KitchenAid KESC307 Electric Kitchen Range Logo
Posted on Jan 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Off button doesen't shut off oven
Everything else works on the stove except the off button for oven. I unplugged the stove for hours and it still didn't correct itself. There doesen't seem to be any give on the button and it doesen't beep.It is not showing any error code.The stove is only 3 years old. It heats up fine.If I put in a cooking time it will shut off on it's own. By that I mean a start and finish time .I may have pushed those buttons too many times not sure.
tom weber
Level 2:
  • Expert 198 Answers
  • Posted on Jan 05, 2009
tom weber
Expert
Level 2:
Answers
198
Questions
6
Helped
109495
Points
452
You will probably have to replace the electronic range control.
2answers
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
Exact same thing happened to me. After a power failure my Frigidaire stove worked and the clock worked but bake broil and self clean gave me a DR error. Tried everything to reset nothing worked. When I unplugged and plugged back in I got an f13 code.I changed the control board and the entire oven is back in business!c86f7aab-24e4-4403-bcd6-0b838d53ac57.jpeg
How to turn the oven light off on my Kenmore Elite Electric stove model790.
You should have either a shorted out door switch or a shorted out light switch on the control panel.
Removing either one and unplugging it should show you which one is the problem.
God bless your efforts.
1helpful
My Ge Stove Xl44 model JGBP79 the oven will not turn off, all other button seem to work but this one
It is possible the touch pad is not working. If you unplug the stove and the oven shuts off then it is more that likely the touch pad.
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Samsung oven display not working
The self clean setting on ovens should be labelled "Self Destruct". This often overheats the timer. This company does oven control repairs. You just remove the timer and send it to them. They repair it for $106 and send it back. There is no charge if they can't repair it.
Feb 02, 2013 • Ovens
10helpful
2answers
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
GE Oven not working
hi
you may need a new control board. if your stove is in warranty contact the manufacturer, if not and you are handy you can find a replacement online and install it yourself. just be sure to unplug the stove before you work on it. if you need help with this please contact me.
Mar 21, 2008 • Ovens
Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Top KitchenAid Kitchen Ranges Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
