Question about Garden
John deere 7420 bcu 302085 fault code - Garden
3 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Posted on Nov 14, 2009
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
  • 100 Answers
SOURCE: Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Posted on Oct 26, 2012
I'm getting a Hitch System BCU 33 message. John Deere 7430 what did it mean and what do I do to fix it.
Hi this is an informational code, if you call you dealer they can tell you. I'm sorry I can't tell you. 33 is not a basic code.
Jan 21, 2017 | John Deere Garden
I hav a john deere 4320 tractor that is showing a fault 13.....what does this mean
I don't know what the code would be but found a site you might be able to find it on.. www.booklad.org
I serched for your model and it came up with this site. Hope this helps
Feb 01, 2015 | John Deere Garden
Have a John Deere 7330 with a default code of BCU
BCU 523745 .31 HMS HMS program switch, fault.
Oct 18, 2014 | Garden
John deere codes
unhook battery for 20 seconds hok back up code should be clear if not take it in something is wrong
Aug 24, 2014 | Garden
Oct 25, 2012 | John Deere Garden
SOME ONE GIVE ME THE UNLOCK CODE FOR JOHN DEERE DRIVE GREEN PLZ
if someone is iknd enough to E-mail me the unlock code of john deere drive evergreen to shleroux@gmail.com
Tanx it will really be nice!
Sep 18, 2010 | John Deere Drive Green Farming Pc Game...
Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
May 17, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
I try to start a 7420 deere tractor and she wont go. i
You need to check your fuel lines from the tank to the filter head and the lines from the filter to the fuel cooler in front of the radiator.If all are goo and the fuel pump is running then you may need a fuel filter.If the fuel is not an issue then you need to call the nearest j.d dealership and give them the stored codes[the operators manual will tell you how to retrieve them].If any lines are wet with fuel then they need to be replaced,a long running problem with Deere.
Jan 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Lights malfunctioing on John Deere 6910, lights on right hand display flashing. Is this a fuse/relay problem?
Can you tell me which light is flashing,first red one second one in etc.?The first light is the glow plug light and if that is flashing it means the engine has de-rated and you need to find out why.To get the codes that may be stored you can remove the fuse cover and put a 10 amp fuse in the cal location in the fuse panel and the the dash will say diag,when this appears turn the right turn signal on for a sec and the dash will change to all signal again to change the dash until it gets to bcu the turn the hazard lights on for a sec ,now right signal until you get to address 1.Now you hit the hazard switch again right signal and record the numbers in the dash,keep doing this until the image clr appears.Turn off the ignition and remove the fuse.Either contact me with the code numbers or contact your nearest dealership and we will be able to tell you where to look-thanks and good luck!
Dec 26, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
