Question about iSymphony Televison & Video
I have an iSymphony LE22iF50 1080p Flat Screen TV and would like to connect it to a sat receiver and DVD player?
  • 142 Answers
SOURCE: dvd player
SOME dvd players have a small hole in the front... just large enough for an opened up paper clip to fit into. If yours has this, unplug your machine and insert an unfolded paper clip into this hole and gently press the mechanical eject switch. If you don't have this feature, your only hope is to disassemble the bottom of your set and spin the eject motor by hand to remove your disk.
Posted on Mar 10, 2008
SOURCE: sony bravia lcd hd flat screen tv
scratches on panel of 52 inch Sony LCD
Posted on Apr 15, 2008
SOURCE: samsung flat screen tv lost sound
Samsung flat screen lost sound - what is the problem? help!
Posted on Feb 21, 2009
landsend
  • 1066 Answers
SOURCE: i bought a 32 inch flat screen tv dvd combo from walmart
the cable connection needs to be resoldered to the circuit board.
Posted on Mar 13, 2009
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
Posted on Aug 12, 2009
Portable dvd to tv
you should be able to get two mini-plug to rca cables and make it work. The audio one will need to have two rca connectors, the video only one.
Jul 06, 2013 | Televison & Video
I cant connect my dvd player to my tv. Theres
If you connect the satelite to the tv, using the tv socket on the sat. and connect the dvd to the vcr socket on the sat. it should play through the sat. even with the sat. turned to standby.
Apr 12, 2010 | Televison & Video
Want to connect dvd player and tv; how can I do this so that I can switch back and forth between tv and dvd player?
Connect the DVD player as you normally would for the inputs that you have available to connect to. Then after that all you have to do is change your input selection to TV/SAT, from whatever input selection your DVD player is connected to.
Dec 26, 2009 | Insignia IS-LCDTV32 32 in. Television
Problem connecting DVD/VCR to DISH
Dish dvr can only output so you have to connect your dish dvr to your dvd/vcr and then connect your dvd/vcr to your tv and im sure it should work
Dec 19, 2009 | Televison & Video
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Correct hookup from satilite receiver to dvd/vcr to tv
Av out from sat to AV1 on TV.
AV2 from tv to av in on dvd/vcr .
( if you can pick what av2 on the tv sends out set to send av1 out to record)
OR
AVout from sat. to AV1 on TV, AVvideo on sat to vcr/dvd.
The sat. system will act as a "play through" device so you can play vcr/dvd without changing the AV on the TV.
If you connect another lead in either option you may get a feedback loop causing audio "squeak" and video problems.
Post back to let me know if this helps.
Aug 12, 2009 | Televison & Video
Snow on screen and no picture on my DS35510
Hi and welcome to FixYa,
Offhand, if the previous system/connection works then we should leave that as it is. Coax-Sat Receiver-Coax-DVD Recorder-TV and TV should be Channel 3 (or 4).
On the new Sat Receiver, coax from LNB/Dish to Sat Receiver, yellow, red & white to TV. TV should be set to Video 1 or A/V or Video. There should be no snow, rather if no reception, it should be blue indicating video has muted in the absence of a good signal.
Good luck and Thank you for using FixYa.
Jan 04, 2009 | Sanyo DS35510 35" TV
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Cant get the wiring figured out.........
I have a similar set up. For yours, I would run one optical from your Sat box to your 407 and connect the DVD player optical to the Kenwood as well. This will allow you to get whatever your watching, DVD or Satellite to your speakers. For Video, use the component cables to connect DVD player to TV. For the SAT box, coaxial to TV or S video to TV will give you about the same video quality. I hope this helps. A couple of suggestions: Your new screen size will greatly magnify the quality of your video, what looked good on the Sharp may not look good on the Samsung due to the size difference. I REALLY suggest you get a new SAT box with a HDMI connection. Also you can get a blu ray player in the $120 range. The Blu ray will play blu rays and upconvert DVDs to a higher quality picture through its HDMI connection. You will be amazed at the difference HDMI will make on how your TV will look!
Oct 29, 2008 | Kenwood VR-405 Receiver
Televison & Video Logo
89 people viewed this question
Top iSymphony Televison & Video Experts
ray gallant
Vernon Taylor
Are you an iSymphony Televison and Video Expert? Answer questions, earn points and help others
