Need a driver for all in one hdd docking station model 875d
3 Suggested Answers
  • 226 Answers
SOURCE: drivers for docking station?
The driver that's needed for docking station (it's more a port replicator than a docking station) support is Toshiba's Mobile Extension 3. After that, it oughta support warm/cold dock/undock.
Go here to find and download Mobile Extension 3: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=160273&rpn=PS610U&modelFilter=6100&selCategory=3&selFamily=1073768667
Posted on Apr 10, 2010
  • 400 Answers
SOURCE: Choosing an HDD docking station
You just need a an external case that supports 2.5" Sata harddrives and they will connect to your computer via USB.
haven't seen a harddrive that has the connection on the side ,it is usually at the back ,it could be some sort of a Toshiba adaptor that you might have to remove.
The back should look like this :
http://www.gearxs.com/gearxs/images/MK8034GSX.jpg
There are many brands ,coolermaster ,nvidea etc ,some have USB ,firewire and eSata connectors (your PC has to have firewire and eSata in order to use them) The USB ones are usually cheaper.
As far as the password problem goes you can take ownership of that drive by using the security tab on the specific folder that you cannot access but this depends on which operating system you have .Windows XP pro and Vista home and upwards can do this.
Posted on May 06, 2009
I need a driver for the Nexstar H.D.Dock,NST-D100
digitech have such a product called a usb3.0 sata hdd docking station---xc4696 available for Jaycar electronics shops ( around $50.00 aud ) there is also an adapter that fits inside the docking station to be able to use pre sata hdds as well
Aug 24, 2016 | Sata Computers & Internet
Which USB cradle works for a WDAC24300?
Okeba 2.5" 3.5" SATA IDE Hard Disk Drive HDD Dock Station Clone With USB HUB card reader - CA130 From - Rakuten.com,
or: Sisun 2.5"/3.5" IDE SATA HDD Docking Station +Card Reader Hub - From Amazon.com
Feb 12, 2015 | Western Digital AC24300-00LK 4.3gb 5400rpm...
I need the instructions for Thermaltake BlacX ST0005U
The manufacturer page for this item is here: http://www.thermaltakeusa.com/products-model.aspx?id=C_00002058
Their support page does not provide a manual, instructions or drivers.
I suspect that is because none are needed. This is essentially an external hard drive enclosure for SATA drives which are standard. Connected via eSATA or USB.
Oct 21, 2014 | Thermaltake Computers & Internet
How to install USB3.0 eSATA 2.5"/3.5" horizonatal mobile HDD Docking station?
Hi
Once you have the drive installed in the docking station you will need to install the drivers on the host PC, if your drive is not showing up in my computer, then either the drive is faulty, the docking station is faulty or the drivers have not installed correctly.
1 listen to the drive can you hear clicking noises from the drive, or is there any activity at all from the drive if not then the drive is either not sat in the holder correctly so is not getting power. or if it seated ok then the drive has gone faulty.
2. If the Docking Station is faulty return it and get it replaced
3 Remove and reinstall the drivers.
Cliff
MCP
Aug 23, 2014 | Dell Dimension Computers & Internet
What power plug do i use with unitek data hdd docking station
The Y-2041 comes with a 12V 4A power supply which is not quite as large as the typical laptop supply. It is manufactured by Ktec and the model is KSAH1200400T1M2.
Jan 19, 2014 | BestOfferBuy Unitek Y-2041 USB 2.0/eSATA...
Why would my hdd docking station driver be blocked from loading (new install) ?
it is common problem when installing unsigned driver. please select the 'install driver anyway' when got pop-up window option. Thank you.
Nov 04, 2013 | Interface 2.5 3.5 IDE SATA Multifunctional...
Usb port not working after hdd reformat
Since you reformatted the HDD you have lost the driver for the usb, go to HP support and put in the model of the computer in the search box and click on driver/software. Look for the usb drivers and chipset etc.
Dec 23, 2009 | HP xb3000 (417329-001) Docking Station
Drivers for docking station?
Jun 19, 2008 | Toshiba Satellite Pro 6100 Notebook
I have an Archos 605 WiFi. I haven't yet connected my Archos docking station to the TV and HDD. Meanwhile, I thought I would copy a programme from the HDD to a DVD, then put the DVD in the computer and...
What kind of HDD do you have, do you have any type of output on it. You stated that you haven't connected the docking station to it and the TV...? The best thing to do is to connect your Archos to the Docking station. Set the docking station up correctly, with cables coming out of the HDD (if it has some sort of output) to the station and out of the station to your TV. Once you set that up, you can use the Archos as a mini DVR or VCR. Go to the REC option on the main screen of Archos, you'll have an option for Video Recorder (tab on top). If you play any source on the HDD, then all you have to do is press the Rec option on the Archos. If you already have a file on the HDD, then try just moving it over into the Archos once you connect the Docking station to your computer via USB or just use the USB cable connected to the computer with the HDD. I use the USB preference as Windows Media Device. (found under menu/settings/system). Is is basically a HDD itself. Remember the Archos will only play certain videos without the purchase of any extra plugins.
Good Luck
Apr 14, 2008 | Archos 605 WiFi Digital Media Player
Computers & Internet Logo
1,566 people viewed this question
David Payne
David Payne
