Question about Indesit Dishwashers
Indesit dif04 door not locking - Indesit Dishwashers
4 Suggested Answers
yalmer
  • 552 Answers
SOURCE: Indesit DIF04 integrated dishwasher
Dishwashers normally are hot or cold feed.
My wife runs water at the sink to get it hot going in before turning on the dishwasher.
You can use either cold or hot water.
We have ours hooked up to the hot water side.
They work better hooked up to the hot water.
Posted on Mar 21, 2008
SOURCE: indesit dishwasher wont come on
this might be a little late but i ahve the same problem, an indesit engineer has been and there ia a metal bar the control wires rub against when opening/shutting the door. major design fault if you ask me. it tripped my entire kitchen and extention out.
Posted on Nov 09, 2010
  • 298 Answers
SOURCE: My Indesit Dishwasher DIF04 has a problem.? My 'newish' Indesit D/W. DIF04 has constantly flashing lights and is permanently stuck in Drain-mode. Any ideas about the problm would be welcomed
flood float switch at the bottom of the dishwasher must be faulty.
Posted on Feb 01, 2012
F06 indesit washing machine. Saying door isn't locked. But it is
you will need to replace the door lock as the switch inside the lock is not working properly by perhaps closing the door to hard at times probably ? eric
Jan 15, 2018 | Indesit Washing Machines
Will not empty water
Its probably a blockage. Try taking the machine out so that you can put the drain pipe at floor level. (Ideally outside) so you can see if it drains or not. That will give you a better idea. Get back to me once you have tried that. Thanks, Sean
Nov 28, 2011 | Indesit Washing Machines
Indesit dishwasher wont come on
May 05, 2010 | Dishwashers
Indesit WIA 121 not working - door latch not shutting
At first thought it was door lock mechanism was at fault but proved it to be ok - removed rubber 'boot' which on this model was on two stretchable spring retainers and checked operation of door lock.
Thought door hinges may have been bent so dismantled door, finding the problem to be the pin that the door latch pivots on had come out on one side so not lining up properly. This was easily pushed back into position.
Oct 05, 2009 | Indesit W 123 Front Load Washer
Indesit washer wont run
the door lock light flashing indicates that the door has not locked or not shut correctly,is the appliance is under 5 yrs old open the door and check the door catch,there are two gaps either side of the catch,if you look into the gaps you should see a metal pin,if the one at the bottom is not there then thats why the door wont catch,there are some screws around the door frame if you take them out and just pry apart the door frame by the catch you will see the pin at the top,push it down till you see it at the bottom gap,refit and test.
Jan 24, 2009 | Indesit W 123 Front Load Washer
Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Jul 10, 2008 | Indesit W 123 Front Load Washer
Door locked
sounds like your interlock has failed you can buy from any appliance spares outlet or online regards jason
Jun 08, 2008 | Indesit W 123 Front Load Washer
Mar 21, 2008 | Dishwashers
Dishwashers Logo
50 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
