Question about Vizio L37 Television
Vizio L42HDTV10A sound problems
I have a Vizio L42HDTV10A that has a very muffled sound when the Bass control is turned up past 90. Turning the bass down cures the problem but then it sounds like a tin can. Any suggestions? Does it on my wireless headset also, so I would think it's not the speakers..
  • Dennis Burkhart May 14, 2007
    Is there a sound card that could be easily replaced?
  • Jbryanb Aug 27, 2008
    I have an L42HDTV10A Plasma. My sound is fine until I turn on surround mode. Then it sounds like a tin can, or at least very thin. Thought surround was supposed to be more rich.
    Bryan
In my case, turning the surround sound OFF is what fixed the problem. The bass contibutes most to the perception of the location of a sound. If surround is ON without surround speakers connected, the internal TV speakers can only take the place of what would be the front speakers in a surround system. So turn surround OFF and set your bass preference wherever you want it. That worked for me.
Posted on Dec 16, 2007
Sometimes when I play my xbox 360 my Vzio 32' hdtv looses sound. if i turn my tv off then back on it works fine... whats the deal with this? should i return it and get another one or a differant brand?
Posted on Sep 29, 2008
I have had my flat panel vizio L37 for under 2 years. The sound is completely gone - any suggestions? No more warranty unfortunately. HelpME
Posted on Apr 29, 2008
Has your set have a surround sound feature, if so turn it on with the remote.
Posted on Dec 06, 2007
My 10 w7 has vocals and bass now my vocals sounds muffled what can i do to get rid of my vocals and keep my bass???
You're going to need what's called in the audio world as a crossover. These can be as simple as a capacitor or inductor in series with the speaker, and can be as complex as you like. I'd advise using an inductor in front of the speaker, of around 8mH. This will leave bass intact, but reduce the vocals.
You can calculate your own crossovers at http://www.the12volt.com/caraudio/crosscalc.asp
There's wiring diagrams to help you.
Jan 10, 2010 | Jl Audio 12W7 Car Subwoofer
No bass and muffled quiet sound... help
No, to make this connection correctly you need a pre amp. you can find them online for about 25 and up. your ipod does not have a pre amp section and is sending a very weak signal to your amplifier. A pre amp is the fix. Hope this helps
Jun 23, 2009 | Alesis RA-150 Amplifier
My tv is making a poping noise. I unpluged the set from the radio but the sound is coming from the speakers on the unit. What is it, and how can it be fixed. Thank you Bryce,
Turn down bass in audio menu or if tv has subwoofer turn down sub level or like i stated earlier turn down bass other than that popping noise is a common complaint with vizio, if under warranty call service provider
c
Sep 29, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
I plugged int he rca's but he the lowest sounding bass possibe
kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Jun 27, 2008 | Kicker KX800.2 Car Audio Amplifier
Muffled sounds from speakers suddenly on our boat
Hi airnurse
If you are using a cassette deck for a source of music, then it will have dirty heads. This can be cured by using a head cleaner cassette. Muffled sound from the loudspeakers usually points to a faulty high frequency driver(tweeter). Is the sound muffled on radio or other sources as well. If so, then you have faulty tweeter(s) to any speakers that are muffled.
Of course in saying that, you should check that someone has not just turned the treble control all the way down, or the bass control alll the way up :) Pays to check.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
Jun 18, 2008 | Audio Players & Recorders
Setting low pass and bass eq
Hello, i have a hifonics brutus also, in the manual it states to set the eq at half way, so that there is no clipping or at least to prevent clipping , the eq will make the bass punchier, if you do go pass half way, i would recommend to readjust your gain settings, also check your head unit settings and make sure everything is flat, bass, mid bass etc. example i had my eq past half but i had my gain at mid way, it was hitting hard, then i tried turning the eq all the way down and the turning up the gain and the bass was smoother so it depends where you set it, and what settings you have on your head unit tone control (bass, treble etc)
May 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Bass amp for guitar?
i say it can! u would get a nice clean sound! acoustic guitar sounds nice through a bass amp!
you probably wouldnt get distortion out of bass amp though! depends on the bass amp! some bass amps have built in effects! e.g distortion
Oct 15, 2007 | 3Com SuperStack II advanced RPS...
Speakers stop playing when bass is turned up
may be there is problem with your woffer spk bcoz bass is contrlled by woofer see if you can see the spk cone is not tear or it is damage. bye
Sep 23, 2007 | JBL CREATURE II Computer Speakers
Bass knob not working
you need to have the variable resistor, which is the Bass control replaced.  It's defective.
Jul 25, 2007 | JBL CREATURE II Computer Speakers
JVC RX-618V SOUND IS MUFFLED
check to see if the radio is clear. If it is it may be the signal going into the amplifier. if it is muffled as well, depending if you have an Equalizer hooked to the unit. This also could cause the problem. Finally check the bass, treble balance and volume knob but turn them back and forth while unit is on and see if signal clears up momentarily. if this is the case the control knobs need to be cleaned. Also spin the connection jacks {RCAs} in the rear and see if this clears it up. If not you may have to have the unit serviced by a professional.
Jul 13, 2006 | JVC RX-618V Receiver
Vizio L37 Television Logo
1,744 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
