Question about Nikon FG 35mm SLR Camera
Nikon FG Exposure Compensation Dial
Okay, so I just got this Nikon FG, and the exposure compensation dial was working fine this morning, but now I'd messed it up somehow. When I lift and turn the outer part of the dial with the itty ***** red dot on it, I can turn the exposure dial from +2 to -2, but thats only as far as it will go.
Cant the whole thing rotate around from 12 to 3200, or do I just not know what I'm doing?
Thanks!
  • ailishganley Feb 03, 2009
    i jsut got a nikon fg and i have no idea how to turn it off!!!
  • 122 Answers
Try to set the itty ***** red dot to 0 again make sure the collar goes down its the compensation mode once its down try turning the speed dial again i haven't had a film camera for about 8yrs i had a nikon 6060 which is almost like a fg . hope this helps
Posted on Jan 03, 2009
While my setting is on A (aperture) on my Mode Dial, its my shutter speed, and sometimes my exposure compensation, that is changing when I move my main command dial
It may be possible to swap the functions of the primary control dial and secondary control dial - check in the manual or the menu system.
Jun 12, 2016 | Nikon D5200 DSLR 18-55mm Lens Kit with...
How do I change the aperture when my camera is in manual mode
You have to hold down the exposure compensation button at the same time as turning the control dial.
The values appear on the control panel screen.
I found this on page 33 of the manual...
Set the mode dial to M and turn the control dial to set the value.
• To set the shutter speed: Turn the control dial.
To set the aperture value:Turn the control dial while holding down the
[+-](exposure compensation) button.
The exposure level indicator appears on the control panel screen, showing the difference (ranging from -3 EV to +3 EV) between the exposure value calculated by the currently selected aperture
and shutter speed compared to the exposure value considered optimum by the camera.
Oct 13, 2014 | Olympus EVOLT E-410 Digital Camera
Over exposed photos
Your exposure compensation might not be set correctly. Just behind and to the right of the on/off switch you will see a small button with a "+/-" symbol. That is the exposure compensation switch. When you press it, you will see a number displayed on the LCD. If the number is positive, that is your problem. Positive numbers increase exposure and negative numbers decrease exposure. Set the compensation to 0.0 by turning the rear thumbwheel while depressing the exposure compensation button.
Jan 09, 2014 | Nikon D90 Digital Camera with 18-105mm...
Exposure locked on manual
Is that 10 seconds? 1/10 second? f/10?
What happens when you turn the command dial? What happens when you hold down the exposure compensation button and turn the command dial?
Jan 30, 2013 | Fuji FinePix S9500 Zoom Digital Camera
Incorrect exposure
It sounds like you've got exposure bracketing turned on. Hold down the Fn button and turn the main command dial to change the number of shots to 0.
Full details are in the "Bracketing" subsection of the "Exposure" section of the manual (page 130 in my copy). If you need a manual, you may download a copy here.
Apr 06, 2012 | Nikon D Cameras
My cannon g12 camera takes over exposed photographs. he shutter is working well. so, help me.
Check your Exposure Compensation Dial. In shooting modes where exposure compensation is allowed, this dial can be set to decrease or increase the brightness of the image in 1/3-stop increments across a range of -2 to 2. You use this control to override the camera's automatic exposure settings to get a slightly darker or lighter image. It should be set to 0.
Mar 04, 2012 | Canon G12 Digital Camera
How do I turn on the Rear Command Dial in my Nikon D80 Digital Camera?
That depends on what you want the command dial to do. If you're in either the Manual (M) or Shutter Priority (S) modes, the command dial will change the shutter speed. If you're in the Program (P) mode, the command dial will shift the program exposure. If you're in any other exposure mode, the command dial does nothing.
If you hold down the metering mode button, the command dial will change the exposure metering mode.
If you hold down the exposure compensation button, the command dial will change the amount of the exposure compensation.
If you hold down the release mode button, the command dial will change the release mode.
If you hold down the AF button, the command dial will change the autofocus mode.
If you hold down the QUAL button, the command dial will change the image storage mode.
If you hold down the ISO button, the command dial will change the ISO.
If you hold down the WB button, the command dial will change the white balance setting.
If you're looking at the menus, the command dial will navigate the menu.
If you're reviewing pictures, the command dial will move to the previous or next picture.
Hope this helps. If you still have problems or other questions about this, please don't hesitate to reply to this post.
Jun 29, 2011 | Cameras
Light facial detail in my Nikon D60
Are you using the flash? If so, dial in some negative flash exposure compensation. Otherwise simply dial in some negative exposure compensation.
However, you will have to leave behind the Auto and the other point&shoot modes.
Dec 28, 2009 | Nikon D60 Digital Camera
Nikon F65 35mm how to change the aperture
If the lens has an aperture ring, it must be locked at the mininum aperture (largest F/number). In PSAM modes use the command dial (possibly in conjunction with the exposure compensation button) to change shutter speed/aperture.
Sep 30, 2009 | Nikon F65 35mm SLR Camera
D70s problem
Check the exposure compensation setting to ensure it's set for +/-0. To do this, set the camera for Program mode. Locate the exposure compensation mode button - it's the button with a +/- on it immediately behind the on/off switch. With the camera on, hold down this button. If it shows anything other than "0", use the main command dial (the wheel on the back) to change to setting to 0.
The reason the camera works in the Auto mode is because the exposure compensation settings are not available in auto mode, but are available in Program (P), Aperature (A) and Shutter (S) modes.
Sep 30, 2008 | Nikon D70s Digital Camera
Nikon FG 35mm SLR Camera Logo
128 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
