Question about Panasonic Televison & Video
Disc tray doesnt open on model panasonic SA-HT720
5 Suggested Answers
  • 27 Answers
SOURCE: multi region hack code for panasonic sa-ht720
dvdhelp.com
Posted on May 08, 2009
SOURCE: panasonic recorder model#sa-ht720 will not play
The laser moves along a track by a set of gears. That clicking sound you hear is the laser getting stuck at a certain point and trying to move forward.The laser has to move the full length back and fourth to read the disc. There isn't a whole lot you can do, if its under warranty your best of sending it to the manufacture to be repaired. Otherwise you will have to buy a new one. With that said you could take the cover back off, plug it in (don't touch anything)load a disc and watch it, you should see the laser stop and the gears start skipping over each other. A gear may even have came loose and is no longer spinning or has fallen out. You can attempt to fix this (make sure its unplugged when you are touching the inside). NOTE:: Do not force the laser assembly back and fourth as you will damage it more. Post back with any further info or questions you may have. Thank you for choosing Fixya!
Posted on Jun 05, 2009
  • 62 Answers
SOURCE: cd tray won't open
get it serviced as it happens due to the old band or ring kinda thing in the tray which aids in opening of it.
Posted on Aug 28, 2009
SOURCE: I HAVE A PANASONIC SA-CH72
Unplug the unit, then unscrew the metal cover over the top and sides of the unit. Then unscrew the black plastic cover that goes over the top section of the back. This will allow you to get out a CD that is stuck in the back.
Posted on Apr 24, 2010
Panasonic SA-PT460 disc tray don't opening
The tray mechanism tracks may be binding or the mechanism may lack sufficient power to move the tray.
Dec 30, 2013 | Audio Players & Recorders
Panasonic SA-PT170 disc tray will not open
You may as well replace the player, as the parts to fix it are not available for this type of device, just no demand .
Jan 31, 2012 | Panasonic SC-HT70 System
Panasonic SA-PT460 disc tray keeps opening. When system switched on disc tray opens, then closes and then opens and stays open. can't play a disc.
SA-PT460
Original fault tray would not stay closed,opened up 460 case and then removed 2 screws on rear of drive. unplug 2 ribbon cables.
unscrew 1 screw in micro switch pcb rotate and spay cleaner into switch and rock switch several times until the reading across switch is 0 ohms before you start you will find the switch has about 2.5 k of resistance across it witch is too high.
as long as you have about 4ohms it will work.
Aug 14, 2011 | Audio Players & Recorders
Moved and lost power supply from dvd to wall. SA HT-720 model SR#DE4 1F005628 Theater Home Sound System
http://www.nodevice.com/user_manual/panasonic/dvd_cd/sa-ht720.html
There is a power CORD p/n K2CB2CB00006, but no external power supply.
You could search for that specific part and pay an arm and a leg for it or just go to any Radio Shack or electrical supply store and pick one up for about $8. You may even have one unused somewhere around the house.
Aug 03, 2011 | Panasonic SA-XR15 Receiver
LOCKED displays when attempting to eject disk from SA-HT670
i have a panasonic SA-HT720 and it displayed locked anytime i wanted to eject discs so i found out that dad27's solution was the best and holding down the stop and power buttons also locks the system as well as unlocking it. God richly bless u dad27 u really helped me out
Jul 27, 2007 | Panasonic SC-HT670 System
Disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Nov 19, 2006 | Panasonic SC-HT680 System
Televison & Video Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
