Question about Ovens
My fan forced oven kleenmaid TO400x wont heat heat up on on fan forse mode however the fan works ,how ever the top element heats but not the back one
Oven not heating up on fan force mode the fan working just not heating how ever the top grill working ok if element how do you remove it to replace
3 Suggested Answers
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 109 Answers
    SOURCE: not heating in fan forced mode
    Possibly your fan element has blown. Try and take the cover off that coves the fan inside the oven itself and use a torch to look at the element to see if it looks out of shape etc.
    Posted on Jun 16, 2009
    My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
    Oven functions
    Oven light.
    Upper and lower heating elements.
    (Conventional cooking).
    Upper and lower heating elements with fan.
    (Fan assisted cooking).
    Lower heating element with fan.
    Inner grill heating element.
    (Radiant grill).
    Full grill heating element with fan.
    (Fan grill)
    Rear circular heating element with fan.
    (Fan forced cooking).
    http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
    Oct 10, 2009 | Ovens
    It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
    If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
    To replace: Turn off power!!
    -Remove side racks from oven, then remove rear panel.
    -You should now see fan blade and fan element.
    -You need to remove oven from cavity, then remove rear outer panel.
    -You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
    Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
    Aug 10, 2009 | Smeg Ovens
    Not heating in fan forced mode
    Jun 15, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
    Oven not heating up
    Hi.
    If the fan is working o/k, then in all probability the fan oven element has failed.
    A common problem with fan assisted ovens.
    It is a fairly easy job to replace same
    Nov 13, 2008 | Baumatic B180 Electric Single Oven
    No manual
    The light bulb is the oven light.
    The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
    The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
    The big circle with a fan is the Fan forced Oven
    The small line at top only is the Grill Mode
    The larger line at top only is the Double Grill Mode
    The line up top with the fan underneath is Double Grill with Fan mode
    The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
    The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
    Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
    Dear customer,
  • Test the element
    Jul 08, 2008 | Ovens
    Oven no heat
    for king louie
    fault is the circular element round the fan. take off the back plate inside the oven and you can often see the damage but not always. to get at the terminals, remove the rear cover and test for continuity across the element with a multimeter - remove any connections before doing this and note down where they go
    for tarzantony.
    i can't remember where the cutout is but probably on top of the oven or close to the fan on bthe back. just trace the wiring from the element and it should lead you to it
    Mar 25, 2008 | Neff U1721 Double circotherm Electric Oven
    Fan assist wont heat oven
    the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
    Jun 25, 2007 | Baumatic B187 Stainless Steel Electric...
    Ovens Logo
    62 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
