Question about LG DLG5932W Gas Dryer
LG DLG2524W DRYER WORKS FINE EXCEPT DOESN'T HEAT UP
DRYER SEEMS TO WORKING FINE EXCEPT DOESN'T HEAT UP. CIRCUTI BREAKERS NOT TRIPPED. VENTING SEEMS NOT TO BE BLOCKED. TRIED REMOVING FRONT PANEL TO CHECK HEAT ELEMENT BUT NOT SURE HOW TO DO. WILL TRY TO CLEAN,. ANY SUGGESTIONS
  • 8 more comments
  • Rob Ohnikian Jan 03, 2009
    DLG2524W. MIGHT HAVE USED THE WRONG TERM. TRIED CLEANING THE PART THAT IGNITES THE GAS. READ IN A PREVIOUS POST THAT RESETING THE DIME SIZED THERMOSTAT NEAR THE GAS VALVE. I COULDN'T LOCATE. ALSO HAVE PROBLEM REMOVING LOWER PANEL. LOOKS LIKE UPPER CONTROL PANEL HAS SCREWS BEHIND IT THAT HAVE TO BE REMOVED. I CAN'T REMOVE UPPER PANEL TO REMOVE LOWER. THANKS
  • Rob Ohnikian Jan 04, 2009
    YOU HIT THE NAIL ON THE HEAD. THANKS FOR THE DETAILED DESCRIPTION.
  • Anonymous Jan 20, 2009
    i have the same model dlg2524w an its gas i cant find the dime size reset pin
  • khutchins Jan 24, 2009
    I have the same problem. Gas ignites runs for 2-5 seconds then shuts off. I found the thermo switch and have pushed it but same problem exists.
    What part do I need to replace?
  • no1cubsfan Apr 04, 2009
  • I hate LG Apr 07, 2009
    Have done all this. Does the pin in the high limit thermostat push in easily?? Does it just take a light push or does ir actually have to go in. I see a bit of copper between the top of the pin and the thermostat--does this need to disappear when it is pushed?? An answer would be great.
  • hncohen Apr 30, 2009
    Model LG DLG2532 Gas Dryer,  does not heat.  Service came and removed the upper (top) panel and reset something inside. Have same problem again....what did he reset?
  • I hate LG May 11, 2010
    Do you know the part number for the High Limit Thermostat.
  • no1cubsfan May 11, 2010
    Is this solution for DLG2524W model? My Dryer suddenly stop having heat.
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    You mention a heat element (electic dryer) but post under a gas model. What is your model number?
  • 1,543 Answers
1. Open dryer door and remove the phillips head screws at the 5 and 7 O'Clock positions. 2. Remove three screws at very back, allowing top cover to be moved back about an inch and lifted off. 3. remove screw at top left and top right from front top panel. 4. pull plastic front panel along top edge to release front top panel. (watch for sharp edges) 5. Swing top up and over onto top of dryer. 6. Unplug light and door switch. 7. remove four screws at top of large lower panel. 8. lift panel up a bit and off. 9. unplug sensor plug at bottom allowing panel with door to be set aside. 10. gas dryer has dime sized high limit thermostat on left front side of burner chamber. Has two wires on it, with a small pin in the center. Push the pin in. Reassemble and clean out vent, eliminating flexible venting, replacing with rigid aluminum piping and elbows. Outside vent should have a four inch vent flap opening, not just a two inch if it is that style.
Posted on Jan 03, 2009
Testimonial: "YOU HIT THE NAIL ON THE HEAD WITH THIS SOLUTION. THANKS"
  • Juan DeHaro Sep 22, 2013
    Perfect instructions. My dyer works good now. Thanks.
LG DLG2524W gas dryer with check filter light on. Dryer will work but no heat. Totally vacuumed filter and filter area out. Opened cap on bottom side of dryer and vacuumed that out but still same thing....
It sounds like the high limit switch has tripped. You will need to disassemble the dryer to get to the switch to reset it. LG recommends replacing the high limit switch.
Aug 05, 2011 | LG Dryers
Dryer seems to work (runs, tumbler turns, timer works, air flows) except there is no heat. I see that there could be several reasons for this, how do I isolate the problem and fix it?
First look for reasons why safety components would trip and remedy them thangsthemobilian_1642.jpgthemobilian_1643.jpgthemobilian_1644.jpgthemobilian_1645.jpg
So once we have that ironed out we now have an idea where to look first. If the dryer is clean and the vent is clear and you still have no heat then one of your heating components have failed. The heating components are the element, coils, sensors, ignitors and controls.
So if the element is bad simply replace it and you now have heat but what if the element is ok?
themobilian_1648.jpgthemobilian_1649.jpgthemobilian_1650.jpgthemobilian_1651.jpgthemobilian_1652.jpgthemobilian_1653.jpgIf your ignitor and flame detector is fine you may have the very common problem of weak coils themobilian_1654.jpg
If it turns out thet your safetys are fine and your heating components are fine then you could have a bad controlthemobilian_1655.jpg
If your control is fine you could have a bad circuit breaker.The motor on American machines is 120 volt of alternating current but the 5000 watt heating element requires 240 volts.themobilian_1656.jpg
I have include a dozen or so Dryer service manuals and more HERE
Let Me Know.
Mar 03, 2011 | Dryers
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
The timer will not advance, it heats up on the correct settings, but will just stay on indefinately. Sounds like a classic Timer issue, but just want to ask for a second opinion, and ask what the part...
We have a dryer ( could be any make! ) that is consistently blowing fuses after about 15-20 minutes. We have taken the dryer apart to check for clogs in the venting system and to check if the heating core was okay and they seem to be fine. Any ideas?
Blowing the house fuses? If yes....the dryer usually will blow a fuse right away if there is a problem in the dryer....more often than not a fuse that blows after the dryer has been running a while it is a fuse box issue. A test: Put 2 new 30 amp fuses in and run the dryer with the heat on for 5-10 minutes, turn off the dryer and quickly remove the fuses from the house fuse box and see if they are hot at all ( especially on the bottom )....if the fuses are getting hot they are probably melting the fuse link and not really blowing = fuse box problem.
As for most things there are exceptions....a grounded heating element -may- blow the fuse after the dryer has been on for a while, it is easy to test for that as well. See. A burnt/loose power cord/plug -may- also give this type of a problem.
Dryer basics- Venting problems and power supply:
Most dryer "to long to dry" or "poor/low heat" complaints can be traced back to a bad or poor venting system and sometimes a poorly maintained lint filter. Do not go outside and put your hand under the vent opening and say " it is fine - I feel air coming out"...that is not good enough...take your venting apart, clean it ALL out and make sure the vent hood flapper works and that it is not clogged with lint. Make sure your venting system is short, straight and resistance free as possible. A poor venting system will shorten the life of your dryer, plug up the fan blower and duct work inside your dryer as well.
Gas dryers need 120 volts to operate the whole dryer. Electric dryers need 240 volts to operate the heating element and 120 volts to operate the timer and motor. You should see 240 volts between the black and red wires, 120 volts between the red and white wires, 120 volts between the black and white wires at the electric dryer main power harness. A blown house fuse ( or breaker ) would stop a gas dryer from working at all. A blown house fuse ( or a 1/2 tripped breaker ) would still allow the electric dryer to run but you would get no heat. Depending on which fuse goes, sometimes the dryer could be dead as well. If you have problems with a fuse letting go or a breaker tripping after the dryer runs for a while, normally the problem is not in the dryer but is in the fuse box.i think it will work
Dec 16, 2010 | Dryers
LG DLG2532 dryer not heating up, lint trap clean, good air flow out exhasut vent, all controls seam to be working i.e. lights on buttons and chimes good, seams like its not getting gas but valve is turned...
Hi, Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Apr 16, 2010 | LG DLE2532W Electric Dryer
No heat-Kenmore (Whirlpool) Elite He5 Steam 110.8775
Check that there is 240 volt at the plug as sometimes a breaker will be weak on one side and only produce 120 volts which will let the drum spin but produce no heat
Mar 20, 2010 | Kenmore Elite 45986 Front Load Washer
Lg dlg2524w runs and tries to heat but doesn't
Our electric did the same thing...techie guy said it was working fine, suggested I clear the dryer lint vent pipe which I tried but it was destroyed so I had to rebuild the whole line which took a day of messing around with the wall behind the unit, the ceiling exit hole and in the attic some. But Man!! it works great now!! All that heat and moist air has to go somewhere away from the machine, or it just goes back into your clothes. Super important. Good luck!
Mar 25, 2009 | LG DLG5932W Gas Dryer
I just moved and my LG dryer does not heat up.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Heating element
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
Dec 01, 2008 | LG DLG5932W Gas Dryer
Dryer internal breaker trips
If you are using dryer sheets in the machine the filter screen may be plugged and will have to be cleaned. You can check it by placing a bit of water on the screen if it beads and does not flow through then the screen is indeed plugged reducing air flow. There could be lint and build up in the dryer's internal ducting and sensors, the machine will have to be disassembled for a complete cleaning this will also reduce air flow and cause the machine to heat abnormally.
Mar 01, 2007 | Asko T731 Electric Dryer
LG DLG5932W Gas Dryer Logo
1,280 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
