Question about Samsung SGH-a737 Cellular Phone
Text messaging When I use T9 with my samsung a737 it doesn't allow me to choose any more words from the series of letters I have typed, it only gives my one option. How do I get different words?
Hit the zero button..
Posted on Jan 12, 2009
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
Daughter borrowed phone and switched the text msg typing to auto fill and numbers. I have tried every thing and I can't figure it out, can you please help me? Thank you, Susan
Based on your description, what you are referring to is called T9 Predictive Texting. It allows words to be entered by a single keypress for each letter, as opposed to the multi-tap approach used in the older generation of mobile phones in which several letters are associated with each key, and selecting one letter often requires multiple keypresses. Example, when typing the word 'love' in a T9 activated phone, all you have to do is press the numbers 5, 6, 8 and 3 once in sequence. As compared to the regular texting, in order to complete the word 'love', you have to press the number 5 thrice, the number 6 thrice, the number 8 thrice, and the number 3 twice.
If you want to disable T9 predictive texting, it can usually be disabled by pressing and holding the hash or number key (#).
Hope this information is helpful.
Apr 08, 2011 | LG Cell Phones
Can't add word to T9
Do this:
Go to Menu--Messages--Create Message--Message--Tap on the Blank Screen (I am sure you can do this)...here is the step for adding words into the T9 library
Now on the Pad (from where you type the message) you will see T9 button lower left corner--press it--the color will change from Black to Blue.
When you will start typing few letters e.g.,Hello you will also see these words Hello,Cello,Helen on the Right Side of these words you will buttons for selecting the words and moving them up and down...move them down completely as soon as the words are finished you will see another button and that is Add word --press it and type in any word that you want to add--after typing press Done from the bottom left corner and you are done with the problem.
If there's any more help you need,do let me know.
Feb 10, 2010 | Samsung SGH-S5230 Cell Phone
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
Typing & viewing text messages on Samsung SGH-A411.
Dear
Turn of dictionary function, in that function ur phone directly suggest a word ageinst letters u type ex. if u type h then it suggest hi,hello ets
I m unable to tell how u can turn it off as u have not mentioned ur phone's name & model
Some Brands in which i know how to turn off its
Nokia - Press # key to change wordsn in left corner turns to abc from abc_ or just go to option & turn off dictionary
Sony - In message composing go to menu & turn of T9 Dictionary
Thanks
Mar 16, 2009 | Cell Phones
Problems with T9 predictive text Samsung SPH-m530
the phone is most likely got the setting only suggest alternate words after the 3rd letter inputted (unless i misunderstood the phone that setting's meaning)
Dec 08, 2008 | Samsung SPH-M500 Cellular Phone
Predictive text
I had this problem and it was very annoying. What you have to do is..... create a new text message, enter the text that is annoying (mine was is coming up as 47). When you type the word and it comes up with the annoying one, select the word that you wanted and enter a space, and do it again and again (you can do this in the same text message - it can take up to 20 goes and eventually, the dictionary recognises that you actually wanted "is".
Oct 04, 2008 | Samsung U900 Soul Cellular Phone
Reset the T9 text dictionary
I ran into this problem as well, and it is extremely annoying. I just lived with it for the longest time and then I finally decided to go looking for a solution. That came to a quick end when I found the Samsung FAQ and it said that there is no way to delete words from the predictive dictionary. However, that got me thinking. If it's predictive, can I teach the predictive to write the correct word? The answer is YES! Open a blank text message, don't worry about a number just go to the text entry portion. Type out the word and press zero to change it to the correct word instead of the numbers. Do this 10-20 times IN A ROW and then the phone will recognize the right word as being most used and change it back to that.
Sep 25, 2008 | Samsung SGH-a737 Cellular Phone
Text Messaging
You need to go to options and take the setting of T9 out. T9 is the setting that will spell out words for you as you go through typing the word.
Aug 28, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Samsung SGH-a737 Cellular Phone Logo
48 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
