Question about Nokia 1110 Cellular Phone
Keypad not working
When i press 1 then 2 or 3 also press in on time menu also not open
    Problem Solver:
  • 13 Answers
Phone will have to be replaced. keyboard has either started to fail or become corroded or the phone board has started to fail or become corroded.
Posted on Jan 03, 2009
3 Suggested Answers
bigjohn007
  • 425 Answers
SOURCE: some menu automatic update key not work
hi
i think thiers a prob in your switch. try opening your phone and try cleaning your keypad boards. maybe it is shorted or get dirty inside...
hope it helps...
Posted on Oct 16, 2007
Bajanguru
  • 7752 Answers
SOURCE: W810 keypad abnormal working
take the phone and ahve the keyboard replaced
Posted on Aug 24, 2008
I need a puk # for a verizon sims card #8914800000 0776538424. I have a AT&T phone that I need to use the Verizon sim card.
If your phone is a Samsung Galaxy S4 the following should work.
Step one: Turn the phone on and open up the dialler.
Step two: Then type *#0011# on the keypad.
Step three: Press the menu key, then tap BACK on the screen, press the menu key again and this time select KEY INPUT.
When the box appears enter the number '1' and press OK.
Step four: Once again press the menu key and then tap BACK on the screen.
You should now be in the ServiceMode main menu.
Tap on the first option - [1]UMTS,
then tap the first option again [1]DEBUG SCREEN,
then tap on [6]PHONE CONTROL,
then [6]NETWORK LOCK and finally [3]PERSO SHA256 OFF.
Step five: Head back to the UMTS menu by pressing the menu button and tapping Back on the screen.
Step six: From here tap [6]COMMON, then [6]NV REBUILD and finally [4]RESTORE BACKUP.
Step seven: Now wait for a few minutes while your Galaxy S4 reboots.
Oct 31, 2015 | Samsung SGH Cell Phones
Why won't the keypad outside mount not open the garage door but the remotes work fine.
U will have to re program the keypad follow the directions on the lid of the keypad now on some models u have to hold down * # at the same time until it stops blinking then enter your 4 digit code press enter hold for 2 sec if opener does not release and press again as soon as u hear the opener click or light blink press 0 to store code then wait 60sec and try
Sep 02, 2014 | Chamberlain 1/2-HP Whisper Drive Belt...
Model 6032 need help setting the date and time
Press MENU/SELECT to display menu when in idle mode.
Press down-arrow or up-arrow to reach Date/Time . Press MENU/SELECT.
Use the keypad to set the year. Press MENU/SELECT.
Use the keypad to set the date. Press MENU/SELECT.
Use the keypad to set the time. Press down-arrow or up-arrow to select a.m. or p.m. Press MENU/SELECT.
The screen displays Stored and you'll hear a confirmation beep.
The above is from page 8 of the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/175/UserManual/458/6032_Manual.pdf
Aug 29, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
HOW TO SET DATE & TIME
To open the USER SETTINGS MENU. Open all three of the One-touch speed dialing panels. Then press the button labeled "Data Registration".
Press the "SET" button 2 times until you see: USER SETTINGS - 1. DATE & TIME.
To open the DATE & TIME Menu. Press SET. Use the buttons on the numeric keypad to enter the current month, day, year and current time. Just enter the new numbers over the old numbers.
To set the year, enter 08, 09, etc.
Use the 24-hours format to enter the time (e.g. 1:00 p.m. would be entered as 13:00)
You can also use the cursor buttons to move the cursor without changing a number entry.
To restore previous entry, press CLEAR. Press SET to "lock in" the Date and Time.
These instructions come directly from the User's Manual.
Hope this helps.
Mar 29, 2011 | Canon L220 Plain Paper Laser Fax
I did not open my game on my Phone V3 If i open then came a massage "No Installed MIDLet Suites" Please solve my problem
  • 1 Press the V3's "Menu/OK" button, located in the center of the directional keypad.
  • 2 Use the arrow keys on the directional keypad to navigate the menu down to the "Settings" option, then press the "Menu/OK" button.
  • 3 Select the "Initial Setup" option in the Settings menu and then select the "Master Reset" option in the Initial Setup menu.
  • 4 Enter "000000" into the field in the Master Reset menu; if you've changed your L9 security code, enter the new code instead. Press the "Menu/OK" button.
  • Dec 27, 2010 | Cell Phones
    We just moved in our house in January and our keypad on our 1/2HP Liftmaster stopped working. I have changed the battery and when I try the code the backlight blinks several times but the door never opens....
    Try programming the keypad by doing this:
    Press and immediately release the smart/learn button and then walk over to your keypad and key in any 4 digit code you like and press enter. If this doesn't work you keypad has quit.
    Aug 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
    HOW DO I SET THE DATE & TIME ON THE ANSWERING MACHINE DS6221-1
    Hi there, I found my manual that states:
    Press the up or down triangles to reach DATE/TIME. Press MENU/SELECT.
    Use the keypad to set the date. Press MENU/SELECT,
    Use the keypad to set the time. Press the up or down triangles to select a.m. or p.m. Press MENU/SELECT
    The screen displays STORED and you'll hear a confirmation beep.
    George Rocks
    Apr 18, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
    Time & Date
    1. To open the USER SETTINGS MENU. Open all three of the One-touch speed dialing panels. Then press the button labeled "Data Registration".
    2. Press the "SET" button 2 times until you see:
    3. To open the DATE & TIME Menu. Press SET.
    Jul 10, 2009 | Canon LaserCLASS Fax 710 Printer
    Coby 514 change region solution
    Try these two. they seem like they'll work. Their both for this unit.
    Turn unit on with remote
    NO DVD in the tray closed or opened might work
    Press TITLE then 1 then 9
    Gray box will appear in the center of the screen with number 1 in the middle
    Using up/down arrows change to desired region (0 for REGION FREE)
    1. Open the DVD tray
    2. Press 'STOP' button on the remote control
    3. Press '70'
    4. Press 'MENU PBC'
    5. Use the numeric keypad to select your region code number (0 – 6). 0 is all regions.
    6. Press 'Enter'
    Oct 11, 2008 | Coby DVD-514 DVD Player
    Some menu automatic update key not work
    hi
    hope it helps...
    Jul 10, 2007 | Sony Ericsson K510i Cellular Phone
    Nokia 1110 Cellular Phone Logo
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
