Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite laptop error code 10-fc12-0241
SOURCE: toshiba satellite A205-S5847
When dealing with this error (10-FC06-000D) message in Toshiba unit is very comment in the L300 series, I don’t know if Toshiba is using cheaper hard drives or what but I see a lot of them with the same problem. If you have a Toshiba unit got to their website to check if your unit is still under manufacture warranty if it is you have some options send it to Toshiba direct they should cover the shipping but I’m not to sure, or take it in to any Best Buy or Future shop stores with your proof of purchase and they will send it out for you. This is a hardware problem that is related to the hard drive, I wiped the hard drive and all it’s boot records still unable to reinstall the OS OK, I finally decided to use a test hard drive to reinstall the OS worked fine so there is something wrong with the hard drive that most likely would need to be replaced
Posted on Feb 19, 2009
  • 49 Answers
SOURCE: toshiba satellite error code ide #0 error
IDE #0 is where your hard drive connects to your computer's motherboard. You may be able to connect your hard drive to IDE#1 or you will have to have your motherboard replaced.
Posted on Jun 29, 2009
SOURCE: i am coming up with error 10-fc12-0570 on the
The error message is telling you that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive. The problem could be with the disc, the CD/DVD drive or the hard drive.
but usually error 10-FC12-0570 is pertaining to a bad HDD or memory
First, try copying the second disc using another system. If you can't copy it, order replacements from Toshiba Customer Assistance: 1-800-457-7777. If you can copy it, try using the copy to do the restore.
You can try using a third party disk checker to verify the problem is or is not with the hard drive. But since the system is under warranty, you're going to have to arrange to have it repaired anyhow, so it may not be worth the effort to verify whether it's the hard drive or CD/DVD drive. It's probably not the CD/DVD drive since you got all the way through the first disc. Contact a Premier (not regular) ASP for service from here: http://pcrepair.toshiba.com
The best way would be to load the Win Vista discs n format the pc...and reinstall...iam telling this because u have a tried the recovery disk as well....
I know most users will not have the Vista CD with you but the Vista Recovery Boot Cd is available free by Microsoft just google...
Download it burn the Image .iso and run that disc. Since that disc will not restore the OS all it does it lets u run diagnostics on ur HDD and allows u to install the OS. Once disk check is completed and repaired, proceed with the Recovery disks that you have.
thank you
have a nice day
Posted on Jul 08, 2009
  • 11800 Answers
SOURCE: My Laptop Problem
Usual cause for your error: memory error (data cannot be swapped out to disk using the paging file).
To troubleshoot Stop error 0x00000050
1.Remove any newly installed hardware - usually the video driver does that
2.Run any system diagnostics supplied by your computer manufacturer,
especially the memory check.
3.Restart your computer, and then run Chkdsk /f /r on the system partition.
4.Disable or uninstall any antivirus programs.
5.Disable BIOS memory options such as caching or shadowing.
Posted on Jul 08, 2010
  • 55 Answers
SOURCE: Toshiba Power Saver. Fatal error Code 0x7E
uninstall Power Saver while in Safe Mode, reboot into Safe Mode again, and reinstalled Power Saver
Posted on Jul 05, 2012
High definition audio controller This device cannot start. (Code 10)
If you run into the error "This device cannot start. Code 10 (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10 or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
The technical explanation for this message, according to Microsoft, is this:
"If the device has a FailReasonString value in its hardware key, that string appears as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message:
What does that mean in plain English? It means that if the device which is throwing the error has added its own custom error text to your Windows system when the device was installed, then when the device encounters an error, you will see the custom error message specific to that device. But if it doesn't have its own custom error message, then Windows uses its own generic error message for devices, which is "This device cannot start. (Code 10)"
Microsoft recommends that when this happens, you click "Update Driver" to update the drivers for the device. You can also start the Windows troubleshooting wizard by going to the general properties tab of the device, and clicking on "Troubleshoot".
Before doing this, be sure that you have the correct and most up-to-date versions of the driver(s) for that device. You can also try uninstalling and reinstalling the device, using the disk which came with it.
Finally, you can go to the website of the device's manufacturer, and check their downloads or support section for current, up-to-date drivers.
Go to Toshiba support site look for Toshiba Satellite A135 drivers, download the one for your windows 32 or 64 bit install, restart and off you go. Regards, Mike
May 19, 2014 | Toshiba Satellite A135 Notebook
Getting error code F3 F100 0003 on a Toshiba Satellite L650 running on a Windows 7 Ultimate 32 bit operating system. This code appeared before hard disk drive was replaced and continues to appear after a...
Hi Lea,
If you're getting the F3 F100 0003 error on boot-up, the problem might lie on three things. It's either the a bad HDD, Memory, or the video adapter (which is soldered on the motherboard). Since you already replaced the HDD, the problem might lie on the other two. If you can burn a disc to run diagnostics on your computer, you can use UltimateBootCD or Hiren's Boot CD (more info on the tools here).
I've also seen some errors when you are trying to re-image the HDD using the Recovery Discs and it may have some connection to the error message that you're getting. Here's a list below:
-An error has occurred: ERROR : 10-FC10-1710" -- may be caused by a faulty hard drive.--An error has occurred. ERROR : 10-FC12-0241" -- may be caused by a faulty hard drive or defective memory.
-An error has occurred. ERROR :10-FC12-045D" -- may be caused by a faulty hard drive.
-An error has occurred. ERROR :10-FC06-0002" -- may be caused by damaged recovery media or faulty hard drive.
-An error has occurred. ERROR :10-FC12-0970" -- may be caused by defective memory.
Hope this helps. Good luck.
Sep 06, 2011 | Toshiba Satellite L455D-S5976 Notebook
When restoring toshiba L355D-S7901 what does "error 10-FA11-045D" mean? i get that code when its creating the crc files. how can i fix this?
Read this forum:
http://www.howtogeek.com/forum/topic/recovery-error-on-toshiba-satellite-a205-s5864?replies=21
Jun 20, 2011 | Computers & Internet
I recieved error 10-FA12-045D after trying to restore factory state on my toshiba satellite C655 laptop
Error codes starting with 10 on Toshiba laptops point to a hard drive failure. The drive is most likely dead and cannot be revived. You will need to replace the drive and then reinstall the operating system.
Feb 28, 2011 | Computers & Internet
Error code 03-eeee-0000 when i try to use restore disc on my toshiba sattelite laptop
error code 03-eeee-0000 when i try to use restore disc on my toshiba sattelite laptop
Jul 17, 2009 | Toshiba Satellite A215-S4747 Notebook
Problem with laptop- no power
The battery needs to be taken out once in a while. It is possible to use the ac adapter and power cord without the battery to power your laptop. Please press on the power button for 10 seconds for your computer to turn on. Check if you can see any message on the screen.
Sep 04, 2008 | Toshiba Satellite A105 Notebook
Not work
Try this...
http://support.microsoft.com/kb/929461/en-us
It should clear out error code 10
hope this helps...
Jul 25, 2008 | Toshiba Satellite A135 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
390 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
