It is common practice in pro and car audio to use separate amps for subbass, low, mid and high; four amps working together to their corresponding drivers (more or less depending on the system and type of audio being produced).
In your case, getting the two different sources from basically the same amp (power supply), would not accomplish the full intent of bi-wiring; it would just make more wiring for the same end result. However still a good thought on your end. Onkyo receivers are great because of their beefy power supplies. Not very many other brands have such strong power supplies. Denon's are close but not equal.
Chris-
Feb 14, 2010 | Onkyo TX-SR601 Receiver
No sound from rear speakers
Hello, the setting must be "Not Activated" That is for zone 2 setup. If you are setting up 5 speakers the rear speakers should be connected to surround not surround back. Thank you Onkyo USA.
Mar 25, 2017 | Onkyo TX-DS898 Receiver
Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Aug 03, 2008 | Onkyo TX-SR803 Receiver
No sound from main speakers.....
WHEN YOU SET ZONE 2 ON DID IT ASK YOU TO OUT PUT ZONE 2 ONLY OR MAIN + ZONE 2? IFF SO TRY SWITCHING MAIN ON AND IFF THIS DID NOT WORK MAKE SHURE SPEAKERS ARE SWITCHED ON IN MAIN MENU.
I KNOW THIS IS 2 LATE 4 YOUR NEW YEARS PARTY BUT I JUST FOUND THIS SITE 2DAY.
HOPE THIS HELPED.
CABLE GUY.
Dec 25, 2007 | Onkyo TX-SR601 Receiver
Onkyo 605 Reciever no sound from zone 2 RCAs
did the AS amp ever work properly from the RCA's?
Dec 05, 2007 | Onkyo TX-NR801 Receiver
Zone 2
if you have a main speaker system working properly, takea known good amp to ch2. wire the main pre amp out to amp 2 input.. turn both units on(no spkrs connected), fire it up. if the amp does not go into protect mode, turn ALL power off to the system.,connect one Spkr channel on A2, AND TURN THE VOLUME DOWN FIRS!!!!. pOWER UP THE SYSTEM AND SEE WHAT YOU GET.BE GENTLE WITH VOLUME SETTINGD! If ch 1 works, repeat procedure with ch 2 pre amp out.
Nov 11, 2007 | Onkyo TX-NR801 Receiver
Denon AVR588 Receiver Logo
218 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
