Question about Garden
I bought a echo SRM-220BE straight shaft wipper snipper second hand what is the best oil to fuel mixture as the guy I bought it off had know idea
  • 708 Answers
SOURCE: fuel mix and manual for Echo SRM 4000
Go to www.echo-usa.com/pdf/documentation/SRM40005000edi_110107.pdf
Posted on Mar 28, 2009
vincob
  • 718 Answers
SOURCE: echo srm 3800 strimmer starting problems.
Check to see that your fuel line is still attached in the tank the piece in the tank will also have a clunk on it. The hose in the tank is usually yellow in color and they get soft and fall off sometimes. You can get this hose at your local hardware store or small engine service center.
Posted on Oct 08, 2009
dontbother10
  • 2220 Answers
SOURCE: hi im after the fuel mixture for a 125L husqvarna
From you manual:
Two-stroke oil
For great results and performance use HUSQVARNA two--stroke oil, which is specially formulated for our two-stroke engines. Mixture 1:50 (2%). To maximize the life of your trimmer, you may choose to use a high quality synthetic oil formulated for two-stroke engines. Mixture 1:50 (2%). Never use two--stroke oil intended for water-cooled outboard engines, sometimes referred to as outboard oil. Never use oil intended for four-stroke engines.
WARNING! Always ensure there is adequate ventilation when handling fuel.
1 gallon of premium fuel to 2.6 ounces 2-cycle oil. 2.6 ounce pre-measured containers are available at most chainsaw outlets.
You can find your manual here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Posted on Jan 25, 2010
rycgl
  • 1545 Answers
SOURCE: Owners Manual for Echo GT200R straight Shaft Gas Trimmer
Maybe go to Echo's website and check with them.
Posted on Jul 13, 2010
rycgl
  • 1545 Answers
SOURCE: how to set air fuel 323l wipper snipper runs for 2
Here are 2 links for adjusting the two popular brands of diaphragm carburetors:
http://www.zamacarb.com/tipspage.html
http://tech.flygsw.org/walbro_tuneup.htm
Posted on Dec 12, 2010
How do you take off the nylonhead off a srm 225 straight shaft trimmer to put on a new one
The nylon head should pop off by clicking on two pins holding it to the main body. Once it pops off you should be able to reload it and push back to those clips again
Aug 14, 2014 | Echo Garden
Whipper snipper manual
50:1 with good quality 2/s oil
Jan 18, 2014 | Echo Garden
Echo SRM-230 trimmer stalls when you give it more gas. Can get more RPM with choke, but still not enough to use. Trimmer only has 20 hours on it.
empty the fuel tank and refill with the correct oil/ fuel mixture as too much oil blocks the jets Machines do not like any e- mix fuels as the jets are not set for the mix.
Jun 22, 2013 | Echo Garden
Have a ECHO gas trimmer SRM 2100 wont start. coulld it be the fly wheel
If it doesn't turn over when you pull the rope it could be in the starter assembly or the flywheel where the starter pawls engage it. If it turns over then you need to check for fuel, spark, air and compression.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 20, 2013 | Echo 2-Cycle 28.1 cc Straight Shaft Gas...
SRM 2000a echo whipper snipper Not starting tried new spark plug and fuel.
Small engines have three systems. 1-ignition 2-compression 3-fuel
if you have spark at the plug and fuel gets to the engine the issue is in the engine compression system. I recommend pulling off the muffler and looking for scratches or scoring.
If you need to replace parts find a dealer like www.arcolawn.com to assist.
Feb 11, 2011 | Echo Garden
My stil wipper snipper starts and runs but only on low revs.it will not rev up
Most Stihl's are the same...Sounds like you need to adjust your mixture screws on the carby. you will need a small flat blade screwdriver (usually these are supplied with the wipper snipper from new and they have a little arrow on the top), H is for the High speed mixture screw, L is for the Low speed mixture screw. Turn the screws clockwise in until they seat (do NOT tighten!!) then turn them anti-clockwise the recommended amounts of turn on the cover around the holes. Careful not to lean the mixture out too much, but if it is the newer type they have a restictor on the High Speed that stops it at 3/4 of a turn. start it up and hopefully it will fix your problem, if not you will have to take it to a professional. Further info majority of STIHL high and low mixture setting are fine tuned via the respective rev settings , you'll have find out the particular setting from your STIHL dealer(sorry)
Nov 21, 2010 | Garden
Fuel mix and manual for Echo SRM 4000
Mar 28, 2009 | Echo Garden
Garden Logo
264 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
