Question about Samsung Televison & Video
Fuse 230 v t3 15ah blowing on board bn44-00264a. samsung tv
2 Suggested Answers
ekcnoel
  • 998 Answers
SOURCE: The 3.15A fuse on the
Some of the parts of the power is shorted try to check the regulator and the diode. But be sure to unplug the unit before checking the regulator and the diode. Feel free to send feed back good day and best regards.
Posted on Aug 18, 2011
Have a Samsung tv that won't turn on we have checked all fuses and no capacitors are blown don't know what to do or check next.
hi unplug each board one at a time then turn on. see which one is causing the fault, it's usually the ysus board blows takes out the buffer boards thanks
shaun
Mar 19, 2017 | Samsung Televison & Video
Hello, I have a samsung un55d6400 led tv, where the standby light blinks 5 times, ive replaced the powerboard and main board. The fuse keeps blowing what is my next step
The fuse keeps opening because the problem is more serious. If it did not blow, then more damage could be incurred in the TV. Sounds like you should consult a professional rather than not really knowing what you should be doing next.
Dec 05, 2016 | Samsung Televison & Video
I noticed one fuse on the main board of my Samsung 52" LCD TV. How do I determine if the fuse was blown? The color of the fuse looks solid white.
a fuse can be checked with a cheap multimeter on OHM setting or a cheap fuse tester. or make a simple circuit tester with a AA battery and bulb. Some fuses are a white ceramic and will not change color after blowing out. But, Since the TV is "clicking' I would say you have a more serious problem than a fuse.
Mar 08, 2015 | Samsung Touch of Color LN52A650 52 in. LCD...
Samsung fp-t5084 fuse fix is the replacement fuse slow burn or fast burn?
I'm certain it uses a T12amp slow blow type. I have the exact same model, you can replace the fuse. The TV will for a while, but that fuse will blow again. You will need to replace the power supply board for a more permanent fix.
Dec 21, 2012 | Samsung FPT5084 50 in. Plasma HDTV
Samsung dlp 5065w keeps blowing fuse
samsung motherboards are bad for going out. they are 125 dollars online, if you have the technical skills to replace them.. basically just plug and play, with LOTS of screws to take off.
Oct 06, 2012 | Samsung HLN5065W 50" DLP TV
Samsung LN55B640 LCD TV blowing fuses
when the fuse always blown, it could be a shorted component at the power supply board or the main board was affected during lightning where in some of the component get burned then cause a shorted line.if you don't have an idea in any electronic repair just leave it to the trained technician to do the works. hope this can help you thanks for using the fixya.
Jul 18, 2012 | Samsung LN55B640 LCD TV
I have a samsung le46m51b no picture just audio
Tcon board failed check the fuse on the board marked by the letter P on it check it is ok no screen can be the fuse has popped this works in milli amps. if a failing capacitor on main board or on power board it blows the fuse in the tcon board in the middle of the screen back you need to take all boards out and remove the cage mind the cables when doing this. unscrew the 4 screw on the silver case covering the t con board un clip the cables off the screen ( with finger lift the black/brown flaps from cable end up) carefully remove the cables from the tcon board, now looking at the tcon board you will see a row of resistors and one marked with P on it check this. using a meter. should read no resistance and if on buzzer on meter should buzz. if don't buzz, remove the fuse with soldering iron, replace with the same fuse from a nintendo ds they are the same blow rate. before turning on the tv when you put everything back check the capacitors on power board the 16 volt 1000uf check these for damage as this is one of the main areas to cause the tcon board fuse to blow. also on the main board there are 3 capacitors 2 the same size and one that stands up more check these as the power goes to these first before going to the tcon board side. you need to remove them to test them. if any problems with these replace them. when replaced and you have checked there is no faults you can see on any board then turn the tv on. should be fine then.
May 05, 2012 | Samsung LE46M51B 46 in. LCD Television
Need to find the ceramic fuse for my samsung 50"
Hello Dyan, Hi you can find one at any electrical or electronics shop that sells spare parts, But mind you the reason why the fuse blows in the first place, have the power supply board checked for shorts such as a shorted switching regulator. If in the event the replacement fuse blows again, there is definitely a shorted part. Have this checked by a technician.
Feb 12, 2011 | Samsung FPT5084 50 in. Plasma HDTV
Samsung LN40A530P1F LCD TV keeps blowing main power fuse when i turn set on it blows right away i have replaced fuse many times. Also when back was off i noticed a arcing as fuse blows at a component just...
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=LN40A530P1F
If a fuse blows like that there is a major problem, inside. I suspect that what your are seeing is the inrush thermistor, and they exhibit this under great load. I would explect that this fault maybe in the actual PSU. Due to the lack of service manual support, i would get a quote for repair from an authorised service center.
Jun 22, 2010 | Samsung LN40A530 40 in. LCD TV
TV Blows internal fuse
You will have to find the source of a major short in your power supply.Since it's a 5A i assume i imagine that's where the short is.
Oct 23, 2007 | Samsung SlimFit TX-S2783 TV
Televison & Video Logo
118 people viewed this question
Henry  Thomas
Henry Thomas
