C62 error code - NASHUA 8112RE
Error code displayed as soon as machine switched on - NASHUA 8112RE
  • nigel_p_edwa Jan 05, 2009
    Thanks for trying. This is an old copier that decided to stop working. Regards
  • Jessetech May 11, 2010
    need to know what copier there all differant
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Is this right out of the box?? If it is, make sure that you have removed all the SHIPPING SCREWS. Check for the one that holds the optical scanner. If this screw is left in the scanner will not move and cause error. ---should be on left side or under left side of optical pan. If all shipping screws are removed, do a once over and check to make sure that all shipping tape and paper are removed. Some companies use tape to hold parts in place.
Posted on Jan 04, 2009
Error code J020 on a Nashua Aficio MP C 2050
You must call Customer Care for the support. Entering the wrong way can permanently damage your printer. Just a call at +1(800) 243-0051 Toll Free
Apr 27, 2017 | The Office Equipment & Supplies
How can i fix a SC- 546 error on my NASHUA Aficio 2018D all in one problem
You could try to reset the error, but it may come back. Here is the key sequence for resetting:
CLEAR MODES
7
STOP (hold down for three seconds)
You can then switch the machine off then back on. If the problem comes back, then you will need to have your fuser unit repaired.
Mar 13, 2011 | Office Equipment & Supplies
I have nashua aficio mp161spf and it display the message sc500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
Nov 08, 2010 | Ricoh Aficio 1013F Copier
I have a Nashua sc550 Aficio 1013. Its displaying error SC550. message displayed is "Functional problems, turn off main power switch then on again. If error reoccur, call service" Best regards
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
ERROR CODE SC329 IN NASHUA AFICIO 3445
ca 107 c then inter the sp mode then clear error
Jan 14, 2010 | Ricoh Aficio 450 Copier
ERROR CODE SC329 IN AFICIO 450
Laser synchronization error
The main scan synchronization
detector board cannot detect the laser
synchronization signal for more than 5
consecutive 100 ms intervals
Need help
we do not have that brand in the US The only E1 problem I can find is for Toshiba and Xerox ( is that who makes Nashua??)
E1 is paper jam inside machine, look for paper on sensor
Feb 03, 2008 | Kyocera RI-3530 Black and White Copier
149 people viewed this question
jasbo
jasbo
