Question about Toto Round Maple SoftClose Toilet Seat With Lifekoat Polished Brass Hinges
Toto toilet seat slides to side - Toto Round Maple SoftClose Toilet Seat With Lifekoat Polished Brass Hinges
  • 86 Answers
You have to tighten these from the bottom of the bowl...use open end wrench or cresent to do
Posted on Nov 27, 2014
4 Suggested Answers
  • 659 Answers
SOURCE: I have a Toto saftclose toilet seat but it doesnt close softly!!!
If it is something you can adjust, there will be an area on the hing. There also may be a small cover over the adjustment screw.
Posted on Apr 01, 2009
sasquach8602
  • 5 Answers
SOURCE: Hi I have a Toto toilet
just get a new seat. You may find a replacement bolt kit but they are rare. happy hunting.
Posted on Feb 20, 2010
  • 40 Answers
SOURCE: The Toto maple softclose round
Try buying some cheap foam tape and place some on both the cover and the seat. Any hardware store should have it. Something similar to this:
http://www.google.com/products/catalog?q=foam+tape&hl=en&safe=off&client=firefox-a&hs=8cx&rls=org.mozilla:en-US:official&prmd=ivns&um=1&ie=UTF-8&tbm=shop&cid=10171339953270674152&sa=X&ei=Cu_VTfaCKIfYgQfIhrmvBw&ved=0CJgBEPICMAE&biw=1280&bih=548#
Posted on May 20, 2011
Loose seat,piece missing or broken
Hello, I experienced similar symptoms with my Neorest 600. Do not call a plumber, they cannot fix!
I recommend calling Toto! Their support people will take the time to help you [this is what the experienced Toto plumber did that I hired :' ]
I had a leak too and ended up sending the whole electronics & seat in for repair. These one piece units do not require a plumber. Lo [Toto technical support] gave directions that I, a 60 year old woman who normally does not disassemble such an item was able to perform!
I realize some may not like my post to turn it to the manufacturer, but in this case it was the best solution for my fix.
Call first, get a case number and support person. Then they work quickly via email with you. This was my only toliet :' So i was with out a toilet during this period. Toto worked quickly to get my toilet back to me! The shipping time is what took the longest. Take a photo of the problem and you will be able to submit for your case via online.
Hope this helps! And hope your fix they will be able to send parts for so you are able to fix!
My excellent contact.
Lo Lam
Senior Technical Support
Technical Support
(888) 295-8134 ext. 1641Office
(888) 295-8134 ext. 4Tech Support
(678) 466-1287Fax
TOTO USA,Inc.
5351 Jurupa StreetOntario CA, 91761
http://www.totousa.com
May 29, 2014 | Toto MS990CGR11 Neorest 600 One-Piece...
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
The Toto elongated seat is shifting from left to right--
They are designed to have a little movement to prevent breakage if it is a lot then replace they is no way to adjust
Nov 01, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
The toilet seat on my TOTO toilet has come off. Has something broken that I can repair or do I have to buy a new seat?
are you sure it is broken or the screw has come loose check it out again does not break very easily
Sep 26, 2009 | Toto Washlet S400 for Power Gravity...
Loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Sep 06, 2009 | Home
Hello - my toto toilet seat broke where the bolt holds the seat to the toilet
well you can go to home depot and get your self new seat with bolt or you can buy the screws for it
Aug 10, 2009 | Toto Lloyd 1pc. E/F Toilet w/Maple Seat ...
Toto C100 Toilet Washlet Seat
There are two types of bowls as far as toilets are concerned...elongated and round front. The seats are interchangable as long as there isn't anything different in the way the seat is mounted to the toilet. As far as I know and my experiance with both brands, I can't see any reason why it would not work.
Apr 05, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
Toto Round Maple SoftClose Toilet Seat With Lifekoat Polished Brass Hinges Logo
488 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
