Question about Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator
Why is our Whirlpool model number ET21NKXJW01 is leaking inside from under the freezer area
22yooper
  • 828 Answers
SOURCE: The back part of the refridgerator inside where the cold air comes out is leaking water and the back inside wall is wet?
You should fine a drain line just below the freezer level in the back. The drain line is more than likely plugged. Check the loop seal down by the drain pan under the back of the refrigerator. It may be restricted at that point. It may require a complete defrost of the freezer to clear the ice formed in the drain from a back-up.
Posted on May 28, 2008
  • 236 Answers
SOURCE: whirlpool refrigerator leaks
the drain hole at the bottom rear is blocked. a pipe cleaner run down it should clear it out.
Posted on Apr 09, 2009
SOURCE: Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
Posted on May 13, 2009
Sea Breeze
  • 4655 Answers
SOURCE: leak inside and outside
Most times this is because the drain from the defrost is blocked as it goes down to the pan under the refrigerator. I am placing a link that can help you solve this problem. sometimes on different models the cause may be in a different place so let me know what you find. Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
http://servicepartstec.blogspot.com/
Posted on May 31, 2009
erpaalai
  • 999 Answers
SOURCE: Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Posted on Aug 10, 2009
My frigidaire automatic defrost upright freezer gets ice build-up at the top right at the front any suuggestions
This is just a general answer but it may mean that the door seal is leaking. Try running a dollar bill under the seal to see if that area is looser than the rest of the door seal.
Look inside the freezer for model number.
How to Check Freezer Door Seal DoItYourself com
Aug 01, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Drain tube opening clogs with ice inside freezer.
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com and provide your full name, phone number, address and the model and serial number for your freezer.
Apr 01, 2017 | Whirlpool Freezers
Drain pan filling up. I emptied the pan and about 24 hours later its full again. We have ice and water in the door the freezer is cold just pan filling
If your evaporator fan is working properly the water would evaporate back into your home or business. If the evaporator fan was not working the freezer would not freeze and fresh food would spoil. That is way too much normal condensate unless there is a leak around the door seal or leak in the cool water supply tank storage or filter area. Not knowing the model number I would think you may have a drain opening under the crisper drawer that leads to pan. And think it may be a good idea to turn water supply off until sure of the source. Click here=> Leaking Refrigerators Just What may Be Happening and Click Here=> Leaking Refrigerator's? Locate model number for Kenmore Here=> Kenmore Model Number Locator's Most other model number locators are about the same as on the left sidebar on the Leaking Refrigerators page. I will be here to answer further questions, and there are a lot of things to look for on that page, Thanks, Sea Breeze Click on Logo enter your model for parts breakdown=>
sea_breeze_114.jpg WHIRLPOOL PRODUCT MANUALS
I will be here to answer further questions, Thanks, Sea Breeze
Mar 13, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
It appears the I have water leaking from under the freezer. The freezer is on top, under the freezer is a styrophom area that appears to leak. Ideas?
in the area of the Styrofoam should be a plastic tube this is drain for freezer during defrost cycle drain might be clogged and leaking down thru unit
Sep 27, 2009 | Whirlpool Refrigerators
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool Refrigerator ET21GM LEAKING water ALL OVER INSIDE
there is a drain under the coils in the freezer. it is frozen and the water has no place to go. hairdryer and a lot of patience. a hairdryer can melt a freezer /warning.
Jun 09, 2009 | Whirlpool ET1MTKXKQ White 20.9 Cu. Ft....
Leak inside and outside
May 30, 2009 | Whirlpool ET8MTKX Top Freezer Refrigerator
Our whirlpool gold refrigerator is 50 degrees
Sounds like your refrigerator is not defrosting. Could you send me the model number so I can help you better? Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 29, 2009 | Refrigerators
WATER RUNNING OUT FROM UNDER REFRIGERATOR
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
Dec 20, 2008 | Whirlpool 19.8 cu. ft. Side-by-Side...
Whirlpool has water drip inside fridge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 25, 2008 | Refrigerators
Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator Logo
52 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
