Question about Sharp AL 1631 Copier
Sharp a207 toner cartridge
This new cartridge installed in a sharp photocopier machine but after installing it the machine didnt respond properly dont know why means not even a single respong it didnt even warm up like they do when u start them up just like a pc hangs some one said thar there may be a difference in model no from uae and europe stuff.
  • Vladimir Machlis
    Vladimir Machlis May 11, 2010
    Is the cartridge original or remanufactured?
    Are any read lights on display?
  • Jessetech May 11, 2010
    need to see if your copier needs developer if so you overtoned it
    Problem Solver:
  • 8 Answers
Thats so true - the Chinese **** on the market is just doing horrendous things to copiers out there. I remember we had Katun - all their stuff was great and cheap but these days anything aftermarket has been slapped together in some greasy sweatshop in some god forsaken corner of the globe then western customers go and put this stuff into their multi thousand dollar office machines thinking everything will be fine - very risky.
Posted on Mar 01, 2009
    Novelist:
  • 126 Answers
Is this new cart. an Original manuf. cart. or after market?? If it is an after market you have to read very carefully. You have to make sure it says, ' for use in' not ' can be used in'. The problem with SOME 'can be used in' products are that there could be just a slight difference in the part ( in this case the toner cart.). Take the new cart. out of the machine and install the old cart. back into the machine.... does the machine sound like old --- even if the device gives you a message like ' replace toner cart.' ?? If so you have a bad cart. or you may have installed it wrong. Try the new cart. once again but do not force. Does it work? If not contact the company you purchased it from and tell them the problem, most companies will work with you. Again, if you are buying after market supplies make sure if states 'for use in'.
Posted on Jan 04, 2009
Sharp MX-M232D: F2-40 error. I was able to scan without issues. When I inserted a Sharp Genuine Toner cartridge into the machine, I receive an F2-40 error.
If you have reset the machine as described & then re--inserted the same toner cartridge giving you the same error code then I would suspect the CRUM chip that is installed on the toner cartridge is faulty.
If your machine is under a maintenance contract which includes the provision of toner then contact your service provider & they should replace it F.O.C. If you have purchased it yourself then contact the supplier advising them of a faulty cartridge. If you replace the toner with a new one, you must reset the machine as above before you insert the new toner.
Hope this helps.
Dave.
Oct 12, 2017 | Sharp Office Equipment & Supplies
SHARP AR 5520 keep displaying TONER INDICATOR ALARM MESSAGE whenever I switch on the copier. And even if there is toner, the message keep displaying. So what is the problem?
Dear
The ink cart. is dual component one is drum unit and other is toner unit. You may go to system information there consumable information which indicate the status of the both and according to that replace the chip of the respective cart.
Thanks.
Jan 12, 2015 | Sharp Office Equipment & Supplies
Sharp ar 5620 photocopy error f2
F2 errors means problem with toner supply or toner cartridge itself. For better understanding it is necessary to obtain a subcode by pressing START key. Clean toner cartridge CRUM chip contacts and check if cartridge destination is proper for your area.
Apr 15, 2013 | Sharp AR-M237 Copier
Code F2:72
F2:72 is for Toner cartridge improper cartridge detection (MAGENTA).
Check and see if the right toner cartridge is installed. If it is the proper cartridge I would suggest placing a service call.
Oct 12, 2010 | Sharp MX-2700N Color Copier
SHarp Z-20 home photocopier toner refill- Manual?.
There is a small door at the right front, unlatch from the top, open the door and unlatch the green tab on the cartridge and pull the cartridge out.
Mar 17, 2009 | Sharp Office Equipment & Supplies
Newly installed Sharp AR-5320E not copying
That is because you need to put in some developer. This acts as a carrier for the toner. AR202ld is what you need
Nov 24, 2008 | Sharp AR-5320 Black and White Copier
Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Nov 05, 2008 | Sharp AL 1631 Copier
How to install sharp photocopier AR5320E on vista
just bought a brand new AR-5320E, unwrapped the whole thing and the paper manual only tells me about how to install the printer drivers, and make photocopies, I've inserted the cartridge and poured the dark powder developer stuff into the chamber, but still it's not making any photocopies, and I can't find a single manual or instructions booklet anywhere to tell me what's wrong!! can you help? I've been reading about toner's etc, but it only came with the black powdery stuff
Oct 08, 2008 | Sharp Office Equipment & Supplies
Sharp al-1644 photocopier
Usually CH indicates that one of the doors on the copier is not closed properly, if it is a flashing CH then there is no toner cartridge in the copier or the cartridge is of the wrong type for this machine. A lot of toners for this machine look alike but are not the same for the machine.
May 26, 2008 | Office Equipment & Supplies
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
